[Nek5000-users] Prex problem
Fri Apr 25 17:02:06 CDT 2014
Thanks for the clarification.  To be sure I understand, when you open prex
from your terminal, the viewing frame appears,and you can start the session
ok (choosing a name for the session, clicking read previous
parameters...etc)?  Or does the viewing frame appear blank and there is no
text in the terminal log?
If you can start the session but not load the files, please send me the
stdout on the terminal of the session. (send off list to heisey at anl.gov)
If you cannot even start the session, you should check where X11 is
installed and that the path is set correctly in the prenek/makefile.
Best,
Katherine
On Thu, Apr 24, 2014 at 6:53 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Katherine,
> Thank you for the reply and sorry for the unclear description in last
> email.
> I tried both actually.  For pretex, somtimes I have to give proper BC type
> for shown element no. and face index. Yes I can set them up once I checked
> the element corner list in .rea file according to their numbers. But I hate
> to say it is rally clumsy esp. when there are tens or even higher numbers
> of boundary elements to set.
> This is why I also tried prex, and then I got the problem I showed in last
> email. A black window without showing the topology of my mesh looks
> strange, since there are no X11 compatibility problem (I am using Ubuntu
> 13.10 & 14.04). Meanwhile, I can show the mesh by opening a .rea file from
> postx, but you know I cannot set BCs there.
> Best regards,
> Zhenyu
> -----原始邮件-----
> *发件人:* nek5000-users at lists.mcs.anl.gov
> *发送时间:* 2014-04-25 02:47:30 (星期五)
> *收件人:* nek5000-users at lists.mcs.anl.gov
> *抄送:*
> *主题:* Re: [Nek5000-users] Prex problem
> Hi,
> Are you using pretex or prex?  pretex doesn't have a gui associated with
> it, so you must use the terminal menu to make changes to your mesh.  If you
> want the graphical interface, you would want prex
> Katherine
> On Thu, Apr 24, 2014 at 12:28 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Dear All,
>>  I am trying nek5000 under ubuntu. Now I adapted mkmesh from case
>> expansion for my own case, which is a flat plane boundary layer with a slot.
>> I build one box for the jet slot and 23 boxes for the plane wall around
>> it (mbox in SIZE of genbox.f was changed for it).  Now when I use pretex to
>> merge both 2d mesh together, pretex show no picture for the mesh (but just
>> an empty menubar and a black window, no errors shown) then I cannot assign
>> properly B.C. for the boundaries.
>> Could anyone give any hints? Thank you very much in advance.
>> If you need, I can send the setup files to you.
>>  Zhenyu Zhang
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140425/c640df40/attachment.html>
