[Nek5000-users] SFD error message from p66
Tue Aug 12 03:00:58 CDT 2014
Hi
We had similar problem. Check tolerance fro pressure and velocity solver
(parameters 21, 22 in .rea). They can limit your convergence.
Regards
Adam
On 06/08/14 06:56, nek5000-users at lists.mcs.anl.gov wrote:
> Hello
> I implemented an SFD for a 2d cylinder
> https://bitbucket.org/cpraveen/nek5000/src/master/ext_cyl/
> It seems to work but the residuals reduce by about 5 orders of
> magnitude only. Maybe I am not choosing the parameters correctly. I
> would like to see how others do it and compare with my own implementation.
> Best
> praveen
> On Mon, Jun 30, 2014 at 1:21 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi SL
>     We have implemented SFD some time ago and we can share the code if
>     you wish. It is probably good to have single tested version of the
>     code than develop number of variations. We've already shared the
>     code with Elia.
>     Regards
>     Adam
>     On 27/06/14 17:28, nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>         Dear Nek's,
>         I'm trying to program a Selective Frequency Damping following
>         the article of Akervik et. al (Physics of Fluids, 2006) and
>         some Nek5000 posts.
>         I'm able to compile the code, however, when I try to run my
>         simulation, I find the following error message:
>                 0  0.0000E+00 Write checkpoint:
>                 0  0.0000E+00 OPEN:
>         At line 335 of file User/nek5_svn/trunk/nek/prepost.f (unit =
>         24, file = '')
>         Fortran runtime error: File '' does not exist
>         It seems to be something related to param 66. I've tried with
>         p66=6, 0, 1, -1, but I always get the same error.
>         Do you know what happens?
>         Thanks
>         SL
>         _______________________________________________
>         Nek5000-users mailing list
>         Nek5000-users at lists.mcs.anl.gov
>         <mailto:Nek5000-users at lists.mcs.anl.gov>
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140812/35f1592a/attachment.html>
