[Nek5000-users] Computing higher order derivatives
Wed Jan 15 03:45:44 CST 2014
Hello
For doing stability analysis I need upto third derivatives of velocity. Is
this already available in nek ? I tried to compute derivatives of the nek
solution using chebfun but the second and higher derivatives are coming out
to be discontinuous ? This is expected I suppose, since the solution is
only C^0. Can I repeatedly use gradm1 to get higher derivatives ? Does
gradm1 do some projection ?
Thanks
praveen
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140115/4b8a0415/attachment.html>
