[Nek5000-users] The first time step in a Nek file must contain a mesh error
Fri Jan 10 04:00:43 CST 2014
Hi
  Thanks a lot for the reply and it worked.
I have couple of more questions
1) How can I create a .rea for a specific geometry say ' A sudden
expansion pipe ' or a ' Diverging pipe '
2) What tool I should use to create that mesh.
Thank you
On 09/01/2014 23:31, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Kamal,
> It looks like your metadata file for Visit needs to be changed to:
> filetemplate:  helix%01d.f%05d
> This should result in the example working as expected.  You can check
> that the helix0.f000001 file has the mesh by:
> head -1 helix0.f00001 |strings
> There should be an 'X' in the alpha-character line that signifies the
> xyz data is found in that file.
> On Thu, Jan 9, 2014 at 10:26 AM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hello,
>     I am using VisIT for nek5000, I tried some of the tutorials from
>     Nek5000.
>     I was able to launch and create the metadata file for Eddy_uv example.
>     I tried to do the same for the Helix Pipe example but when I
>     loaded the metadata file into VisIT, I got an error saying  " The
>     first time step in a Nek file must contain a mesh "
>     This is my metadata file for the pipe helix example
>     NEK5000
>     version: 1.0
>     helix.rea
>     filetemplate:  helix0.f%05d
>     firsttimestep: 1
>     numtimesteps: 1
>     Can some one tell me how to add mesh to the first time step.
>     Thank you,
>     Kamal
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140110/01af9e1d/attachment.html>
