[Nek5000-users] ParaView with Nek5000
Tue Sep 24 06:49:44 CDT 2013
Matteo,
Just guessing, but perhaps paraview is looking for geometry
in the subsequent .fld files, even though it's present only
in the 01 file.
One test would be to create a dummy file pair, blah.fld01
blah.fld02, what are copies of the current .fld01 file and then
see if paraview views both of these files.
Note that if you're running on more than 1000 cores you'll
likely want to switch to the .f00001 file format generated
vi the IFMPIIO flag in makenek.
Hope this helps,
Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Tuesday, September 24, 2013 3:38:13 AM
Subject: [Nek5000-users] ParaView with Nek5000
Dear Nek users,
I'm trying to use ParaView 3.98 in order to visualize the results of a Nek5000 simulation.
Starting from the output files .fld, I first create the metatada file .nek5000 (the same which can be used with VisIt).
When I open this file in Paraview 3.98 all the .fld files are loaded, but the problem is that I can see only the first of these files, while the others are not visualized.
Can anyone explain me the procedure to solve this problem?
Thanks a lot.
Matteo
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
