[Nek5000-users] Restart option failed
Fri Apr 11 18:24:51 CDT 2014
Hello Neks,
I did a SVN update of the nek files to be sure that I don't miss some updates. I got the version 1021.
But this time when I launch my code, I get this error
verify mesh topology
   0.0000000000000000        6.2831853071795862       Xrange
   0.0000000000000000        6.2831853071795862       Yrange
   0.0000000000000000        0.0000000000000000       Zrange
ERROR (proc 0002, /Users/kamalselvam/nek5_svn/trunk/nek/jl/gs.c:1234): gs_op: op 4 not in valid range 1-3
ERROR (proc 0003, /Users/kamalselvam/nek5_svn/trunk/nek/jl/gs.c:1234): gs_op: op 4 not in valid range 1-3
ERROR (proc 0000, /Users/kamalselvam/nek5_svn/trunk/nek/jl/gs.c:1234): gs_op: op 4 not in valid range 1-3
ERROR (proc 0001, /Users/kamalselvam/nek5_svn/trunk/nek/jl/gs.c:1234): gs_op: op 4 not in valid range 1-3
Thank you in advance,
Kamal
On 10 Apr 2014, at 17:48, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Katie,
> yes,  my restart file is 0.f00000 format and the parameter in *.rea file is   ' 6.00000     p067 restart: <0=ascii, else binary '
> Thanks for your reply.
> Kamal
> On 11/04/2014 17:43, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> Is your restart file a 0.f00000 format?
>> If the param (67) is not set in the .usr file, the default is set to 0 . f00000.
>> Katie
>> Katie
>> On Apr 11, 2014 9:56 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Paul,
>> I don't change parameters through the .usr file.
>> Thank you
>> Kamal
>> On 11/04/2014 16:52, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Kamal,
>>> Make certain tey aren't reset in your .usr file.
>>> Best, Paul
>>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>> Sent: Thursday, April 10, 2014 9:09 AM
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Subject: Re: [Nek5000-users] Restart option failed
>>> Hi JC,
>>> Thanks for the reply
>>> The parameters are positive
>>>    0.00000     p064 =1 --> perturbation restart
>>>    1.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
>>>    6.00000     p066 output : <0=ascii, else binary
>>> Regards,
>>> Kamal
>>> On 11/04/2014 14:18, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Kamal,
>>>> Check out the parameters 64 or 65 in your .rea file. It is very likely that it is set to -4 instead of a positive number.
>>>> Cheers,
>>>> JC
>>>> 2014-04-10 14:13 GMT+02:00 <nek5000-users at lists.mcs.anl.gov>:
>>>> Hello Neks,
>>>> I tried to restart my simulation from a previous output *.f file but it failed
>>>> I set the restart option in *.rea to 1 and added the file name.
>>>> Could some please tell me what might be the possible cause for this ?
>>>>  nekuic (1) for ifld            1
>>>>  Reading checkpoint data
>>>>        0       0 OPEN: extens0.f00250
>>>> extens0.f00250
>>>> byte_read() :: fopen failure2!
>>>> ERROR: Error reading restart header in mfi_prepare  ierr=  1
>>>> call exitt: dying ...
>>>> Thanks in advance.
>>>> Kamal
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Jean-Christophe Loiseau
>>>> Homepage
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140412/defeabfa/attachment.html>
