[Nek5000-users] Problem in 2d pipe simulation
Mon Jan 13 08:49:56 CST 2014
I created my .box file, with help of genbox I created .rea file.
later I created a .usr and SIZE file.
I have attached all the files I used with this mail
I launched the simulation and I got this error
|      _   __ ______ __ __  ______  ____    ____    ____   |
|     / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
|    /  |/ // __/  / ,<   /___ \\  / / / // / / // / / /   |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \\____/ \\____/ \\____/   |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
| Version:  1.0rc1 / SVN  r982                             |
| Web:      http://nek5000.mcs.anl.gov                     |
  Number of processors:           1
  REAL    wdsize      :           8
  INTEGER wdsize      :           4
   Beginning session:
/home/kamal/neksamples/mine/box.rea
  timer accuracy:   0.0000000E+00 sec
  read .rea file
  nelgt/nelgv/lelt:          15          15          15
  lx1  /lx2  /lx3 :           8           6           8
  mapping elements to processors
            0          15          15          15          15  NELV
  RANK     0 IEG       1       2       3       4       5 6       7       8
                       9      10      11      12      13      14 15
  element load imbalance:            0          15          15
  done :: mapping elements to processors
            0  objects found
  done :: read .rea file   0.67091E-03 sec
  Reset the target Courant number to .5
  setup mesh topology
    Right-handed check complete for      15 elements. OK.
    setvert2d:   8         252         792         252         252
  call usrsetvert
  done :: usrsetvert
gs_setup: 0 unique labels shared
    handle bytes (avg, min, max): 3972 3972 3972
    buffer bytes (avg, min, max): 0 0 0
    setupds time 1.9503E-04 seconds   0  8         252          15
            4  max multiplicity
  done :: setup mesh topology
  call usrdat
  done :: usrdat
  generate geometry data
  vol_t,vol_v:   1.9999999999999920        1.9999999999999920
  done :: generate geometry data
  call usrdat2
  done :: usrdat2
  regenerate geometry data           1
  vol_t,vol_v:   1.9999999999999938        1.9999999999999938
  done :: regenerate geometry data           1
  verify mesh topology
    0.0000000000000000        4.0000000000000000       Xrange
    0.0000000000000000       0.50000000000000000       Yrange
    0.0000000000000000        0.0000000000000000       Zrange
  done :: verify mesh topology
  103   Parameters from file:/home/kamal/neksamples/mine/box.rea
    1      1.00000         p1  DENSITY
    2     -20.0000         p2  VISCOS
    7      1.00000         p7  RHOCP
    8      1.00000         p8  CONDUCT
   11      1000.0          p11 NSTEPS
   12     -1.000000E-04    p12 DT
   15      100.000         p15 IOSTEP
   18      0.250000E-01    p18 GRID
   19     -1.00000         p19 INTYPE
   20      12.0000         p20 NORDER
   21      0.100000E-10    p21 DIVERGENCE
   22      0.100000E-11    p22 HELMHOLTZ
   24      0.100000E-09    p24 TOLREL
   25      0.100000E-09    p25 TOLABS
   26      1.00000         p26 COURANT/NTAU
   27      3.00000         p27 TORDER
   28      0.              p28 TORDER: mesh velocity (0: p28=p27)
   43      1.00000         p43 0=semg/1=schwarz
   66      4.00000         p66 output : <0=ascii, else binary
   67      4.00000         p67 restart: <0=ascii, else binary
   93      20.0000          p93 Number of previous pressure solns saved
   94      5.00000          p94 start projecting velocity after p94 step
   95      5.00000          p95 start projecting pressure after p95 step
   96      1.00000          p96 u0 translational velocity (in .usr)
   97      0.30000          p97 v0 translational velocity (in .usr)
   99      3.00000          p99   dealiasing: <0--> off/3--> old/4--> new
  102      1.00000          p102   Dump out divergence at each time step
  IFTRAN   = T
  IFFLOW   = T
  IFHEAT   = F
  IFSPLIT  = F
  IFLOMACH = F
  IFUSERVP = F
  IFUSERMV = F
  IFSTRS   = F
  IFCHAR   = F
  IFCYCLIC = F
  IFAXIS   = F
  IFMVBD   = F
  IFMELT   = F
  IFMODEL  = F
  IFKEPS   = F
  IFMOAB   = F
  IFNEKNEK = F
  IFSYNC   = T
  IFVCOR   = T
  IFINTQ   = F
  IFCWUZ   = F
  IFSWALL  = F
  IFGEOM   = F
  IFSURT   = F
  IFWCNO   = F
  IFTMSH for field           1    =  F
  IFADVC for field           1    =  T
  IFNONL for field           1    =  F
  Dealiasing enabled, lxd=          12
  Estimated eigenvalues
  EIGAA =    20.047633939712757
  EIGGA =    46987.971345031350
  EIGAE =   0.61685027506808487
  EIGAS =    3.8461538461538464E-003
  EIGGE =    46987.971345031350
  EIGGS =    2.0000000000000000
   E-solver strategy:  1 itr
            0          15  BC FAIL
EXIT: E INVALID BC FOUND in genfast         15
call exitt: dying ...
backtrace(): obtained 9 stack frames.
./nek5000(print_stack_+0x1a) [0x4fe90a]
./nek5000(exitt_+0x20f) [0x5bc0af]
./nek5000(exitti_+0x12a) [0x5be72a]
./nek5000(gen_fast_+0x581) [0x4fa701]
./nek5000(set_overlap_+0x125) [0x4eb465]
./nek5000(nek_init_+0x82d) [0x41affd]
./nek5000(main+0x24) [0x419e54]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fd9f1f33de5]
./nek5000() [0x419e99]
total elapsed time             :   3.74889E-03 sec
total solver time incl. I/O    :   0.00000E+00 sec
time/timestep                  :   0.00000E+00 sec
CPU seconds/timestep/gridpt    :   0.00000E+00 sec
real    0m0.030s
user    0m0.020s
sys    0m0.000s
          15          24           3           8          60          24           0
           7           8           7          19          18
           7           7          16          18          17
           6          16          24          17          23
           3          24           6          23          11
           3           6           5          11          10
           5          19          18          15          14
           5          18          17          14          22
           6          17          23          22          21
           2          23          11          21          13
           2          11          10          13          12
           4          15          14           4           3
           4          14          22           3          20
           1          22          21          20           2
           1          21          13           2           9
           0          13          12           9           1
****** PARAMETERS *****
    2.610000     NEKTON VERSION
            2 DIMENSIONAL RUN
          103 PARAMETERS FOLLOW
   1.00000         p1  DENSITY
  -20.0000         p2  VISCOS
   0.
   0.
   0.
   0.
   1.00000         p7  RHOCP
   1.00000         p8  CONDUCT
   0.
   0.              p10 FINTIME
   1000.0          p11 NSTEPS
   0.              p13 IOCOMM
   0.              p14 IOTIME
   100.000         p15 IOSTEP
   0.              p16 PSSOLVER
   0.
  -1.00000         p19 INTYPE
   12.0000         p20 NORDER
  0              p23 NPSCAL
   3.00000         p27 TORDER
   0.              p29 magnetic visc if > 0, = -1/Rm if < 0
   0.              p30 > 0 ==> properties set in uservp()
   0.              p31 NPERT: #perturbation modes
   0.              p32 #BCs in re2 file, if > 0
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.              p41 1-->multiplicative SEMG
   0.              p42 0=gmres/1=pcg
   0.              p44 0=E-based/1=A-based prec.
   0.              p45 Relaxation factor for DTFS
   0.              p46 reserved
   0.              p47 vnu: mesh matieral prop
   0.
   0.
   0.
   0.
   0.              p52 IOHIS
   0.
   0.              p54 1,2,3-->fixed flow rate dir=x,y,z
   0.              p55 vol.flow rate (p54>0) or Ubar (p54<0)
   0.
   0.
   0.
   0.              p59 !=0 --> full Jac. eval. for each el.
   0.              p60 !=0 --> init. velocity to small nonzero
   0.
   0.              p62 >0 --> force byte_swap for output
   0.              p63 =8 --> force 8-byte output
   0.              p64 =1 --> perturbation restart
   0.              p65 #iofiles (eg, 0 or 64); <0 --> sep. dirs
   0.              p68 iastep: freq for avg_all
   0.
   0.
   0.
   0.
   0.
   0.              p74 verbose Helmholtz
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.               p84 !=0 --> sets initial timestep if p12>0
   0.               p85 dt ratio if p84 !=0, for timesteps>0
   0.               p86 reserved
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.               p101   No. of additional filter modes
   .000             p103   weight of stabilizing filter (.01)
      4  Lines of passive scalar data follows2 CONDUCT; 2RHOCP
   1.00000       1.00000       1.00000       1.00000       1.00000
           13  LOGICAL SWITCHES FOLLOW
  T     IFFLOW
  F     IFHEAT
  T     IFTRAN
  T F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
  F F T T T T T T T T T T IFTMSH (IF mesh for this field is T mesh)
  F     IFAXIS
  F     IFSTRS
  F     IFSPLIT
  F     IFMGRID
  F     IFMODEL
  F     IFKEPS
  F     IFMVBD
  F     IFCHAR
 4.00000       0.50000      0.00      0.00     XFAC,YFAC,XZERO,YZERO
 **MESH DATA** 6 lines are X,Y,Z;X,Y,Z. Columns corners 1-4;5-8
          15  2          15           NEL,NDIM,NELV
            ELEMENT           1 [    1a]  GROUP  0
   0.00000      0.800000      0.800000       0.00000
   0.00000       0.00000      0.166667      0.166667
            ELEMENT           2 [    1b]  GROUP  0
  0.800000       1.60000       1.60000      0.800000
            ELEMENT           3 [    1c]  GROUP  0
   1.60000       2.40000       2.40000       1.60000
            ELEMENT           4 [    1d]  GROUP  0
   2.40000       3.20000       3.20000       2.40000
            ELEMENT           5 [    1e]  GROUP  0
   3.20000       4.00000       4.00000       3.20000
            ELEMENT           6 [    1f]  GROUP  0
  0.166667      0.166667      0.333333      0.333333
            ELEMENT           7 [    1g]  GROUP  0
            ELEMENT           8 [    1h]  GROUP  0
            ELEMENT           9 [    1i]  GROUP  0
            ELEMENT          10 [    1j]  GROUP  0
            ELEMENT          11 [    1k]  GROUP  0
  0.333333      0.333333      0.500000      0.500000
            ELEMENT          12 [    1l]  GROUP  0
            ELEMENT          13 [    1m]  GROUP  0
            ELEMENT          14 [    1n]  GROUP  0
            ELEMENT          15 [    1o]  GROUP  0
  ***** CURVED SIDE DATA *****
           0 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
  ***** BOUNDARY CONDITIONS *****
  ***** FLUID   BOUNDARY CONDITIONS *****
 ,W   1  1   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1  2   2.00000       4.00000       0.00000       0.00000       0.00000
 E    1  3   6.00000       1.00000       0.00000       0.00000       0.00000
 v ,  1  4   0.00000       0.00000       0.00000       0.00000       0.00000
 ,W   2  1   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2  2   3.00000       4.00000       0.00000       0.00000       0.00000
 E    2  3   7.00000       1.00000       0.00000       0.00000       0.00000
 E    2  4   1.00000       2.00000       0.00000       0.00000       0.00000
 ,W   3  1   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3  2   4.00000       4.00000       0.00000       0.00000       0.00000
 E    3  3   8.00000       1.00000       0.00000       0.00000       0.00000
 E    3  4   2.00000       2.00000       0.00000       0.00000       0.00000
 ,W   4  1   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4  2   5.00000       4.00000       0.00000       0.00000       0.00000
 E    4  3   9.00000       1.00000       0.00000       0.00000       0.00000
 E    4  4   3.00000       2.00000       0.00000       0.00000       0.00000
 ,W   5  1   0.00000       0.00000       0.00000       0.00000       0.00000
  ,A  5  2   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5  3   10.0000       1.00000       0.00000       0.00000       0.00000
 E    5  4   4.00000       2.00000       0.00000       0.00000       0.00000
 E    6  1   1.00000       3.00000       0.00000       0.00000       0.00000
 E    6  2   7.00000       4.00000       0.00000       0.00000       0.00000
 E    6  3   11.0000       1.00000       0.00000       0.00000       0.00000
 v ,  6  4   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7  1   2.00000       3.00000       0.00000       0.00000       0.00000
 E    7  2   8.00000       4.00000       0.00000       0.00000       0.00000
 E    7  3   12.0000       1.00000       0.00000       0.00000       0.00000
 E    7  4   6.00000       2.00000       0.00000       0.00000       0.00000
 E    8  1   3.00000       3.00000       0.00000       0.00000       0.00000
 E    8  2   9.00000       4.00000       0.00000       0.00000       0.00000
 E    8  3   13.0000       1.00000       0.00000       0.00000       0.00000
 E    8  4   7.00000       2.00000       0.00000       0.00000       0.00000
 E    9  1   4.00000       3.00000       0.00000       0.00000       0.00000
 E    9  2   10.0000       4.00000       0.00000       0.00000       0.00000
 E    9  3   14.0000       1.00000       0.00000       0.00000       0.00000
 E    9  4   8.00000       2.00000       0.00000       0.00000       0.00000
 E   10  1   5.00000       3.00000       0.00000       0.00000       0.00000
  ,A 10  2   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10  3   15.0000       1.00000       0.00000       0.00000       0.00000
 E   10  4   9.00000       2.00000       0.00000       0.00000       0.00000
 E   11  1   6.00000       3.00000       0.00000       0.00000       0.00000
 E   11  2   12.0000       4.00000       0.00000       0.00000       0.00000
  ,  11  3   0.00000       0.00000       0.00000       0.00000       0.00000
 v , 11  4   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12  1   7.00000       3.00000       0.00000       0.00000       0.00000
 E   12  2   13.0000       4.00000       0.00000       0.00000       0.00000
  ,  12  3   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12  4   11.0000       2.00000       0.00000       0.00000       0.00000
 E   13  1   8.00000       3.00000       0.00000       0.00000       0.00000
 E   13  2   14.0000       4.00000       0.00000       0.00000       0.00000
  ,  13  3   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13  4   12.0000       2.00000       0.00000       0.00000       0.00000
 E   14  1   9.00000       3.00000       0.00000       0.00000       0.00000
 E   14  2   15.0000       4.00000       0.00000       0.00000       0.00000
  ,  14  3   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14  4   13.0000       2.00000       0.00000       0.00000       0.00000
 E   15  1   10.0000       3.00000       0.00000       0.00000       0.00000
  ,A 15  2   0.00000       0.00000       0.00000       0.00000       0.00000
  ,  15  3   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15  4   14.0000       2.00000       0.00000       0.00000       0.00000
  ***** NO THERMAL BOUNDARY CONDITIONS *****
            0 	      PRESOLVE/RESTART OPTIONS  *****
            7         INITIAL CONDITIONS *****
C Default
C Default
C Default
C Default
C Default
C Default
C Default
  ***** DRIVE FORCE DATA ***** BODY FORCE, FLOW, Q
            4                 Lines of Drive force data follow
C
C
C
C
  ***** Variable Property Data ***** Overrrides Parameter data.
            1 Lines follow.
            0 PACKETS OF DATA FOLLOW
  ***** HISTORY AND INTEGRAL DATA *****
            0   POINTS.  Hcode, I,J,H,IEL
  ***** OUTPUT FIELD SPECIFICATION *****
            6 SPECIFICATIONS FOLLOW
  T      COORDINATES
  T      VELOCITY
  T      PRESSURE
  F      TEMPERATURE
  F      TEMPERATURE GRADIENT
            0      PASSIVE SCALARS
  ***** OBJECT SPECIFICATION *****
       0 Surface Objects
       0 Volume  Objects
       0 Edge    Objects
       0 Point   Objects
c-----------------------------------------------------------------------
      subroutine uservp (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
C
      udiff =0.
      utrans=0.
      return
      end
      subroutine userf  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
c
      ffx = 0.0
      ffy = 0.0
      ffz = 0.0
      return
      end
      subroutine userq  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
C
      qvol   = 0.0
      source = 0.0
      return
      end
      subroutine userchk    ! called once per step
      include 'SIZE'
      include 'TOTAL'
c
      n = nx1*ny1*nz1*nelv
      visc = param(2)
      u0   = param(96)
      v0   = param(97)
      if (istep.eq.0     ) call outpost(ue,ve,vx,pr,t,'   ')
      call sub3   (ud,ue,vx,n)
      call sub3   (vd,ve,vy,n)
      if (istep.eq.nsteps) call outpost(ud,vd,vx,pr,t,'   ')
      umx = glamax(vx,n)
      vmx = glamax(vy,n)
      uex = glamax(ue,n)
      vex = glamax(ve,n)
      udx = glamax(ud,n)
      vdx = glamax(vd,n)
      if (nid.eq.0) then
          write(6,11) istep,time,udx,umx,uex,u0,'  X err'
          write(6,11) istep,time,vdx,vmx,vex,v0,'  Y err'
   11     format(i5,1p5e14.6,a7)
      endif
      if (istep.le.5) then        !  Reset velocity to eliminate
         call copy (vx,ue,n)      !  start-up contributions to
         call copy (vy,ve,n)      !  temporal-accuracy behavior.
      endif
      return
      end
      subroutine userbc (ix,iy,iz,iside,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux = 1.0
      uy = 0.0
      temp = 0
      return
      end
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux = 1.0
      uy = 0.0
      temp = 0
      return
      end
      subroutine usrdat
      return
      end
      subroutine usrdat2
      return
      end
      subroutine usrdat3
      return
      end
C     Dimension file to be included
C
C     HCUBE array dimensions
C
      parameter (ldim=2)
      parameter (lx1=8,ly1=lx1,lz1=1,lelt=15,lelv=lelt)
      parameter (lxd=12,lyd=lxd,lzd=1)
      parameter (lelx=20,lely=20,lelz=1)
      parameter (lzl=3 + 2*(ldim-3))
      parameter (lx2=lx1-2)
      parameter (ly2=ly1-2)
      parameter (lz2=lz1  )
      parameter (lx3=lx1)
      parameter (ly3=ly1)
      parameter (lz3=lz1)
      parameter (lp = 512)
      parameter (lelg = 4100)
c
c     parameter (lpelv=lelv,lpelt=lelt,lpert=3)  ! perturbation
c     parameter (lpx1=lx1,lpy1=ly1,lpz1=lz1)     ! array sizes
c     parameter (lpx2=lx2,lpy2=ly2,lpz2=lz2)
c
      parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
      parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
      parameter (lpx2=1,lpy2=1,lpz2=1)
c
c     parameter (lbelv=lelv,lbelt=lelt)          ! MHD
c     parameter (lbx1=lx1,lby1=ly1,lbz1=lz1)     ! array sizes
c     parameter (lbx2=lx2,lby2=ly2,lbz2=lz2)
c
      parameter (lbelv=1,lbelt=1)                ! MHD
      parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
      parameter (lbx2=1,lby2=1,lbz2=1)
C     LX1M=LX1 when there are moving meshes; =1 otherwise
      parameter (lx1m=1,ly1m=1,lz1m=1)
      parameter (ldimt= 2)                       ! 2 passive scalars + T
      parameter (ldimt1=ldimt+1)
      parameter (ldimt3=ldimt+3)
c
c     Note:  In the new code, LELGEC should be about sqrt(LELG)
c
      PARAMETER (LELGEC = 1)
      PARAMETER (LXYZ2  = 1)
      PARAMETER (LXZ21  = 1)
      PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
      PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
      PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
      PARAMETER (LXZ=LX1*LZ1)
      PARAMETER (LORDER=3)
      PARAMETER (MAXOBJ=4,MAXMBR=LELT*6)
      PARAMETER (lhis=100)         ! # of pts a proc reads from hpts.in
                                   ! Note: lhis*np > npoints in hpts.in
C
C     Common Block Dimensions
C
      PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
      PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
C
C     The parameter LVEC controls whether an additional 42 field arrays
C     are required for Steady State Solutions.  If you are not using
C     Steady State, it is recommended that LVEC=1.
C
      PARAMETER (LVEC=1)
C
C     Uzawa projection array dimensions
C
      parameter (mxprev = 20)
      parameter (lgmres = 30)
C
C     Split projection array dimensions
C
      parameter(lmvec = 1)
      parameter(lsvec = 1)
      parameter(lstore=lmvec*lsvec)
c
c     NONCONFORMING STUFF
c
      parameter (maxmor = lelt)
C
C     Array dimensions
C
      COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
     $,NX3,NY3,NZ3,NDIM,NFIELD,NPERT,NID
     $,NXD,NYD,NZD
c automatically added by makenek
      parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
      parameter(lpart = 1  ) ! max number of particles
      integer ax1,ay1,az1,ax2,ay2,az2
      parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) ! running averages
      parameter (lxs=1,lys=lxs,lzs=(lxs-1)*(ldim-2)+1) !New Pressure Preconditioner
      parameter (lfdm=0)  ! == 1 for fast diagonalization method
            2 DIMENSIONAL RUN
   1.00000         p1  DENSITY
  -20.0000         p2  VISCOS
   0.
   0.
   0.
   0.
   1.00000         p7  RHOCP
   1.00000         p8  CONDUCT
   0.
   0.              p10 FINTIME
   1000.0          p11 NSTEPS
   0.              p13 IOCOMM
   0.              p14 IOTIME
   100.000         p15 IOSTEP
   0.              p16 PSSOLVER
   0.
  -1.00000         p19 INTYPE
   12.0000         p20 NORDER
   0.              p23 NPSCAL
   3.00000         p27 TORDER
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.              p46 reserved
   0.
   0.
   0.
   0.
   0.              p52 IOHIS
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.               p86 reserved
   0.
   0.
   0.
   0.
   0.
   0.
   0.
   0.
  T     IFFLOW
  F     IFHEAT
  T     IFTRAN
  F     IFAXIS
  F     IFSTRS
  F     IFSPLIT
  F     IFMGRID
  F     IFMODEL
  F     IFKEPS
  F     IFMVBD
  F     IFCHAR
