[Nek5000-users] Pipe with expansion
Wed Jan 15 09:52:08 CST 2014
Hi Paul,
I will try that mapping, I created a straight pipe to do some simulations.
1) Is there a way to check my spectral convergence, so that I can do
some mesh convergence study?
2) Is there a way to plot the kinetic energy in the flow ?
Thank you,
Kamal
On 15/01/2014 12:14, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Kamal,
> For the geometry you describe, I would apply mesh morphing
> to a standard straight pipe.  You can create such a pipe
> using a subset of the mkmesh script provided in the expansion
> example.
> If your transition region is conical, then I woud make
> certain that the change in slope occurs at element boundaries,
> i.e., as in the half cross-section depicted below:
>                               _______________
>        ________________/  |   |      |      |
>        +-----+-----+---+--+---+------+------+---->  z
> Paul
> On Wed, 15 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> I looked at the example and it looks very helpful, but for a sudden
>> expansion we have only two parts (i.e) the inlet pipe and the outlet
>> pipe. Whereas in a diverging pipe we have three section (i.e,) The
>> inlet pipe, Diverging section and the outlet pipe.
>> Is it possible for me to create a 2D diverging section using mesh
>> modification and revolve it around the centre axis to get a 3d
>> diverging pipe ?
>> or should I apply the mesh modification directly to the 3d sudden
>> expansion pipe using usrdat2() ?
>> Thanks,
>> Kamal
>> On 14/01/2014 21:09, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Paul,
>>> Thanks a lot for the update. I will take a look at as soon as
>>> possible and keep you updated with it.
>>> Thank you,
>>> Kamal
>>> On Jan 14, 2014, at 9:04 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Kamal,
>>>> I've added an example for a step-type expansion in a pipe. New
>>>> example directory
>>>> is nek5_svn/examples/expansion, with a README.
>>>> If you want a standard diffuser, I would use mesh-morphing, as
>>>> outlined in the
>>>> nek primer, which can be found on this page:
>>>> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
>>>> I've also automated our turbulent outflow bc treatment -- one
>>>> simply provides an
>>>> expansion factor (typically ~ 1.5) and two persistent arrays to
>>>> turb_outflow(), which
>>>> is now in navier5.f.    This can be useful when very strong
>>>> vortices are leaving the
>>>> domain, which is possible for certain diffuser flow conditions (and
>>>> others).
>>>> Paul
>>>> ________________________________________
>>>> From: nek5000-users-bounces at lists.mcs.anl.gov
>>>> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
>>>> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>> Sent: Monday, January 13, 2014 3:35 AM
>>>> To: nek5000-users at lists.mcs.anl.gov
>>>> Subject: [Nek5000-users] Creating a Mesh
>>>> Hi
>>>> Can some one please help me in this because I am new to nek
>>>> 1) How can I create a .rea for a specific geometry say ' A sudden
>>>> expansion pipe ' or a ' Diverging pipe '
>>>> 2) What tool I should use to create that mesh.
>>>> Thank you
>>>> kamal
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
