[Nek5000-users] ParaView with Nek5000
Wed Sep 25 04:30:31 CDT 2013
Hi Paul,
I have tried to create a dummy file pair but it doesn't work.
ParaView still views only the first file while the second file
is only loaded but it isn't visualised.
Matteo
2013/9/24 <nek5000-users at lists.mcs.anl.gov>
> Matteo,
> Just guessing, but perhaps paraview is looking for geometry
> in the subsequent .fld files, even though it's present only
> in the 01 file.
> One test would be to create a dummy file pair, blah.fld01
> blah.fld02, what are copies of the current .fld01 file and then
> see if paraview views both of these files.
> Note that if you're running on more than 1000 cores you'll
> likely want to switch to the .f00001 file format generated
> vi the IFMPIIO flag in makenek.
> Hope this helps,
> Paul
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Tuesday, September 24, 2013 3:38:13 AM
> Subject: [Nek5000-users] ParaView with Nek5000
> Dear Nek users,
> I'm trying to use ParaView 3.98 in order to visualize the results of a
> Nek5000 simulation.
> Starting from the output files .fld, I first create the metatada file
> .nek5000 (the same which can be used with VisIt).
> When I open this file in Paraview 3.98 all the .fld files are loaded, but
> the problem is that I can see only the first of these files, while the
> others are not visualized.
> Can anyone explain me the procedure to solve this problem?
> Thanks a lot.
> Matteo
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130925/69688950/attachment.html>
