[Nek5000-users] Segmentation Error
Fri Feb 21 12:12:00 CST 2014
Hi Neks,
I have a setobj() subroutine which defines my wall surface of integral,
This subroutine worked well on my local machine for a smaller mesh.
Recently I launched a simulation with a big mesh, I found that using the
setobj() subroutine gives a error which something looks like this, I
have attached the complete error file with this mail along with logfile
and .usr file.
could some tell me what is going wrong ?
[lomc-itp-43:15165] *** Process received signal ***
[lomc-itp-43:15159] *** Process received signal ***
[lomc-itp-43:15159] Signal: Segmentation fault (11)
[lomc-itp-43:15159] Signal code: Address not mapped (1)
[lomc-itp-43:15159] Failing at address: (nil)
[lomc-itp-43:15164] *** Process received signal ***
[lomc-itp-43:15160] *** Process received signal ***
[lomc-itp-43:15160] Signal: Segmentation fault (11)
[lomc-itp-43:15160] Signal code: Address not mapped (1)
[lomc-itp-43:15160] Failing at address: (nil)
[lomc-itp-43:15162] *** Process received signal ***
[lomc-itp-43:15162] Signal: Segmentation fault (11)
[lomc-itp-43:15162] Signal code: Address not mapped (1)
[lomc-itp-43:15162] Failing at address: (nil)
[lomc-itp-43:15163] *** Process received signal ***
[lomc-itp-43:15163] Signal: Segmentation fault (11)
[lomc-itp-43:15163] Signal code: Address not mapped (1)
[lomc-itp-43:15163] Failing at address: (nil)
[lomc-itp-43:15164] Signal: Segmentation fault (11)
[lomc-itp-43:15164] Signal code: Address not mapped (1)
[lomc-itp-43:15164] Failing at address: (nil)
Kamal
c-----------------------------------------------------------------------
C
C  USER SPECIFIED ROUTINES:
C
C     - boundary conditions
C     - initial conditions
C     - variable properties
C     - local acceleration for fluid (a)
C     - forcing function for passive scalar (q)
C     - general purpose routine for checking errors etc.
C
      subroutine uservp (ix,iy,iz,eg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,f,eg
c     e = gllel(eg)
      udiff =0.
      utrans=0.
      return
      end
      subroutine userf  (ix,iy,iz,eg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,f,eg
c     e = gllel(eg)
c     Note: this is an acceleration term, NOT a force!
c     Thus, ffx will subsequently be multiplied by rho(x,t).
      ffx = 0.0
      ffy = 0.0
      ffz = 0.0
      return
      end
      subroutine userq  (ix,iy,iz,eg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,f,eg
c     e = gllel(eg)
      qvol   = 0.0
      source = 0.0
      return
      end
      subroutine userchk
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      parameter (lt=lx1*ly1*lz1*lelt)
      common /myjunk/ vort(lt,3),w1(lt),w2(lt)
      common /Residual_arrays/ uo(lt), vo(lt), wo(lt)
      real h1, semi, l2, linf, residu
      if (mod(istep,iostep).eq.0) then
         call comp_vort3(vort,w1,w2,vx,vy,vz)
         call outpost(vort(1,1),vort(1,2),vort(1,3),pr,t,'vrt')
      end if
      if(istep.eq.0) then
         call set_obj
         call rzero(x0,3)
      end if
      if (mod(istep,2).eq.0) call torque_calc(1.0,x0,.true.,.true.)
      call opsub2(uo,vo,wo,vx,vy,vz)
      call normvc(h1,semi,l2,linf,uo,vo,wo)
      residu = l2/dt
      call opcopy(uo,vo,wo,vx,vy,vz)
      if(istep.eq.0) then
        if(nid.eq.0) open(unit=10,file='residu.dat')
      endif
      if(nid.eq.0) write(10,*) istep, residu
      if(istep.eq.nsteps) then
           if(nid.eq.0) close(10)
      end if
      if((istep.gt.10).AND.(residu.lt.1e-8)) then
          call outpost(vx,vy,vz,pr,t,'BF_')
       call exitt
      endif
c
      ifxyo = .true.
      if (iostep.gt.0.and.istep.gt.iostep) ifxyo = .false.
      return
      end
      subroutine userbc (ix,iy,iz,iside,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,eg
      common /mygeom/ xmin,xmax,ymin,ymax
      delta = 1
      if (z.le.0) delta = 0.5
      xd=x/delta
      yd=y/delta
      rr=xd*xd+yd*yd
      scale = 2*(0.5/delta)**2  ! Ubar = 1 in inlet pipe (r=0.5)
      ux=0.0
      uy=0.0
      uz=scale*(1-rr)
      temp=0.0
      return
      end
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,eg
      delta = 1
      xd=x/delta
      yd=y/delta
      rr=xd*xd+yd*yd
      ux=0.0
      uy=0.0
      uz=scale*(1-rr)
      temp=0.0
      return
      end
      subroutine usrdat
      include 'SIZE'
      include 'TOTAL'
c
      return
      end
      subroutine usrdat3
      include 'SIZE'
      include 'TOTAL'
c
      return
      end
      subroutine usrdat2  !  Modify geometry
      include 'SIZE'
      include 'TOTAL'
      n = nx1*ny1*nz1*nelt
      scal = 0.5 ! Rescale radius from 1.0 to 0.5
      call cmult(xm1,scal,n)
      call cmult(ym1,scal,n)
      xmin = glmin(xm1,n)
      ymin = glmin(ym1,n)
      xmax = glmax(xm1,n)
      ymax = glmax(ym1,n)
      smax = 2.0
      z0 = 0.
      z1 = 1.
      do i=1,n
        x = xm1(i,1,1,1)
        y = ym1(i,1,1,1)
        z = zm1(i,1,1,1)
        scale = 1.
        if (z.gt.z0) scale = 1 + (smax-1)*(z-z0)/(z1-z0)
        if (z.gt.z1) scale = smax
        xm1(i,1,1,1) = scale*x
        ym1(i,1,1,1) = scale*y
      enddo
      param(59) = 1         ! Force ifdfrm=.true. ( 8/26/03 )
      ifxyo     = .true.
c     call outpost(xm1,ym1,zm1,pr,t,'   ')
c     call exitt
      return
      end
      subroutine set_obj  ! define objects for surface integrals
c
      include 'SIZE'
      include 'TOTAL'
c
      integer e,f
c
c     Define new objects
c
      nobj = 1			! for Periodic
      iobj = 0
      do ii=nhis+1,nhis+nobj
         iobj = iobj+1
         hcode(10,ii) = 'I'
         hcode( 1,ii) = 'F' ! 'F'
         hcode( 2,ii) = 'F' ! 'F'
         hcode( 3,ii) = 'F' ! 'F'
         lochis(1,ii) = iobj
      enddo
      nhis = nhis + nobj
c
      if (maxobj.lt.nobj) write(6,*) 'increase maxobj in SIZEu. rm *.o'
      if (maxobj.lt.nobj) call exitt
c
      nxyz = nx1*ny1*nz1
      do e=1,nelv
      do f=1,2*ndim
         if (cbc(f,e,1).eq.'W  ') then
            iobj = 1
            if (iobj.gt.0) then
               nmember(iobj) = nmember(iobj) + 1
               mem = nmember(iobj)
               ieg = lglel(e)
               object(iobj,mem,1) = ieg
               object(iobj,mem,2) = f
c               write(6,1) iobj,mem,f,ieg,e,nid,' OBJ'
    1          format(6i9,a4)
            endif
c
         endif
      enddo
      enddo
      write(6,*) 'number',(nmember(k),k=1,4)
c
      return
      end
|      _   __ ______ __ __  ______  ____    ____    ____   |
|     / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
|    /  |/ // __/  / ,<   /___ \\  / / / // / / // / / /   |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \\____/ \\____/ \\____/   |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
| Version:  1.0rc1 / SVN  r996                             |
| Web:      http://nek5000.mcs.anl.gov                     |
 Number of processors:           8
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
  Beginning session:
  /home/kamal/neksamples/pipe2000/divpipe.rea
 timer accuracy:   0.0000000E+00 sec
 read .rea file
 nelgt/nelgv/lelt:       25200       25200        3200
 lx1  /lx2  /lx3 :           5           5           5
 mapping elements to processors
           7        3150        3150       25200       25200  NELV
           0        3150        3150       25200       25200  NELV
           2        3150        3150       25200       25200  NELV
           4        3150        3150       25200       25200  NELV
           6        3150        3150       25200       25200  NELV
           1        3150        3150       25200       25200  NELV
           3        3150        3150       25200       25200  NELV
           5        3150        3150       25200       25200  NELV
 RANK     0 IEG   22005   22006   22007   22008   22010   22012   22014   22016
                  22025   22026   22033   22034   22036   22037   22045   22046
                  22047   22048   22051   22052   22054   22056   22061   22066
                  22067   22068   22071   22072   22074   22076   22081   22082
                  22083   22084   22085   22086   22087   22088   22089   22090
                  22091   22092   22093   22094   22095   22096   22097   22098
                  22099   22100   22101   22102   22103   22104   22105   22106
                  22107   22108   22109   22110   22111   22112   22113   22114
                  22115   22116   22117   22118   22119   22120   22121   22122
                  22123   22124   22125   22126   22127   22128   22129   22130
                  22131   22132   22133   22134   22135   22136   22137   22138
                  22139   22140   22141   22142   22143   22144   22145   22146
                  22147   22148   22149   22150   22151   22152   22153   22154
                  22155   22156   22157   22158   22159   22160   22161   22162
                  22163   22164   22165   22166   22167   22168   22169   22170
                  22171   22172   22173   22174   22175   22176   22177   22178
                  22179   22180   22181   22182   22183   22184   22185   22186
                  22187   22188   22189   22190   22191   22192   22193   22194
                  22195   22196   22197   22198   22199   22200   22201   22202
                  22203   22204   22205   22206   22207   22208   22209   22210
                  22211   22212   22213   22214   22215   22216   22217   22218
                  22219   22220   22221   22222   22223   22224   22225   22226
                  22227   22228   22229   22230   22231   22232   22233   22234
                  22235   22236   22237   22238   22239   22240   22241   22242
                  22243   22244   22245   22246   22247   22248   22249   22250
                  22251   22252   22253   22254   22255   22256   22257   22258
                  22259   22260   22261   22262   22263   22264   22265   22266
                  22267   22268   22269   22270   22271   22272   22273   22274
                  22275   22276   22277   22278   22279   22280   22281   22282
                  22283   22284   22285   22286   22287   22288   22289   22290
                  22291   22292   22293   22294   22295   22296   22297   22298
                  22299   22300   22301   22302   22303   22304   22305   22306
                  22307   22308   22309   22310   22311   22312   22313   22314
                  22315   22316   22317   22318   22319   22320   22321   22322
                  22323   22324   22325   22326   22327   22328   22329   22330
                  22331   22332   22333   22334   22335   22336   22337   22338
                  22339   22340   22341   22342   22343   22344   22345   22346
                  22347   22348   22349   22350   22351   22352   22353   22354
                  22355   22356   22357   22358   22359   22360   22361   22362
                  22363   22364   22365   22366   22367   22368   22369   22370
                  22371   22372   22373   22374   22375   22376   22377   22378
                  22379   22380   22381   22382   22383   22384   22385   22386
                  22387   22388   22389   22390   22391   22392   22393   22394
                  22395   22396   22397   22398   22399   22400   22401   22402
                  22403   22404   22405   22406   22407   22408   22409   22410
                  22411   22412   22413   22414   22415   22416   22417   22418
                  22419   22420   22421   22422   22423   22424   22425   22426
                  22427   22428   22429   22430   22431   22432   22433   22434
                  22435   22436   22437   22438   22439   22440   22441   22442
                  22443   22444   22445   22446   22447   22448   22449   22450
                  22451   22452   22453   22454   22455   22456   22457   22458
                  22459   22460   22461   22462   22463   22464   22465   22466
                  22467   22468   22469   22470   22471   22472   22473   22474
                  22475   22476   22477   22478   22479   22480   22481   22482
                  22483   22484   22485   22486   22487   22488   22489   22490
                  22491   22492   22493   22494   22495   22496   22497   22498
                  22499   22500   22501   22502   22503   22504   22505   22506
                  22507   22508   22509   22510   22511   22512   22513   22514
                  22515   22516   22517   22518   22519   22520   22521   22522
                  22523   22524   22525   22526   22527   22528   22529   22530
                  22531   22532   22533   22534   22535   22536   22537   22538
                  22539   22540   22541   22542   22543   22544   22545   22546
                  22547   22548   22549   22550   22551   22552   22553   22554
                  22555   22556   22557   22558   22559   22560   22561   22562
                  22563   22564   22565   22566   22567   22568   22569   22570
                  22571   22572   22573   22574   22575   22576   22577   22578
                  22579   22580   22581   22582   22583   22584   22585   22586
                  22587   22588   22589   22590   22591   22592   22593   22594
                  22595   22596   22597   22598   22599   22600   22601   22602
                  22603   22604   22605   22606   22607   22608   22609   22610
                  22611   22612   22613   22614   22615   22616   22617   22618
                  22619   22620   22621   22622   22623   22624   22625   22626
                  22627   22628   22629   22630   22631   22632   22633   22634
                  22635   22636   22637   22638   22639   22640   22641   22642
                  22643   22644   22645   22646   22647   22648   22649   22650
                  22651   22652   22653   22654   22655   22656   22657   22658
                  22659   22660   22661   22662   22663   22664   22665   22666
                  22667   22668   22669   22670   22671   22672   22673   22674
                  22675   22676   22677   22678   22679   22680   22681   22682
                  22683   22684   22685   22686   22687   22688   22689   22690
                  22691   22692   22693   22694   22695   22696   22697   22698
                  22699   22700   22701   22702   22703   22704   22705   22706
                  22707   22708   22709   22710   22711   22712   22713   22714
                  22715   22716   22717   22718   22719   22720   22721   22722
                  22723   22724   22725   22726   22727   22728   22729   22730
                  22731   22732   22733   22734   22735   22736   22737   22738
                  22739   22740   22741   22742   22743   22744   22745   22746
                  22747   22748   22749   22750   22751   22752   22753   22754
                  22755   22756   22757   22758   22759   22760   22761   22762
                  22763   22764   22765   22766   22767   22768   22769   22770
                  22771   22772   22773   22774   22775   22776   22777   22778
                  22779   22780   22781   22782   22783   22784   22785   22786
                  22787   22788   22789   22790   22791   22792   22793   22794
                  22795   22796   22797   22798   22799   22800   22801   22802
                  22803   22804   22805   22806   22807   22808   22809   22810
                  22811   22812   22813   22814   22815   22816   22817   22818
                  22819   22820   22821   22822   22823   22824   22825   22826
                  22827   22828   22829   22830   22831   22832   22833   22834
                  22835   22836   22837   22838   22839   22840   22841   22842
                  22843   22844   22845   22846   22847   22848   22849   22850
                  22851   22852   22853   22854   22855   22856   22857   22858
                  22859   22860   22861   22862   22863   22864   22865   22866
                  22867   22868   22869   22870   22871   22872   22873   22874
                  22875   22876   22877   22878   22879   22880   22881   22882
                  22883   22884   22885   22886   22887   22888   22889   22890
                  22891   22892   22893   22894   22895   22896   22897   22898
                  22899   22900   22901   22902   22903   22904   22905   22906
                  22907   22908   22909   22910   22911   22912   22913   22914
                  22915   22916   22917   22918   22919   22920   22921   22922
                  22923   22924   22925   22926   22927   22928   22929   22930
                  22931   22932   22933   22934   22935   22936   22937   22938
                  22939   22940   22941   22942   22943   22944   22945   22946
                  22947   22948   22949   22950   22951   22952   22953   22954
                  22955   22956   22957   22958   22959   22960   22961   22962
                  22963   22964   22965   22966   22967   22968   22969   22970
                  22971   22972   22973   22974   22975   22976   22977   22978
                  22979   22980   22981   22982   22983   22984   22985   22986
                  22987   22988   22989   22990   22991   22992   22993   22994
                  22995   22996   22997   22998   22999   23000   23001   23002
                  23003   23004   23005   23006   23007   23008   23009   23010
                  23011   23012   23013   23014   23015   23016   23017   23018
                  23019   23020   23021   23022   23023   23024   23025   23026
                  23027   23028   23029   23030   23031   23032   23033   23034
                  23035   23036   23037   23038   23039   23040   23041   23042
                  23043   23044   23045   23046   23047   23048   23049   23050
                  23051   23052   23053   23054   23055   23056   23057   23058
                  23059   23060   23061   23062   23063   23064   23065   23066
                  23067   23068   23069   23070   23071   23072   23073   23074
                  23075   23076   23077   23078   23079   23080   23081   23082
                  23083   23084   23085   23086   23087   23088   23089   23090
                  23091   23092   23093   23094   23095   23096   23097   23098
                  23099   23100   23101   23102   23103   23104   23105   23106
                  23107   23108   23109   23110   23111   23112   23113   23114
                  23115   23116   23117   23118   23119   23120   23121   23122
                  23123   23124   23125   23126   23127   23128   23129   23130
                  23131   23132   23133   23134   23135   23136   23137   23138
                  23139   23140   23141   23142   23143   23144   23145   23146
                  23147   23148   23149   23150   23151   23152   23153   23154
                  23155   23156   23157   23158   23159   23160   23161   23162
                  23163   23164   23165   23166   23167   23168   23169   23170
                  23171   23172   23173   23174   23175   23176   23177   23178
                  23179   23180   23181   23182   23183   23184   23185   23186
                  23187   23188   23189   23190   23191   23192   23193   23194
                  23195   23196   23197   23198   23199   23200   23201   23202
                  23203   23204   23205   23206   23207   23208   23209   23210
                  23211   23212   23213   23214   23215   23216   23217   23218
                  23219   23220   23221   23222   23223   23224   23225   23226
                  23227   23228   23229   23230   23231   23232   23233   23234
                  23235   23236   23237   23238   23239   23240   23241   23242
                  23243   23244   23245   23246   23247   23248   23249   23250
                  23251   23252   23253   23254   23255   23256   23257   23258
                  23259   23260   23261   23262   23263   23264   23265   23266
                  23267   23268   23269   23270   23271   23272   23273   23274
                  23275   23276   23277   23278   23279   23280   23281   23282
                  23283   23284   23285   23286   23287   23288   23289   23290
                  23291   23292   23293   23294   23295   23296   23297   23298
                  23299   23300   23301   23302   23303   23304   23305   23306
                  23307   23308   23309   23310   23311   23312   23313   23314
                  23315   23316   23317   23318   23319   23320   23321   23322
                  23323   23324   23325   23326   23327   23328   23329   23330
                  23331   23332   23333   23334   23335   23336   23337   23338
                  23339   23340   23341   23342   23343   23344   23345   23346
                  23347   23348   23349   23350   23351   23352   23353   23354
                  23355   23356   23357   23358   23359   23360   23361   23362
                  23363   23364   23365   23366   23367   23368   23369   23370
                  23371   23372   23373   23374   23375   23376   23377   23378
                  23379   23380   23381   23382   23383   23384   23385   23386
                  23387   23388   23389   23390   23391   23392   23393   23394
                  23395   23396   23397   23398   23399   23400   23401   23402
                  23403   23404   23405   23406   23407   23408   23409   23410
                  23411   23412   23413   23414   23415   23416   23417   23418
                  23419   23420   23421   23422   23423   23424   23425   23426
                  23427   23428   23429   23430   23431   23432   23433   23434
                  23435   23436   23437   23438   23439   23440   23441   23442
                  23443   23444   23445   23446   23447   23448   23449   23450
                  23451   23452   23453   23454   23455   23456   23457   23458
                  23459   23460   23461   23462   23463   23464   23465   23466
                  23467   23468   23469   23470   23471   23472   23473   23474
                  23475   23476   23477   23478   23479   23480   23481   23482
                  23483   23484   23485   23486   23487   23488   23489   23490
                  23491   23492   23493   23494   23495   23496   23497   23498
                  23499   23500   23501   23502   23503   23504   23505   23506
                  23507   23508   23509   23510   23511   23512   23513   23514
                  23515   23516   23517   23518   23519   23520   23521   23522
                  23523   23524   23525   23526   23527   23528   23529   23530
                  23531   23532   23533   23534   23535   23536   23537   23538
                  23539   23540   23541   23542   23543   23544   23545   23546
                  23547   23548   23549   23550   23551   23552   23553   23554
                  23555   23556   23557   23558   23559   23560   23561   23562
                  23563   23564   23565   23566   23567   23568   23569   23570
                  23571   23572   23573   23574   23575   23576   23577   23578
                  23579   23580   23581   23582   23583   23584   23585   23586
                  23587   23588   23589   23590   23591   23592   23593   23594
                  23595   23596   23597   23598   23599   23600   23601   23602
                  23603   23604   23605   23606   23607   23608   23609   23610
                  23611   23612   23613   23614   23615   23616   23617   23618
                  23619   23620   23621   23622   23623   23624   23625   23626
                  23627   23628   23629   23630   23631   23632   23633   23634
                  23635   23636   23637   23638   23639   23640   23641   23642
                  23643   23644   23645   23646   23647   23648   23649   23650
                  23651   23652   23653   23654   23655   23656   23657   23658
                  23659   23660   23661   23662   23663   23664   23665   23666
                  23667   23668   23669   23670   23671   23672   23673   23674
                  23675   23676   23677   23678   23679   23680   23681   23682
                  23683   23684   23685   23686   23687   23688   23689   23690
                  23691   23692   23693   23694   23695   23696   23697   23698
                  23699   23700   23701   23702   23703   23704   23705   23706
                  23707   23708   23709   23710   23711   23712   23713   23714
                  23715   23716   23717   23718   23719   23720   23721   23722
                  23723   23724   23725   23726   23727   23728   23729   23730
                  23731   23732   23733   23734   23735   23736   23737   23738
                  23739   23740   23741   23742   23743   23744   23745   23746
                  23747   23748   23749   23750   23751   23752   23753   23754
                  23755   23756   23757   23758   23759   23760   23761   23762
                  23763   23764   23765   23766   23767   23768   23769   23770
                  23771   23772   23773   23774   23775   23776   23777   23778
                  23779   23780   23781   23782   23783   23784   23785   23786
                  23787   23788   23789   23790   23791   23792   23793   23794
                  23795   23796   23797   23798   23799   23800   23801   23802
                  23803   23804   23805   23806   23807   23808   23809   23810
                  23811   23812   23813   23814   23815   23816   23817   23818
                  23819   23820   23821   23822   23823   23824   23825   23826
                  23827   23828   23829   23830   23831   23832   23833   23834
                  23835   23836   23837   23838   23839   23840   23841   23842
                  23843   23844   23845   23846   23847   23848   23849   23850
                  23851   23852   23853   23854   23855   23856   23857   23858
                  23859   23860   23861   23862   23863   23864   23865   23866
                  23867   23868   23869   23870   23871   23872   23873   23874
                  23875   23876   23877   23878   23879   23880   23881   23882
                  23883   23884   23885   23886   23887   23888   23889   23890
                  23891   23892   23893   23894   23895   23896   23897   23898
                  23899   23900   23901   23902   23903   23904   23905   23906
                  23907   23908   23909   23910   23911   23912   23913   23914
                  23915   23916   23917   23918   23919   23920   23921   23922
                  23923   23924   23925   23926   23927   23928   23929   23930
                  23931   23932   23933   23934   23935   23936   23937   23938
                  23939   23940   23941   23942   23943   23944   23945   23946
                  23947   23948   23949   23950   23951   23952   23953   23954
                  23955   23956   23957   23958   23959   23960   23961   23962
                  23963   23964   23965   23966   23967   23968   23969   23970
                  23971   23972   23973   23974   23975   23976   23977   23978
                  23979   23980   23981   23982   23983   23984   23985   23986
                  23987   23988   23989   23990   23991   23992   23993   23994
                  23995   23996   23997   23998   23999   24000   24001   24002
                  24003   24004   24005   24006   24007   24008   24009   24010
                  24011   24012   24013   24014   24015   24016   24017   24018
                  24019   24020   24021   24022   24023   24024   24025   24026
                  24027   24028   24029   24030   24031   24032   24033   24034
                  24035   24036   24037   24038   24039   24040   24041   24042
                  24043   24044   24045   24046   24047   24048   24049   24050
                  24051   24052   24053   24054   24055   24056   24057   24058
                  24059   24060   24061   24062   24063   24064   24065   24066
                  24067   24068   24069   24070   24071   24072   24073   24074
                  24075   24076   24077   24078   24079   24080   24081   24082
                  24083   24084   24085   24086   24087   24088   24089   24090
                  24091   24092   24093   24094   24095   24096   24097   24098
                  24099   24100   24101   24102   24103   24104   24105   24106
                  24107   24108   24109   24110   24111   24112   24113   24114
                  24115   24116   24117   24118   24119   24120   24121   24122
                  24123   24124   24125   24126   24127   24128   24129   24130
                  24131   24132   24133   24134   24135   24136   24137   24138
                  24139   24140   24141   24142   24143   24144   24145   24146
                  24147   24148   24149   24150   24151   24152   24153   24154
                  24155   24156   24157   24158   24159   24160   24161   24162
                  24163   24164   24165   24166   24167   24168   24169   24170
                  24171   24172   24173   24174   24175   24176   24177   24178
                  24179   24180   24181   24182   24183   24184   24185   24186
                  24187   24188   24189   24190   24191   24192   24193   24194
                  24195   24196   24197   24198   24199   24200   24201   24202
                  24203   24204   24205   24206   24207   24208   24209   24210
                  24211   24212   24213   24214   24215   24216   24217   24218
                  24219   24220   24221   24222   24223   24224   24225   24226
                  24227   24228   24229   24230   24231   24232   24233   24234
                  24235   24236   24237   24238   24239   24240   24241   24242
                  24243   24244   24245   24246   24247   24248   24249   24250
                  24251   24252   24253   24254   24255   24256   24257   24258
                  24259   24260   24261   24262   24263   24264   24265   24266
                  24267   24268   24269   24270   24271   24272   24273   24274
                  24275   24276   24277   24278   24279   24280   24281   24282
                  24283   24284   24285   24286   24287   24288   24289   24290
                  24291   24292   24293   24294   24295   24296   24297   24298
                  24299   24300   24301   24302   24303   24304   24305   24306
                  24307   24308   24309   24310   24311   24312   24313   24314
                  24315   24316   24317   24318   24319   24320   24321   24322
                  24323   24324   24325   24326   24327   24328   24329   24330
                  24331   24332   24333   24334   24335   24336   24337   24338
                  24339   24340   24341   24342   24343   24344   24345   24346
                  24347   24348   24349   24350   24351   24352   24353   24354
                  24355   24356   24357   24358   24359   24360   24361   24362
                  24363   24364   24365   24366   24367   24368   24369   24370
                  24371   24372   24373   24374   24375   24376   24377   24378
                  24379   24380   24381   24382   24383   24384   24385   24386
                  24387   24388   24389   24390   24391   24392   24393   24394
                  24395   24396   24397   24398   24399   24400   24401   24402
                  24403   24404   24405   24406   24407   24408   24409   24410
                  24411   24412   24413   24414   24415   24416   24417   24418
                  24419   24420   24421   24422   24423   24424   24425   24426
                  24427   24428   24429   24430   24431   24432   24433   24434
                  24435   24436   24437   24438   24439   24440   24441   24442
                  24443   24444   24445   24446   24447   24448   24449   24450
                  24451   24452   24453   24454   24455   24456   24457   24458
                  24459   24460   24461   24462   24463   24464   24465   24466
                  24467   24468   24469   24470   24471   24472   24473   24474
                  24475   24476   24477   24478   24479   24480   24481   24482
                  24483   24484   24485   24486   24487   24488   24489   24490
                  24491   24492   24493   24494   24495   24496   24497   24498
                  24499   24500   24501   24502   24503   24504   24505   24506
                  24507   24508   24509   24510   24511   24512   24513   24514
                  24515   24516   24517   24518   24519   24520   24521   24522
                  24523   24524   24525   24526   24527   24528   24529   24530
                  24531   24532   24533   24534   24535   24536   24537   24538
                  24539   24540   24541   24542   24543   24544   24545   24546
                  24547   24548   24549   24550   24551   24552   24553   24554
                  24555   24556   24557   24558   24559   24560   24561   24562
                  24563   24564   24565   24566   24567   24568   24569   24570
                  24571   24572   24573   24574   24575   24576   24577   24578
                  24579   24580   24581   24582   24583   24584   24585   24586
                  24587   24588   24589   24590   24591   24592   24593   24594
                  24595   24596   24597   24598   24599   24600   24601   24602
                  24603   24604   24605   24606   24607   24608   24609   24610
                  24611   24612   24613   24614   24615   24616   24617   24618
                  24619   24620   24621   24622   24623   24624   24625   24626
                  24627   24628   24629   24630   24631   24632   24633   24634
                  24635   24636   24637   24638   24639   24640   24641   24642
                  24643   24644   24645   24646   24647   24648   24649   24650
                  24651   24652   24653   24654   24655   24656   24657   24658
                  24659   24660   24661   24662   24663   24664   24665   24666
                  24667   24668   24669   24670   24671   24672   24673   24674
                  24675   24676   24677   24678   24679   24680   24681   24682
                  24683   24684   24685   24686   24687   24688   24689   24690
                  24691   24692   24693   24694   24695   24696   24697   24698
                  24699   24700   24701   24702   24703   24704   24705   24706
                  24707   24708   24709   24710   24711   24712   24713   24714
                  24715   24716   24717   24718   24719   24720   24721   24722
                  24723   24724   24725   24726   24727   24728   24729   24730
                  24731   24732   24733   24734   24735   24736   24737   24738
                  24739   24740   24741   24742   24743   24744   24745   24746
                  24747   24748   24749   24750   24751   24752   24753   24754
                  24755   24756   24757   24758   24759   24760   24761   24762
                  24763   24764   24765   24766   24767   24768   24769   24770
                  24771   24772   24773   24774   24775   24776   24777   24778
                  24779   24780   24781   24782   24783   24784   24785   24786
                  24787   24788   24789   24790   24791   24792   24793   24794
                  24795   24796   24797   24798   24799   24800   24801   24802
                  24803   24804   24805   24806   24807   24808   24809   24810
                  24811   24812   24813   24814   24815   24816   24817   24818
                  24819   24820   24821   24822   24823   24824   24825   24826
                  24827   24828   24829   24830   24831   24832   24833   24834
                  24835   24836   24837   24838   24839   24840   24841   24842
                  24843   24844   24845   24846   24847   24848   24849   24850
                  24851   24852   24853   24854   24855   24856   24857   24858
                  24859   24860   24861   24862   24863   24864   24865   24866
                  24867   24868   24869   24870   24871   24872   24873   24874
                  24875   24876   24877   24878   24879   24880   24881   24882
                  24883   24884   24885   24886   24887   24888   24889   24890
                  24891   24892   24893   24894   24895   24896   24897   24898
                  24899   24900   24901   24902   24903   24904   24905   24906
                  24907   24908   24909   24910   24911   24912   24913   24914
                  24915   24916   24917   24918   24919   24920   24921   24922
                  24923   24924   24925   24926   24927   24928   24929   24930
                  24931   24932   24933   24934   24935   24936   24937   24938
                  24939   24940   24941   24942   24943   24944   24945   24946
                  24947   24948   24949   24950   24951   24952   24953   24954
                  24955   24956   24957   24958   24959   24960   24961   24962
                  24963   24964   24965   24966   24967   24968   24969   24970
                  24971   24972   24973   24974   24975   24976   24977   24978
                  24979   24980   24981   24982   24983   24984   24985   24986
                  24987   24988   24989   24990   24991   24992   24993   24994
                  24995   24996   24997   24998   24999   25000   25001   25002
                  25003   25004   25005   25006   25007   25008   25009   25010
                  25011   25012   25013   25014   25015   25016   25017   25018
                  25019   25020   25021   25022   25023   25024   25025   25026
                  25027   25028   25029   25030   25031   25032   25033   25034
                  25035   25036   25037   25038   25039   25040   25041   25042
                  25043   25044   25045   25046   25047   25048   25049   25050
                  25051   25052   25053   25054   25055   25056   25057   25058
                  25059   25060   25061   25062   25063   25064   25065   25066
                  25067   25068   25069   25070   25071   25072   25073   25074
                  25075   25076   25077   25078   25079   25080   25081   25082
                  25083   25084   25085   25086   25087   25088   25089   25090
                  25091   25092   25093   25094   25095   25096   25097   25098
                  25099   25100   25101   25102   25103   25104   25105   25106
                  25107   25108   25109   25110   25111   25112   25113   25114
                  25115   25116   25117   25118   25119   25120   25121   25122
                  25123   25124   25125   25126   25127   25128   25129   25130
                  25131   25132   25133   25134   25135   25136   25137   25138
                  25139   25140   25141   25142   25143   25144   25145   25146
                  25147   25148   25149   25150   25151   25152   25153   25154
                  25155   25156   25157   25158   25159   25160   25161   25162
                  25163   25164   25165   25166   25167   25168   25169   25170
                  25171   25172   25173   25174   25175   25176   25177   25178
                  25179   25180   25181   25182   25183   25184   25185   25186
                  25187   25188   25189   25190   25191   25192   25193   25194
                  25195   25196   25197   25198   25199   25200
 element load imbalance:            0        3150        3150
 done :: mapping elements to processors
           0  objects found
 done :: read .rea file   0.70946     sec
 Reset the target Courant number to .5
 setup mesh topology
   Right-handed check complete for   25200 elements. OK.
   setvert3d:   5      975293     1655693      975293      975293
 call usrsetvert
 done :: usrsetvert
gs_setup: 11763 unique labels shared
   pairwise times (avg, min, max): 1.16765e-05 1.11103e-05 1.24931e-05
   crystal router                : 3.6639e-05 3.60012e-05 3.76225e-05
   all reduce                    : 0.00013693 0.00013659 0.000137186
   used all_to_all method: pairwise
   handle bytes (avg, min, max): 3.4036e+06 3375444 3417612
   buffer bytes (avg, min, max): 47052 25616 59104
   setupds time 3.2100E-01 seconds   0  5      975293       25200
           8  max multiplicity
 done :: setup mesh topology
 call usrdat
 done :: usrdat
 generate geometry data
 vol_t,vol_v:   486.94699737572313        486.94699737572313
 done :: generate geometry data
 call usrdat2
 done :: usrdat2
 regenerate geometry data           1
 vol_t,vol_v:   473.85702446339303        473.85702446339303
 NOTE: All elements deformed , param(59) ^=0
 done :: regenerate geometry data           1
 verify mesh topology
  -1.0000000000000000        1.0000000000000000       Xrange
  -1.0000000000000000        1.0000000000000000       Yrange
  -5.0000000000000000        150.00000000000000       Zrange
 done :: verify mesh topology
 118   Parameters from file:/home/kamal/neksamples/pipe2000/divpipe.rea
   1      1.00000     p001 DENSITY
   2    -2000.000     p002 VISCOS
   7      1.00000     p007 RHOCP
   8      1.00000     p008 CONDUCT
  11   1000000.000      p011 NSTEPS
  12    -0.100000E-02 p012 DT
  15    1000.0000     p015 IOSTEP
  18     -20.0000     p018 GRID < 0 --> # cells on screen
  19     -1.00000     p019 INTYPE
  20      10.0000     p020 NORDER
  21     0.100000E-05 p021 DIVERGENCE
  22     0.100000E-06 p022 HELMHOLTZ
  24     0.100000E-01 p024 TOLREL
  25     0.100000E-01 p025 TOLABS
  26      1.00000     p026 COURANT/NTAU
  27      2.00000     p027 TORDER
  28      0.00000     p028 TORDER: mesh velocity (0: p28=p27)
  59      0.00000     p059 !=0 --> full Jac. eval. for each el.
  65      1.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
  66      6.00000     p066 output : <0=ascii, else binary
  67      6.00000     p067 restart: <0=ascii, else binary
  93      20.0000     p093 Number of previous pressure solns saved
  94      3.00000     p094 start projecting velocity after p94 step
  95      5.00000     p095 start projecting pressure after p95 step
  99      0.00000     p099 dealiasing: <0--> off/3--> old/4--> new
 102      1.00000     p102 Dump out divergence at each time step
 103     0.100000E-01 p103 weight of stabilizing filter (.01)
 IFTRAN   = T
 IFFLOW   = T
 IFHEAT   = F
 IFSPLIT  = T
 IFLOMACH = F
 IFUSERVP = F
 IFUSERMV = F
 IFSTRS   = F
 IFCHAR   = F
 IFCYCLIC = F
 IFAXIS   = F
 IFMVBD   = F
 IFMELT   = F
 IFMODEL  = F
 IFKEPS   = F
 IFMOAB   = F
 IFNEKNEK = F
 IFSYNC   = T
 IFVCOR   = F
 IFINTQ   = F
 IFCWUZ   = F
 IFSWALL  = F
 IFGEOM   = F
 IFSURT   = F
 IFWCNO   = F
 IFTMSH for field           1    =  F
 IFADVC for field           1    =  T
 IFNONL for field           1    =  F
 Dealiasing enabled, lxd=           8
 Estimated eigenvalues
 EIGAA =    1.6450710020462991
 EIGGA =    283918.58986179990
 EIGAE =   4.10805594218079453E-004
 EIGAS =   2.08099221708910814E-005
 EIGGE =    283918.58986179990
 EIGGS =    2.0000000000000000
  E-solver strategy:  0 itr
 mg_nx:           1           2           4
 mg_ny:           1           2           4
 mg_nz:           1           2           4
 call usrsetvert
 done :: usrsetvert
gs_setup: 786 unique labels shared
   pairwise times (avg, min, max): 1.89245e-06 1.69277e-06 2.00272e-06
   crystal router                : 5.65052e-06 5.60284e-06 5.6982e-06
   all reduce                    : 1.60843e-05 1.59979e-05 1.62125e-05
   handle bytes (avg, min, max): 235250 233148 236388
   buffer bytes (avg, min, max): 3144 1712 3952
   setupds time 5.6469E-03 seconds   1  2       28124       25200
   setvert3d:   4      503170      704770      503170      503170
 call usrsetvert
 done :: usrsetvert
gs_setup: 6664 unique labels shared
   pairwise times (avg, min, max): 9.01222e-06 8.4877e-06 9.20296e-06
   crystal router                : 2.15054e-05 2.13861e-05 2.16961e-05
   all reduce                    : 8.18253e-05 8.1706e-05 8.18968e-05
   handle bytes (avg, min, max): 1.90516e+06 1888956 1913300
   buffer bytes (avg, min, max): 26656 14512 33488
   setupds time 1.8922E-01 seconds   2  4      503170       25200
   setvert3d:   3      187447      212647      187447      187447
 call usrsetvert
 done :: usrsetvert
gs_setup: 3005 unique labels shared
   pairwise times (avg, min, max): 4.90844e-06 4.60148e-06 5.31673e-06
   crystal router                : 1.1456e-05 1.13964e-05 1.14918e-05
   all reduce                    : 3.45439e-05 3.42846e-05 3.46899e-05
   handle bytes (avg, min, max): 849046 841524 852892
   buffer bytes (avg, min, max): 12020 6544 15104
   setupds time 1.0921E-01 seconds   3  3      187447       25200
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 1.13785e-05 1.0705e-05 1.19925e-05
   crystal router                : 3.50952e-05 3.48091e-05 3.54052e-05
   all reduce                    : 0.000132442 0.000132108 0.000132585
   setupds time 3.1718E-01 seconds   4  5      975293       25200
 h1_mg_nx:           1           2           4
 h1_mg_ny:           1           2           4
 h1_mg_nz:           1           2           4
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 1.85966e-06 1.81198e-06 1.90735e-06
   crystal router                : 5.47469e-06 5.38826e-06 5.50747e-06
   all reduce                    : 1.67131e-05 1.66178e-05 1.68085e-05
   setupds time 9.0699E-03 seconds   5  2       28124       25200
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 7.52509e-06 7.00951e-06 7.82013e-06
   crystal router                : 2.11596e-05 2.10047e-05 2.13146e-05
   all reduce                    : 8.20041e-05 8.18014e-05 8.20875e-05
   setupds time 1.9658E-01 seconds   6  4      503170       25200
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 4.78625e-06 4.3869e-06 5.19753e-06
   crystal router                : 1.0848e-05 1.06812e-05 1.10149e-05
   all reduce                    : 3.41892e-05 3.40939e-05 3.42846e-05
   setupds time 1.0998E-01 seconds   7  3      187447       25200
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 1.11341e-05 1.05143e-05 1.1611e-05
   crystal router                : 3.53426e-05 3.50237e-05 3.56197e-05
   all reduce                    : 0.000133416 0.000133109 0.000133705
   setupds time 3.2016E-01 seconds   8  5      975293       25200
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 1.10209e-05 1.02997e-05 1.13964e-05
   crystal router                : 3.50356e-05 3.47853e-05 3.52859e-05
   all reduce                    : 0.000133777 0.000133705 0.000133896
   setupds time 3.1833E-01 seconds   9  5      975293       25200
   setvert3d:   7     2388739     5538739     2388739     2388739
 call usrsetvert
 done :: usrsetvert
gs_setup: 26281 unique labels shared
   pairwise times (avg, min, max): 2.32637e-05 2.19822e-05 2.39849e-05
   crystal router                : 7.87288e-05 7.81059e-05 7.94172e-05
   all reduce                    : 0.00026685 0.000265884 0.000267482
   handle bytes (avg, min, max): 7.72743e+06 7665588 7757948
   buffer bytes (avg, min, max): 105124 57232 132032
   setupds time 6.9914E-01 seconds  10  7     2388739       25200
 setup h1 coarse grid, nx_crs=           2
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 1.97589e-06 1.78814e-06 2.19345e-06
   crystal router                : 4.18425e-06 4.1008e-06 4.29153e-06
   all reduce                    : 1.62125e-05 1.62125e-05 1.62125e-05
 done :: setup h1 coarse grid    3.1613740921020508       sec
 call usrdat3
 done :: usrdat3
 set initial conditions
 nekuic (1) for ifld            1
 call nekuic for vel
 xyz min    -1.0000      -1.0000      -5.0000
 uvwpt min -0.10000E-19 -0.10000E-19 -0.12378E-05 -0.10000E-19 -0.10000E-19
 PS min      0.0000       0.0000      0.99000E+22
 xyz max     1.0000       1.0000       150.00
 uvwpt max  0.80000E-19  0.80000E-19   2.0000      0.80000E-19  0.80000E-19
 PS max      0.0000       0.0000     -0.99000E+22
 done :: set initial conditions
 call userchk
 schfile:/home/kamal/neksamples/pipe2000/divpipe.sch
 call outfld: ifpsco: F
        0  0.0000E+00 Write checkpoint:
       0       0 OPEN: vrtdivpipe0.f00001
        0  0.0000E+00 done :: Write checkpoint
                              file size =      86.    MB
                              avg data-throughput =   264.1MB/s
                              io-nodes =     1
 number         640           0           0           0
 number         624           0           0           0
 number         624           0           0           0
 number         630           0           0           0
 number         624           0           0           0
 number         640           0           0           0
 number         624           0           0           0
 number         634           0           0           0
       0  0.00000000000E+00  1.24088603539E-10  1.12552189325E-25  1.24088603539E-10      1dragx
       0  0.00000000000E+00 -1.75487705534E-10 -6.86560965255E-26 -1.75487705534E-10      1dragy
       0  0.00000000000E+00  5.33411814488E-01 -2.85097622410E-20  5.33411814488E-01      1dragz
       0  0.00000000000E+00  9.42869304453E-08  7.45679573773E-24  9.42869304453E-08      1torqx
       0  0.00000000000E+00  6.66710102897E-08  1.20869464013E-23  6.66710102897E-08      1torqy
       0  0.00000000000E+00  7.42311196653E-17 -1.56051540126E-32  7.42311196653E-17      1torqz
[lomc-itp-43:15191] *** Process received signal ***
[lomc-itp-43:15191] Signal: Segmentation fault (11)
[lomc-itp-43:15191] Signal code: Address not mapped (1)
[lomc-itp-43:15191] Failing at address: (nil)
[lomc-itp-43:15185] *** Process received signal ***
[lomc-itp-43:15185] Signal: Segmentation fault (11)
[lomc-itp-43:15185] Signal code: Address not mapped (1)
[lomc-itp-43:15185] Failing at address: (nil)
[lomc-itp-43:15186] *** Process received signal ***
[lomc-itp-43:15186] Signal: Segmentation fault (11)
[lomc-itp-43:15186] Signal code: Address not mapped (1)
[lomc-itp-43:15186] Failing at address: (nil)
[lomc-itp-43:15188] *** Process received signal ***
[lomc-itp-43:15188] Signal: Segmentation fault (11)
[lomc-itp-43:15188] Signal code: Address not mapped (1)
[lomc-itp-43:15188] Failing at address: (nil)
[lomc-itp-43:15189] *** Process received signal ***
[lomc-itp-43:15189] Signal: Segmentation fault (11)
[lomc-itp-43:15189] Signal code: Address not mapped (1)
[lomc-itp-43:15189] Failing at address: (nil)
[lomc-itp-43:15184] *** Process received signal ***
[lomc-itp-43:15184] Signal: Segmentation fault (11)
[lomc-itp-43:15184] Signal code: Address not mapped (1)
[lomc-itp-43:15184] Failing at address: (nil)
more error [lomc-itp-43:15186] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ff4bdcdf4a0]
[lomc-itp-43:15186] *** End of error message ***
[lomc-itp-43:15188] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fee28d0f4a0]
[lomc-itp-43:15188] *** End of error message ***
[lomc-itp-43:15190] Signal: Segmentation fault (11)
[lomc-itp-43:15190] Signal code: Address not mapped (1)
[lomc-itp-43:15190] Failing at address: (nil)
[lomc-itp-43:15184] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f029087f4a0]
[lomc-itp-43:15184] *** End of error message ***
[lomc-itp-43:15189] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f172c1664a0]
[lomc-itp-43:15189] *** End of error message ***
[lomc-itp-43:15191] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f8c6bc984a0]
[lomc-itp-43:15191] *** End of error message ***
[lomc-itp-43:15185] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fa56d27a4a0]
[lomc-itp-43:15185] *** End of error message ***
[lomc-itp-43:15187] *** Process received signal ***
[lomc-itp-43:15187] Signal: Segmentation fault (11)
[lomc-itp-43:15187] Signal code: Address not mapped (1)
[lomc-itp-43:15187] Failing at address: (nil)
[lomc-itp-43:15187] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f1140dbf4a0]
[lomc-itp-43:15190] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f5eee3594a0]
[lomc-itp-43:15190] *** End of error message ***
[lomc-itp-43:15187] *** End of error message ***
