[Nek5000-users] 2D simulation for 3D perturbation mode with a 2D baseflow
Fri Oct 25 02:14:40 CDT 2013
Hi Paul,
I'll try that soon and let you know how it works.
thanks again for you help.
Vincent.
Message: 2
Date: Thu, 24 Oct 2013 07:31:40 -0500 (CDT)
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 56, Issue 27
Message-ID:
	<mailman.3603.1382617901.3278.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset=utf-8
Hi Vincent,
You simply need to fill userdiv... typically this would be done
in userchk.
grep div */*usr from the /examples directory would illustrate
some use cases.
It'd be a good idea to run a few tests to make certain it's
working in the way that you think it should.
Paul
