[Nek5000-users] Restart option failed
Sun Apr 13 06:55:14 CDT 2014
Hello Neks,
I figured out where the error of restart fail comes from. Its because
the code is not looking in to the working directory for the file.
In " byte.c " file I made a small change to the byte_read () function,
instead of having the variable " name " I changed it to the path of my
restart file
if (!fp)
      if
(!(fp=fopen("/home/2014012/jpeixi01/neksamples/eddy/eddy_uv0.f00012","rb")))
         printf("%s\n",name);
         printf("byte_read() :: fopen failure2!\n");
         *ierr=1;
         return;
      flag=READ;
this worked for me.
Now I would like to know why is the code not looking into the working
directory, If so where do I change it to overcome this problem so that I
don't have to change the path every single time.
Thanks a lot,
BOW
On 11/04/2014 17:43, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> Is your restart file a 0.f00000 format?
> If the param (67) is not set in the .usr file, the default is set to 0
> . f00000.
> Katie
> Katie
> On Apr 11, 2014 9:56 AM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi Paul,
>     I don't change parameters through the .usr file.
>     Thank you
>     Kamal
>     On 11/04/2014 16:52, nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>     Hi Kamal,
>>     Make certain tey aren't reset in your .usr file.
>>     Best, Paul
>>     *From:* nek5000-users-bounces at lists.mcs.anl.gov
>>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>
>>     [nek5000-users-bounces at lists.mcs.anl.gov
>>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of
>>     [nek5000-users at lists.mcs.anl.gov
>>     <mailto:nek5000-users at lists.mcs.anl.gov>]
>>     *Sent:* Thursday, April 10, 2014 9:09 AM
>>     *To:* nek5000-users at lists.mcs.anl.gov
>>     *Subject:* Re: [Nek5000-users] Restart option failed
>>     Hi JC,
>>     Thanks for the reply
>>     The parameters are positive
>>        0.00000     p064 =1 --> perturbation restart
>>        1.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
>>        6.00000     p066 output : <0=ascii, else binary
>>        6.00000     p067 restart: <0=ascii, else binary
>>     Regards,
>>     Kamal
>>     On 11/04/2014 14:18, nek5000-users at lists.mcs.anl.gov
>>>     Hi Kamal,
>>>     Check out the parameters 64 or 65 in your .rea file. It is very
>>>     likely that it is set to -4 instead of a positive number.
>>>     Cheers,
>>>     JC
>>>     2014-04-10 14:13 GMT+02:00 <nek5000-users at lists.mcs.anl.gov
>>>     <mailto:nek5000-users at lists.mcs.anl.gov>>:
>>>         Hello Neks,
>>>         I tried to restart my simulation from a previous output *.f
>>>         file but it failed
>>>         I set the restart option in *.rea to 1 and added the file name.
>>>         Could some please tell me what might be the possible cause
>>>         for this ?
>>>          nekuic (1) for ifld            1
>>>          Reading checkpoint data
>>>                0       0 OPEN: extens0.f00250
>>>         extens0.f00250
>>>         ERROR: Error reading restart header in mfi_prepare  ierr=  1
>>>         call exitt: dying ...
>>>         Thanks in advance.
>>>         Kamal
>>>         _______________________________________________
>>>         Nek5000-users mailing list
>>>         Nek5000-users at lists.mcs.anl.gov
>>>         <mailto:Nek5000-users at lists.mcs.anl.gov>
>>>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>     Jean-Christophe Loiseau
>>>     Homepage <https://sites.google.com/site/loiseaujc/>
>>>     Nek5000-users at lists.mcs.anl.gov  <mailto:Nek5000-users at lists.mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140413/8be56c1f/attachment-0001.html>
