[Nek5000-users] Linearised Navier-Stokes: 2D cylinder flow
Wed Feb 5 22:11:15 CST 2014
Hi JC,
Are you trying to look at the perturbation from the
steady cylinder base flow ?
Am curious about your boundary conditions (though I
recognize that your bc set for the external cylinder
flow shouldn't be too different from the boundary
layer case)...
Just inquiring to get a better idea of what's going on.
Paul
On Wed, 5 Feb 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Nek's,
> I am trying to run a linearised DNS of the flow over a two-dimensional
> cylinder at Re=60 for illustration purposes using the ext_cyl example. I am
> however encountering some troubles... I have been able to compute the
> unstable steady equilibrium using a selective frequency damping approach
> without any trouble. However, it is quite a different story when it comes
> to the linearised DNS. Indeed, the perturbation velocity field blows up
> quite rapidly and I am not sure why. I have tried other flows (lid-driven
> cavity, boundary layer, ...) just to make sure I had no problem with  my
> nek install and everything was running fine. I have also tried on three
> different computers to make sure it was not platform-dependent and it
> actually blew up every time. I have been using the linearised version of
> nek quite extensively for the past three years and but never had such
> problem.
> Is there something I have missed there?
> Thanks a lot,
> JC
> Jean-Christophe Loiseau
> Homepage <https://sites.google.com/site/loiseaujc/>
