[Nek5000-users] Test expansion exitting
Wed Apr 9 07:23:09 CDT 2014
When I run the expansion example, it stops with the following message:
call exitt: dying ...
backtrace(): obtained 6 stack frames.
./nek5000(print_stack_+0x75) [0x6651cd]
./nek5000(exitt_+0x39f) [0x76aad3]
./nek5000(MAIN__+0x82) [0x44d4ce]
./nek5000(main+0x46) [0x44c926]
/lib64/libc.so.6(__libc_start_main+0xfd) [0x39ad21ecdd]
./nek5000() [0x44c819]
total elapsed time             :   8.44085E+02 sec
total solver time incl. I/O    :   8.33374E+02 sec
time/timestep                  :   8.33374E+00 sec
CPU seconds/timestep/gridpt    :   1.75151E-04 sec
I am confused because it does not give a reason for the exit. The prior
messages are:
end of time-step loop
runtime statistics:
  total time   833.373782019479
  inv3 time         200  0.255646467208862 3.067608709616051E-004
  invc time      432300  0.812657833099365 9.751420678606974E-004
  mltd time         300   12.5136275291443 1.501562420024847E-002
  cdtp time         300   5.82422852516174 6.988735008015416E-003
  eslv time           0  0.000000000000000E+000 0.000000000000000E+000
  pres time         100   541.141169071198 0.649337885048259
  crsl time        1411   4.03384947776794 4.840384428692834E-003
  crsl min    3.67473864555359
  crsl max    4.51544284820557
  crsl avg    4.06963658332825
  hmhz time         303   650.444540500641 0.780495564576613
  spro time         101  0.366436719894409 4.397027213964407E-004
  usbc time         100   3.17075777053833 3.804724649310142E-003
  usbc min    3.17075777053833
  usbc max    3.60764217376709
  usb  avg    3.30022418498993
  axhm time        5496   220.912309885025 0.265081905204286
  advc time         300   52.1149857044220 6.253494749754901E-002
  vdss time         301   2.21998190879822 2.663848991527703E-003
  vdss min    2.21998190879822
  vdss max    2.35859322547913
  vdss avg    2.29367226362228
  dsum time        6784   14.5266296863556 1.743110954505171E-002
  dsum min    14.0492208003998
  dsum max    14.5668377876282
  dsum avg    14.3548709750175
  dadd time           0   24.6760597229004 2.960983445279973E-002
  ddsl time           0  0.000000000000000E+000 0.000000000000000E+000
  solv time           0  0.000000000000000E+000 0.000000000000000E+000
  prep time         100  0.362718105316162 4.352406004868580E-004
#  nid       tusbc       tdadd       tcrsl       tvdss tdsum
tgop    qqq    F
            0  3.1708E+00  2.4676E+01  4.0338E+00  2.2200E+00
1.4527E+01  2.6212E-03 qqq
            1  3.6076E+00  2.5966E+01  4.5154E+00  2.3586E+00
1.4049E+01  8.9169E-04 qqq
            2  3.2093E+00  2.5622E+01  4.0545E+00  2.2720E+00
1.4277E+01  3.8743E-04 qqq
            3  3.2132E+00  2.5637E+01  3.6747E+00  2.3241E+00
1.4567E+01  3.7360E-04 qqq
Its running on 4 processors, hence the various nids. Is there anything
wrong, and if so, how should I fix it?
Tania
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140409/4d653719/attachment.html>
