[Nek5000-users] Problem in 2d pipe simulation
Mon Jan 13 12:58:18 CST 2014
When you create the .box file, it is important that the line containing the
boundary conditions follows the format as described on the nek wiki and
documentation.
It is a 3 character code that defines each boundary condition, and the
whitespace must be maintained.  For example,
"v  ,A  ,W  ,W  ,   ,   "
would be a valid entry, whereas using less than 3 characters will result in
commas and whitespace being entered into your .rea file.
More info and examples can be found:
http://nek5000.mcs.anl.gov/index.php/Genbox
Best,
Katie
On Mon, Jan 13, 2014 at 8:49 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> I created my .box file, with help of genbox I created .rea file.
> later I created a .usr and SIZE file.
> I have attached all the files I used with this mail
> I launched the simulation and I got this error
> |      _   __ ______ __ __  ______  ____    ____    ____   |
> |     / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
> |    /  |/ // __/  / ,<   /___ \\  / / / // / / // / / /   |
> |   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
> |  /_/ |_//_____//_/ |_|/_____/  \\____/ \\____/ \\____/   |
> | NEK5000:  Open Source Spectral Element Solver            |
> | COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
> | Version:  1.0rc1 / SVN  r982                             |
> | Web:      http://nek5000.mcs.anl.gov                     |
>  Number of processors:           1
>  REAL    wdsize      :           8
>  INTEGER wdsize      :           4
>   Beginning session:
> /home/kamal/neksamples/mine/box.rea
>  timer accuracy:   0.0000000E+00 sec
>  read .rea file
>  nelgt/nelgv/lelt:          15          15          15
>  lx1  /lx2  /lx3 :           8           6           8
>  mapping elements to processors
>            0          15          15          15          15  NELV
>  RANK     0 IEG       1       2       3       4       5 6       7       8
>                       9      10      11      12      13      14 15
>  element load imbalance:            0          15          15
>  done :: mapping elements to processors
>            0  objects found
>  done :: read .rea file   0.67091E-03 sec
>  Reset the target Courant number to .5
>  setup mesh topology
>    Right-handed check complete for      15 elements. OK.
>    setvert2d:   8         252         792         252         252
>  call usrsetvert
>  done :: usrsetvert
> gs_setup: 0 unique labels shared
>    handle bytes (avg, min, max): 3972 3972 3972
>    buffer bytes (avg, min, max): 0 0 0
>    setupds time 1.9503E-04 seconds   0  8         252          15
>            4  max multiplicity
>  done :: setup mesh topology
>  call usrdat
>  done :: usrdat
>  generate geometry data
>  vol_t,vol_v:   1.9999999999999920        1.9999999999999920
>  done :: generate geometry data
>  call usrdat2
>  done :: usrdat2
>  regenerate geometry data           1
>  vol_t,vol_v:   1.9999999999999938        1.9999999999999938
>  done :: regenerate geometry data           1
>  verify mesh topology
>    0.0000000000000000        4.0000000000000000       Xrange
>    0.0000000000000000       0.50000000000000000       Yrange
>    0.0000000000000000        0.0000000000000000       Zrange
>  done :: verify mesh topology
>  103   Parameters from file:/home/kamal/neksamples/mine/box.rea
>    1      1.00000         p1  DENSITY
>    2     -20.0000         p2  VISCOS
>    7      1.00000         p7  RHOCP
>    8      1.00000         p8  CONDUCT
>   11      1000.0          p11 NSTEPS
>   12     -1.000000E-04    p12 DT
>   15      100.000         p15 IOSTEP
>   18      0.250000E-01    p18 GRID
>   19     -1.00000         p19 INTYPE
>   20      12.0000         p20 NORDER
>   21      0.100000E-10    p21 DIVERGENCE
>   22      0.100000E-11    p22 HELMHOLTZ
>   24      0.100000E-09    p24 TOLREL
>   25      0.100000E-09    p25 TOLABS
>   26      1.00000         p26 COURANT/NTAU
>   27      3.00000         p27 TORDER
>   28      0.              p28 TORDER: mesh velocity (0: p28=p27)
>   43      1.00000         p43 0=semg/1=schwarz
>   66      4.00000         p66 output : <0=ascii, else binary
>   67      4.00000         p67 restart: <0=ascii, else binary
>   93      20.0000          p93 Number of previous pressure solns saved
>   94      5.00000          p94 start projecting velocity after p94 step
>   95      5.00000          p95 start projecting pressure after p95 step
>   96      1.00000          p96 u0 translational velocity (in .usr)
>   97      0.30000          p97 v0 translational velocity (in .usr)
>   99      3.00000          p99   dealiasing: <0--> off/3--> old/4--> new
>  102      1.00000          p102   Dump out divergence at each time step
>  IFTRAN   = T
>  IFFLOW   = T
>  IFHEAT   = F
>  IFSPLIT  = F
>  IFLOMACH = F
>  IFUSERVP = F
>  IFUSERMV = F
>  IFSTRS   = F
>  IFCHAR   = F
>  IFCYCLIC = F
>  IFAXIS   = F
>  IFMVBD   = F
>  IFMELT   = F
>  IFMODEL  = F
>  IFKEPS   = F
>  IFMOAB   = F
>  IFNEKNEK = F
>  IFSYNC   = T
>  IFVCOR   = T
>  IFINTQ   = F
>  IFCWUZ   = F
>  IFSWALL  = F
>  IFGEOM   = F
>  IFSURT   = F
>  IFWCNO   = F
>  IFTMSH for field           1    =  F
>  IFADVC for field           1    =  T
>  IFNONL for field           1    =  F
>  Dealiasing enabled, lxd=          12
>  Estimated eigenvalues
>  EIGAA =    20.047633939712757
>  EIGGA =    46987.971345031350
>  EIGAE =   0.61685027506808487
>  EIGAS =    3.8461538461538464E-003
>  EIGGE =    46987.971345031350
>  EIGGS =    2.0000000000000000
>   E-solver strategy:  1 itr
>            0          15  BC FAIL
> EXIT: E INVALID BC FOUND in genfast         15
> call exitt: dying ...
> backtrace(): obtained 9 stack frames.
> ./nek5000(print_stack_+0x1a) [0x4fe90a]
> ./nek5000(exitt_+0x20f) [0x5bc0af]
> ./nek5000(exitti_+0x12a) [0x5be72a]
> ./nek5000(gen_fast_+0x581) [0x4fa701]
> ./nek5000(set_overlap_+0x125) [0x4eb465]
> ./nek5000(nek_init_+0x82d) [0x41affd]
> ./nek5000(main+0x24) [0x419e54]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fd9f1f33de5]
> ./nek5000() [0x419e99]
> total elapsed time             :   3.74889E-03 sec
> total solver time incl. I/O    :   0.00000E+00 sec
> time/timestep                  :   0.00000E+00 sec
> CPU seconds/timestep/gridpt    :   0.00000E+00 sec
> real    0m0.030s
> user    0m0.020s
> sys    0m0.000s
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140113/2a0e92b4/attachment.html>
