[Nek5000-users] 3D Problem Visual
Fri Sep 6 04:13:19 CDT 2013
Hi Paul,
Thank you, calling fix_geom in usrdat2() solved the problem. The results
seem to be good even without the fix_geom, the problem with the geometry
doesn't seem to interfere with the flow... but due to the problems with
visualisation it is difficult to be 100% certain.
Thanks again,
JP
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130906/6b99ce39/attachment.html>
