[Nek5000-users] The first time step in a Nek file must contain a mesh error
Thu Jan 9 16:31:29 CST 2014
Hi Kamal,
It looks like your metadata file for Visit needs to be changed to:
filetemplate:  helix%01d.f%05d
This should result in the example working as expected.  You can check that
the helix0.f000001 file has the mesh by:
head -1 helix0.f00001 |strings
There should be an 'X' in the alpha-character line that signifies the xyz
data is found in that file.
On Thu, Jan 9, 2014 at 10:26 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello,
> I am using VisIT for nek5000, I tried some of the tutorials from Nek5000.
> I was able to launch and create the metadata file for Eddy_uv example.
> I tried to do the same for the Helix Pipe example but when I loaded the
> metadata file into VisIT, I got an error saying  " The first time step in a
> Nek file must contain a mesh "
> This is my metadata file for the pipe helix example
> NEK5000
> version: 1.0
> helix.rea
> filetemplate:  helix0.f%05d
> firsttimestep: 1
> numtimesteps: 1
> Can some one tell me how to add mesh to the first time step.
> Thank you,
> Kamal
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140109/672de33b/attachment.html>
