[Nek5000-users] Running MOAB example
Wed Sep 11 11:20:38 CDT 2013
Yes , I am using gnu, and whwen I add USR_LFLAGS="-lmpi_cxx -lstdc++,
I get this,
makenek - automatic build tool for Nek5000
generating makefile ...
mpif77 -c  -O2 -fdefault-real-8 -x f77-cpp-input -fcray-pointer -DMOAB
-DPTRSIZE8 -DMPI -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
-I/home/amirreza/nek5_svn/amirreza_test/examples/moab
-I/home/amirreza/nek5_svn/trunk/nek -I./
/home/amirreza/nek5_svn/amirreza_test/examples/moab/pipe.f
-I/home/amirreza/nek5_svn/trunk/nek/3rd_party
-I/home/amirreza/Amirreza/moab-4.6.0/gcc/include  -o obj/pipe.o
mpif77 -o nek5000  obj/pipe.o obj/drive.o obj/drive1.o obj/drive2.o
obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o
obj/hsmg.o obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o
obj/navier6.o obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o
obj/calcz.o obj/byte.o obj/chelpers.o obj/byte_mpi.o obj/postpro.o
obj/cvode_driver.o obj/nek_comm.o obj/init_plugin.o obj/setprop.o
obj/qthermal.o obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o
obj/dsygv.o obj/nek_in_situ.o obj/mxm_std.o obj/blas.o obj/moab.o
obj/imeshutil.o obj/imeshcutil.o obj/comm_mpi.o obj/singlmesh.o obj/jl_gs.o
obj/jl_sort.o obj/jl_sarray_transfer.o obj/jl_sarray_sort.o
obj/jl_gs_local.o obj/jl_crystal.o obj/jl_comm.o obj/jl_tensor.o
obj/jl_fail.o obj/jl_fcrystal.o obj/jl_findpts.o obj/jl_findpts_local.o
obj/jl_obbox.o obj/jl_poly.o obj/jl_lob_bnd.o obj/jl_findpts_el_3.o
obj/jl_findpts_el_2.o obj/jl_sparse_cholesky.o obj/jl_xxt.o obj/jl_fcrs.o
-L/home/amirreza/Amirreza/netcdf-4.1.3/gcc/lib
-L/home/amirreza/Amirreza/zlib-1.2.5/gcc/lib
-L/home/amirreza/Amirreza/szip-2.1/gcc/lib
-L/home/amirreza/Amirreza/hdf5-1.8.11/lib
-L/home/amirreza/Amirreza/moab-4.6.0/gcc/lib
-L/home/amirreza/Amirreza/moab-4.6.0/gcc/lib -liMesh -lMOAB -lnetcdf
-lhdf5  -lsz   -lm  -lmpi_cxx -lstdc++
obj/moab.o: In function `nekmoab_intbc_':
moab.f:(.text+0xe9d): undefined reference to `imesh_freememory_'
moab.f:(.text+0xece): undefined reference to `imesh_freememory_'
moab.f:(.text+0xee4): undefined reference to `imesh_freememory_'
moab.f:(.text+0xf05): undefined reference to `imesh_freememory_'
obj/moab.o: In function `nekmoab_bc_':
moab.f:(.text+0x1306): undefined reference to `imesh_freememory_'
collect2: ld returned 1 exit status
make: *** [nek5000] Error 1
Ami
On Wed, Sep 11, 2013 at 12:05 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> It depends which compiler you're using.  Are you using gnu?
> Please send complete compile output.
> - tim
> On 09/11/2013 10:11 AM, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>> Thanks for your answer, to make sure I have added libraries to makenek
>> ''USR_LFLAGS="-lmpi_cxx -lstdc++" which I'm
>> getting same error,so you mean I need to add appropriate fortran library
>> to USR_LFLAGS?
>> Thanks,
>> Ami
>> On Wed, Sep 11, 2013 at 10:47 AM, <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov><mailto:
>> nek5000-users at lists.**mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>>>
>> wrote:
>>     Hi Ami,
>>        That's the C++ runtime.  You have two options:
>>     1. Link with the C++ compiler; in this case, you'll have to
>> explicitly add the fortran runtime libraries to the link
>>     statement, which is most easily done by adding it to USR_LFLAGS in
>> makenek.  Compiler documents often tell you which
>>     libraries implement the fortran runtime, usually in a section about
>> inter-language linking.
>>     2. Add the C++ std libs to USR_LFLAGS.  The trunk/nek/makenek file
>> has a few examples of this method for
>>     gnu/intel/pgi.  Sometimes, like on BG/x, it can be difficult to
>> figure out what all comprises the C++ runtime, which
>>     is why I list 1. above.
>>     - tim
>>     On 09/11/2013 09:31 AM, nek5000-users at lists.mcs.anl.__**gov <mailto:
>> wrote:
>>         Hello Neks,
>>         I am trying to run MOAB example with nek5000, but all the time
>> which I am running, it gives me set of undefined
>>         reference error. I put an error with last part of my ./makenek
>> pipe log below.
>>         What is wrong with my work?
>>         IODebugTrack.cpp:(.text+0xb74)**__: undefined reference to
>> `std::basic_ostream<char, std::char_traits<char> >&
>>         std::operator<< <std::char_traits<char>
>> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
>>         IODebugTrack.cpp:(.text+0xb7f)**__: undefined reference to
>>           >::operator<<(unsigned long)'
>>         IODebugTrack.cpp:(.text+0xb8c)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xb97)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xbd3)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xbde)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xbeb)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xbf6)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xc03)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xc0e)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xc1b)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xc26)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xc33)**__: undefined reference to
>>         IODebugTrack.cpp:(.text+0xc38)**__: undefined reference to
>>         std::endl<char, std::char_traits<char> >(std::basic_ostream<char,
>> std::char_traits<char> >&)'
>>         IODebugTrack.cpp:(.text+0xc40)**__: undefined reference to
>>           >::operator<<(std::basic___**ostream<char,
>> std::char_traits<char> >& (*)(std::basic_ostream<char,
>>         std::char_traits<char> >&))'
>>         IODebugTrack.cpp:(.text+0xc50)**__: undefined reference to
>>          >::flush()'
>>         /home/amirreza/Amirreza/moab-_**_4.6.0/gcc/lib/libMOAB.a(__**IODebugTrack.o):
>> In function
>>         `moab::IODebugTrack::all___**reduce()':
>>         IODebugTrack.cpp:(.text+0xd08)**__: undefined reference to
>> `MPI_Comm_size'
>>         IODebugTrack.cpp:(.text+0xdfe)**__: undefined reference to
>> `MPI_Gather'
>>         IODebugTrack.cpp:(.text+__**0x1080): undefined reference to
>> `MPI_Gatherv'
>> In function
>>         `__static_initialization_and__**_destruction_0(int, int)':
>>         IODebugTrack.cpp:(.text+__**0x1221): undefined reference to
>> `std::ios_base::Init::Init()'
>>         IODebugTrack.cpp:(.text+__**0x1226): undefined reference to
>> `std::ios_base::Init::~Init()'
>> In function
>>         `std::list<moab::IODebugTrack:**__:DRange,
>>         std::allocator<moab::__**IODebugTrack::DRange>
>> >::_M_insert(std::_List___**iterator<moab::IODebugTrack::_**_DRange>,
>>         moab::IODebugTrack::DRange const&)':
>>         IODebugTrack.cpp:(.text.___**ZNSt4listIN4moab12IODebugTrack**
>> __6DRangeESaIS2_EE9_M___**insertESt14_List_iteratorIS2__**
>> _ERKS2_[std::list<moab::__**IODebugTrack::DRange,
>>         moab::IODebugTrack::DRange const&)]+0x3a): undefined reference to
>>         `std::__detail::_List_node___**base::_M_hook(std::__detail::_**
>> __List_node_base*)'
>> In function
>>         `__gnu_cxx::new_allocator<std:**__:_List_node<moab::__**
>>           >::deallocate(std::_List_node<**__moab::IODebugTrack::DRange>**
>> *, unsigned long)':
>>         IODebugTrack.cpp:(.text._ZN9__**__gnu_cxx13new_allocatorISt10_**
>> __List___**nodeIN4moab12IODebugTrack6DRan**__geEEE10deallocateEPS5_m[__**
>> gnu___cxx::new_allocator<std::**_List___node<moab::**
>> IODebugTrack::__DRange>
>> *, unsigned long)]+0x1c): undefined reference to
>>         `operator
>>         delete(void*)'
>> In function
>>         `__gnu_cxx::new_allocator<__**moab::IODebugTrack::DRange>::_**_allocate(unsigned
>> long, void const*)':
>>         IODebugTrack.cpp:(.text._ZN9__**__gnu_cxx13new___**
>> allocatorIN4moab12IODebugTrack**__6DRangeEE8allocateEmPKv[__**
>> gnu___cxx::new_allocator<moab:**:__IODebugTrack::DRange>::__**
>> allocate(unsigned
>>         long, void const*)]+0x2c): undefined reference to
>> `std::__throw_bad_alloc()'
>> allocate(unsigned
>>         long, void const*)]+0x45): undefined reference to `operator
>> new(unsigned long)'
>> In function
>> _deallocate(moab::**IODebugTrack:__:DRange*, unsigned
>>         long)':
>> allocatorIN4moab12IODebugTrack**__6DRangeEE10deallocateEPS3_m[**
>> ____gnu_cxx::new_allocator<**moab::__IODebugTrack::DRange>:**
>> :__deallocate(moab::**IODebugTrack:__:DRange*,
>>         unsigned long)]+0x1c): undefined reference to `operator
>> delete(void*)'
>> In function
>>         `__gnu_cxx::new_allocator<std:**__:_List_node<moab::__**IODebugTrack::DRange>
>> >::allocate(unsigned long, void const*)':
>> __List___**nodeIN4moab12IODebugTrack6DRan**__geEEE8allocateEmPKv[__gnu_**
>> cxx:__:new_allocator<std::_**List___node<moab::**IODebugTrack::__DRange>
>>           >::allocate(unsigned long, void const*)]+0x2c): undefined
>> reference to `std::__throw_bad_alloc()'
>>           >::allocate(unsigned long, void const*)]+0x46): undefined
>> reference to `operator new(unsigned long)'
>> IODebugTrack.o):(.eh_frame+__**0x24b): undefined reference to
>>         `__gxx_personality_v0'
>>         /home/amirreza/Amirreza/moab-_**_4.6.0/gcc/lib/libMOAB.a(__**OrientedBox.o):
>> In function
>>         `moab::operator<<(std::basic__**_ostream<char,
>> std::char_traits<char> >&, moab::OrientedBox const&)':
>>         OrientedBox.cpp:(.text+0x97): undefined reference to
>>         std::operator<<
>>         <std::char_traits<char> >(std::basic_ostream<char,
>>         OrientedBox.cpp:(.text+0xaf): undefined reference to
>>         std::operator<<
>>         OrientedBox.cpp:(.text+0xbc): undefined reference to
>>          >::operator<<(double)'
>>         OrientedBox.cpp:(.text+0xc9): undefined reference to
>>         std::operator<<
>>         OrientedBox.cpp:(.text+0xe1): undefined reference to
>>         std::operator<<
>>         OrientedBox.cpp:(.text+0xee): undefined reference to
>>         OrientedBox.cpp:(.text+0xfb): undefined reference to
>>         std::operator<<
>>         OrientedBox.cpp:(.text+0x113): undefined reference to
>>         OrientedBox.cpp:(.text+0x120): undefined reference to
>> In function
>>         OrientedBox.cpp:(.text+0x3aaf)**__: undefined reference to
>>         OrientedBox.cpp:(.text+0x3ab4)**__: undefined reference to
>> In function `moab::ErrorCode
>>         moab::EigenDecomp<moab::__**Matrix3,
>> moab::CartVect>(moab::Matrix3 const&, double*, moab::CartVect*)':
>>         OrientedBox.cpp:(.text.___**ZN4moab11EigenDecompINS___**
>> 7Matrix3ENS_8CartVectEEENS___**9ErrorCodeERKT_PdPT0_[moab::__**ErrorCode
>> moab::CartVect>(moab::Matrix3 const&, double*, moab::CartVect*)]+0xb7f):
>>         undefined
>>         reference to `std::cerr'
>> moab::CartVect>(moab::Matrix3 const&, double*, moab::CartVect*)]+0xb84):
>>         undefined
>>         reference to `std::basic_ostream<char, std::char_traits<char> >&
>> const*)'
>> moab::CartVect>(moab::Matrix3 const&, double*, moab::CartVect*)]+0xb89):
>>         undefined
>>           >(std::basic_ostream<char, std::char_traits<char> >&)'
>> moab::CartVect>(moab::Matrix3 const&, double*, moab::CartVect*)]+0xb91):
>>         undefined
>> OrientedBox.o):(.eh_frame+__**0x22f): undefined reference to
>>         Thanks,
>>         Ami
>>         ______________________________**___________________
>>         Nek5000-users mailing list
>>         Nek5000-users at lists.mcs.anl.__**gov <mailto:Nek5000-users at lists.*
>> *mcs.anl.gov <Nek5000-users at lists.mcs.anl.gov>>
>>         https://lists.mcs.anl.gov/__**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users>
>>         <https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>     ==============================**__============================**
>> ==__====
>>     "You will keep in perfect peace him whose mind is
>>        steadfast, because he trusts in you."               Isaiah 26:3
>>                   Tim Tautges            Argonne National Laboratory
>>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)
>>  (telecommuting from UW-Madison)
>>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>
>>  1500 Engineering Dr.
>>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>
>>  Madison, WI 53706
>>     Nek5000-users at lists.mcs.anl.__**gov <mailto:Nek5000-users at lists.**
>>     https://lists.mcs.anl.gov/__**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users><
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130911/4573c464/attachment-0001.html>
