[Nek5000-users] Running MOAB example
Wed Sep 11 11:33:15 CDT 2013
The linker error is because of your version mismatch. You need to
update your moab to the latest version. I see you are using v4.6 now.
You should be able to use the dev version from
https://bitbucket.org/fathomteam/moab with git or download the newer
patch from https://trac.mcs.anl.gov/projects/ITAPS/wiki/MOAB.
Tim, can we create a new patched version of the release for download.
I spoke to Rajeev about this some time back but we need to decide what
fixes to backport.
Vijay
On Wed, Sep 11, 2013 at 11:20 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Yes , I am using gnu, and whwen I add USR_LFLAGS="-lmpi_cxx -lstdc++,
> I get this,
> makenek - automatic build tool for Nek5000
> generating makefile ...
> mpif77 -c  -O2 -fdefault-real-8 -x f77-cpp-input -fcray-pointer -DMOAB
> -DPTRSIZE8 -DMPI -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
> -I/home/amirreza/nek5_svn/amirreza_test/examples/moab
> -I/home/amirreza/nek5_svn/trunk/nek -I./
> /home/amirreza/nek5_svn/amirreza_test/examples/moab/pipe.f
> -I/home/amirreza/nek5_svn/trunk/nek/3rd_party
> -I/home/amirreza/Amirreza/moab-4.6.0/gcc/include  -o obj/pipe.o
> mpif77 -o nek5000  obj/pipe.o obj/drive.o obj/drive1.o obj/drive2.o
> obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
> obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
> obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
> obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
> obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
> obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
> obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o obj/hsmg.o
> obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o obj/navier6.o
> obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o obj/calcz.o obj/byte.o
> obj/chelpers.o obj/byte_mpi.o obj/postpro.o obj/cvode_driver.o
> obj/nek_comm.o obj/init_plugin.o obj/setprop.o obj/qthermal.o
> obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o obj/dsygv.o
> obj/nek_in_situ.o obj/mxm_std.o obj/blas.o obj/moab.o obj/imeshutil.o
> obj/imeshcutil.o obj/comm_mpi.o obj/singlmesh.o obj/jl_gs.o obj/jl_sort.o
> obj/jl_sarray_transfer.o obj/jl_sarray_sort.o obj/jl_gs_local.o
> obj/jl_crystal.o obj/jl_comm.o obj/jl_tensor.o obj/jl_fail.o
> obj/jl_fcrystal.o obj/jl_findpts.o obj/jl_findpts_local.o obj/jl_obbox.o
> obj/jl_poly.o obj/jl_lob_bnd.o obj/jl_findpts_el_3.o obj/jl_findpts_el_2.o
> obj/jl_sparse_cholesky.o obj/jl_xxt.o obj/jl_fcrs.o
> -L/home/amirreza/Amirreza/netcdf-4.1.3/gcc/lib
> -L/home/amirreza/Amirreza/zlib-1.2.5/gcc/lib
> -L/home/amirreza/Amirreza/szip-2.1/gcc/lib
> -L/home/amirreza/Amirreza/hdf5-1.8.11/lib
> -L/home/amirreza/Amirreza/moab-4.6.0/gcc/lib
> -L/home/amirreza/Amirreza/moab-4.6.0/gcc/lib -liMesh -lMOAB -lnetcdf  -lhdf5
> -lsz   -lm  -lmpi_cxx -lstdc++
> obj/moab.o: In function `nekmoab_intbc_':
> moab.f:(.text+0xe9d): undefined reference to `imesh_freememory_'
> moab.f:(.text+0xece): undefined reference to `imesh_freememory_'
> moab.f:(.text+0xee4): undefined reference to `imesh_freememory_'
> moab.f:(.text+0xf05): undefined reference to `imesh_freememory_'
> obj/moab.o: In function `nekmoab_bc_':
> moab.f:(.text+0x1306): undefined reference to `imesh_freememory_'
> collect2: ld returned 1 exit status
> make: *** [nek5000] Error 1
> Thanks,
> Ami
> On Wed, Sep 11, 2013 at 12:05 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> It depends which compiler you're using.  Are you using gnu?
>> Please send complete compile output.
>> - tim
>> On 09/11/2013 10:11 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Thanks for your answer, to make sure I have added libraries to makenek
>>> ''USR_LFLAGS="-lmpi_cxx -lstdc++" which I'm
>>> getting same error,so you mean I need to add appropriate fortran library
>>> to USR_LFLAGS?
>>> Thanks,
>>> Ami
>>> On Wed, Sep 11, 2013 at 10:47 AM, <nek5000-users at lists.mcs.anl.gov
>>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>>     Hi Ami,
>>>        That's the C++ runtime.  You have two options:
>>>     1. Link with the C++ compiler; in this case, you'll have to
>>> explicitly add the fortran runtime libraries to the link
>>>     statement, which is most easily done by adding it to USR_LFLAGS in
>>> makenek.  Compiler documents often tell you which
>>>     libraries implement the fortran runtime, usually in a section about
>>> inter-language linking.
>>>     2. Add the C++ std libs to USR_LFLAGS.  The trunk/nek/makenek file
>>> has a few examples of this method for
>>>     gnu/intel/pgi.  Sometimes, like on BG/x, it can be difficult to
>>> figure out what all comprises the C++ runtime, which
>>>     is why I list 1. above.
>>>     - tim
>>>     On 09/11/2013 09:31 AM, nek5000-users at lists.mcs.anl.__gov
>>> <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>>         Hello Neks,
>>>         I am trying to run MOAB example with nek5000, but all the time
>>> which I am running, it gives me set of undefined
>>>         reference error. I put an error with last part of my ./makenek
>>> pipe log below.
>>>         What is wrong with my work?
>>>         IODebugTrack.cpp:(.text+0xb74)__: undefined reference to
>>> `std::basic_ostream<char, std::char_traits<char> >&
>>>         std::operator<< <std::char_traits<char>
>>> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
>>>         IODebugTrack.cpp:(.text+0xb7f)__: undefined reference to
>>>           >::operator<<(unsigned long)'
>>>         IODebugTrack.cpp:(.text+0xb8c)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xb97)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xbd3)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xbde)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xbeb)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xbf6)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xc03)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xc0e)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xc1b)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xc26)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xc33)__: undefined reference to
>>>         IODebugTrack.cpp:(.text+0xc38)__: undefined reference to
>>>         std::endl<char, std::char_traits<char> >(std::basic_ostream<char,
>>> std::char_traits<char> >&)'
>>>         IODebugTrack.cpp:(.text+0xc40)__: undefined reference to
>>>           >::operator<<(std::basic___ostream<char, std::char_traits<char>
>>> >& (*)(std::basic_ostream<char,
>>>         std::char_traits<char> >&))'
>>>         IODebugTrack.cpp:(.text+0xc50)__: undefined reference to
>>>          >::flush()'
>>> /home/amirreza/Amirreza/moab-__4.6.0/gcc/lib/libMOAB.a(__IODebugTrack.o): In
>>> function
>>>         `moab::IODebugTrack::all___reduce()':
>>>         IODebugTrack.cpp:(.text+0xd08)__: undefined reference to
>>> `MPI_Comm_size'
>>>         IODebugTrack.cpp:(.text+0xdfe)__: undefined reference to
>>> `MPI_Gather'
>>>         IODebugTrack.cpp:(.text+__0x1080): undefined reference to
>>> `MPI_Gatherv'
>>> function
>>>         `__static_initialization_and___destruction_0(int, int)':
>>>         IODebugTrack.cpp:(.text+__0x1221): undefined reference to
>>> `std::ios_base::Init::Init()'
>>>         IODebugTrack.cpp:(.text+__0x1226): undefined reference to
>>> `std::ios_base::Init::~Init()'
>>> function
>>>         `std::list<moab::IODebugTrack:__:DRange,
>>>         std::allocator<moab::__IODebugTrack::DRange>
>>> >::_M_insert(std::_List___iterator<moab::IODebugTrack::__DRange>,
>>>         moab::IODebugTrack::DRange const&)':
>>> IODebugTrack.cpp:(.text.___ZNSt4listIN4moab12IODebugTrack__6DRangeESaIS2_EE9_M___insertESt14_List_iteratorIS2___ERKS2_[std::list<moab::__IODebugTrack::DRange,
>>>         moab::IODebugTrack::DRange const&)]+0x3a): undefined reference to
>>> `std::__detail::_List_node___base::_M_hook(std::__detail::___List_node_base*)'
>>> function
>>> `__gnu_cxx::new_allocator<std:__:_List_node<moab::__IODebugTrack::DRange>
>>>           >::deallocate(std::_List_node<__moab::IODebugTrack::DRange>*,
>>> unsigned long)':
>>> IODebugTrack.cpp:(.text._ZN9____gnu_cxx13new_allocatorISt10___List___nodeIN4moab12IODebugTrack6DRan__geEEE10deallocateEPS5_m[__gnu___cxx::new_allocator<std::_List___node<moab::IODebugTrack::__DRange>
>>> unsigned long)]+0x1c): undefined reference to
>>>         `operator
>>>         delete(void*)'
>>> function
>>> `__gnu_cxx::new_allocator<__moab::IODebugTrack::DRange>::__allocate(unsigned
>>> long, void const*)':
>>> IODebugTrack.cpp:(.text._ZN9____gnu_cxx13new___allocatorIN4moab12IODebugTrack__6DRangeEE8allocateEmPKv[__gnu___cxx::new_allocator<moab::__IODebugTrack::DRange>::__allocate(unsigned
>>>         long, void const*)]+0x2c): undefined reference to
>>> `std::__throw_bad_alloc()'
>>>         long, void const*)]+0x45): undefined reference to `operator
>>> new(unsigned long)'
>>> function
>>> `__gnu_cxx::new_allocator<__moab::IODebugTrack::DRange>::__deallocate(moab::IODebugTrack:__:DRange*,
>>> unsigned
>>>         long)':
>>> IODebugTrack.cpp:(.text._ZN9____gnu_cxx13new___allocatorIN4moab12IODebugTrack__6DRangeEE10deallocateEPS3_m[____gnu_cxx::new_allocator<moab::__IODebugTrack::DRange>::__deallocate(moab::IODebugTrack:__:DRange*,
>>>         unsigned long)]+0x1c): undefined reference to `operator
>>> delete(void*)'
>>> function
>>> >::allocate(unsigned long, void const*)':
>>> IODebugTrack.cpp:(.text._ZN9____gnu_cxx13new_allocatorISt10___List___nodeIN4moab12IODebugTrack6DRan__geEEE8allocateEmPKv[__gnu_cxx:__:new_allocator<std::_List___node<moab::IODebugTrack::__DRange>
>>>           >::allocate(unsigned long, void const*)]+0x2c): undefined
>>> reference to `std::__throw_bad_alloc()'
>>>           >::allocate(unsigned long, void const*)]+0x46): undefined
>>> reference to `operator new(unsigned long)'
>>> /home/amirreza/Amirreza/moab-__4.6.0/gcc/lib/libMOAB.a(__IODebugTrack.o):(.eh_frame+__0x24b):
>>>         `__gxx_personality_v0'
>>> /home/amirreza/Amirreza/moab-__4.6.0/gcc/lib/libMOAB.a(__OrientedBox.o): In
>>> function
>>>         `moab::operator<<(std::basic___ostream<char,
>>> std::char_traits<char> >&, moab::OrientedBox const&)':
>>>         OrientedBox.cpp:(.text+0x97): undefined reference to
>>>         std::operator<<
>>>         <std::char_traits<char> >(std::basic_ostream<char,
>>>         OrientedBox.cpp:(.text+0xaf): undefined reference to
>>>         std::operator<<
>>>         OrientedBox.cpp:(.text+0xbc): undefined reference to
>>>          >::operator<<(double)'
>>>         OrientedBox.cpp:(.text+0xc9): undefined reference to
>>>         std::operator<<
>>>         OrientedBox.cpp:(.text+0xe1): undefined reference to
>>>         std::operator<<
>>>         OrientedBox.cpp:(.text+0xee): undefined reference to
>>>         OrientedBox.cpp:(.text+0xfb): undefined reference to
>>>         std::operator<<
>>>         OrientedBox.cpp:(.text+0x113): undefined reference to
>>>         OrientedBox.cpp:(.text+0x120): undefined reference to
>>> function
>>>         OrientedBox.cpp:(.text+0x3aaf)__: undefined reference to
>>>         OrientedBox.cpp:(.text+0x3ab4)__: undefined reference to
>>> function `moab::ErrorCode
>>>         moab::EigenDecomp<moab::__Matrix3, moab::CartVect>(moab::Matrix3
>>> const&, double*, moab::CartVect*)':
>>> OrientedBox.cpp:(.text.___ZN4moab11EigenDecompINS___7Matrix3ENS_8CartVectEEENS___9ErrorCodeERKT_PdPT0_[moab::__ErrorCode
>>> const&, double*, moab::CartVect*)]+0xb7f):
>>>         undefined
>>>         reference to `std::cerr'
>>> const&, double*, moab::CartVect*)]+0xb84):
>>>         undefined
>>>         reference to `std::basic_ostream<char, std::char_traits<char> >&
>>> const*)'
>>> const&, double*, moab::CartVect*)]+0xb89):
>>>         undefined
>>>           >(std::basic_ostream<char, std::char_traits<char> >&)'
>>> const&, double*, moab::CartVect*)]+0xb91):
>>>         undefined
>>>         std::char_traits<char> >& (*)(std::basic_ostream<char,
>>> /home/amirreza/Amirreza/moab-__4.6.0/gcc/lib/libMOAB.a(__OrientedBox.o):(.eh_frame+__0x22f):
>>>         Thanks,
>>>         Ami
>>>         _________________________________________________
>>>         Nek5000-users mailing list
>>>         Nek5000-users at lists.mcs.anl.__gov
>>> <mailto:Nek5000-users at lists.mcs.anl.gov>
>>>         https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users
>>>         <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>     ==============================__==============================__====
>>>     "You will keep in perfect peace him whose mind is
>>>        steadfast, because he trusts in you."               Isaiah 26:3
>>>                   Tim Tautges            Argonne National Laboratory
>>>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)
>>> (telecommuting from UW-Madison)
>>>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>      1500
>>> Engineering Dr.
>>>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>
>>> Madison, WI 53706
>>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>             fax: (608) 263-4499      Madison, WI 53706
