[Nek5000-users] postx black window
Mon Oct 21 07:48:58 CDT 2013
Yeah, it works!
But it appears to be strange for me.
ext_cyl.fld%02d  %02d says that there is 2 digits after the name
"ext_cyl.fld"
but it reads 001, which is three digits. So not that strict as I thought.
Thank you again.
On Mon, Oct 21, 2013 at 11:04 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Yop Tubois,
> As far as I known, visit has no problem handling three digits files. For
> the same case, my .nek3d metafile on my laptop simply reads:
> NEK5000
> version: 1.0
> filetemplate: ext_cyl.fld%02d
> firsttimestep: 001
> numtimesteps: 999
> for instance. Have you tried that?
> Regards,
> JC
> 2013/10/21 <nek5000-users at lists.mcs.anl.gov>
> Thank you very much! the "draw" bouton is indeed hided, and i missed it.
>> Another small question: I ran the example of the flow past a cylinder:
>> ext_cyl
>> The output is ext_cyl.fld01 ext_cyl.fld02 .... ext_cyl.fld99, then
>> ext_cyl.fld100, ext_cyl.fld101 ....
>> So the number at the end the name of the data file jumps from two digits
>> to three digits.
>> Anyway to make all of the them in 3 digits or N digits as we wanted
>> without writing another bash script?
>> Thank you very much.
>> Tubois
>> On Sun, Oct 20, 2013 at 11:30 PM, <nek5000-users at lists.mcs.anl.gov>wrote:
>>> Hi Tubois,
>>> Did you got any error messages in the output window which you can access
>>> by pressing icon with "i" at the low right corner?
>>> Also have pressed on 'Draw' after choosing the pressure pseudocolor plot?
>>> Aleks
>>> ----- Original Message -----
>>> From: nek5000-users at lists.mcs.anl.gov
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Sent: Sunday, October 20, 2013 11:58:50 AM
>>> Subject: Re: [Nek5000-users] postx black window
>>> Yes it is. It almost totally correct the problem.
>>> I can visualize the flow pattern now.
>>> But fonction of movie does not work yet.
>>> Still thank you very much.
>>> I just download the visit executable file. The version for ubuntu 11.04
>>> visit2_6_3.linux-x86_64-ubuntu11.tar.gz
>>> There is not version for 12.04 available.
>>> nekb output eddy_uv.fld01 .... eddy_uv.fld12
>>> I created the metadata file called "eddy_uv.nek2d"
>>> NEK5000
>>> version: 1.0
>>> filetemplate: eddy_uv.fld%02d
>>> firsttimestep: 1
>>> numtimesteps: 10
>>> I loaded it into visit, and choose the pressure contour, I got nothing
>>> on the screen.
>>> It seems that visit do not see the nek output file file
>>> What is the problem?
>>> Tubois
>>> On Sun, Oct 20, 2013 at 5:59 PM, < nek5000-users at lists.mcs.anl.gov >
>>> wrote:
>>> Hi Tubois
>>> I had a similar problem when installing on an Ubuntu 12.04 machine (I am
>>> not sure which OS you are using) The problem was solved by installing the
>>> following packages:
>>> mesa-utils
>>> libx11-*
>>> libxt-dev
>>> xfonts-100dpi
>>> xfonts-100dpi-transcoded
>>> xfonts-75dpi
>>> xfonts-75dpi-transcoded
>>> Perhaps this will help you determine what packages need to be installed
>>> on your system.
>>> Brandon
>>> On Oct 20, 2013 3:03 AM, < nek5000-users-request at lists.mcs.anl.gov >
>>> wrote:
>>> Send Nek5000-users mailing list submissions to
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>> nek5000-users-owner at lists.mcs.anl.gov
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of Nek5000-users digest..."
>>> Today's Topics:
>>> 1. Re: postx black window ( nek5000-users at lists.mcs.anl.gov )
>>> Message: 1
>>> Date: Sun, 20 Oct 2013 12:03:26 +0200
>>> Message-ID:
>>> < mailman.2996.1382263412.3278.nek5000-users at lists.mcs.anl.gov >
>>> Content-Type: text/plain; charset="iso-8859-1"
>>> Sorry to bother people in the list for this kind of naive question.
>>> I tried postx on two computers, one my laptop, one cluster in my
>>> laboratory.
>>> I got the same screen. It seems to be some graphics issue with the
>>> system.
>>> You can find the screenshot attached here.
>>> So what should I do? Thank you very much!
>>> Tubois
>>> On Sun, Oct 20, 2013 at 10:40 AM, < nek5000-users at lists.mcs.anl.gov >
>>> wrote:
>>> > Hi Paul,
>>> > Thank you for your response.
>>> > I already put PATH = ~/bin:$PATH in ~/.bashrc
>>> > running nekb is not a problem, the logfile gives the right results by
>>> > using nekb or nekbmpi
>>> > so the computation is ok.
>>> > The question lies on postx
>>> > I typed postx on the command line, then a black window appears, on the
>>> top
>>> > of which there is "Nekton".
>>> > but I do not see any sidebar
>>> > And on the terminal, it asks "Enter Session Name"
>>> > I left click the window with the cursor , and then "return" on the
>>> keyboard
>>> > it returns on the terminal
>>> > Enter Session Name
>>> > Beginning
>>> > Session
>>> > renaming SESSION.NAME SESSION.NAME ~
>>> > Session
>>> > name:
>>> > ** ERROR ** Can't open file .rea
>>> > Enter Session Name
>>> > XIO: fatal IO error 11 (Resource temporarily unavailable) on X server
>>> > ":0.0"
>>> > after 235 requests (235 known processed) with 0 events remaining.
>>> > What is wrong here?
>>> > Thank you very much !
>>> > Tubois
>>> > On Sun, Oct 20, 2013 at 1:57 AM, < nek5000-users at lists.mcs.anl.gov >
>>> wrote:
>>> >> The easiest thing is to copy the nekb script to your working
>>> directory.
>>> >> There should also be a .soft file or something where you can add
>>> >> PATH = ~/bin:$PATH
>>> >> to get your bin directory into your path.
>>> >> hth, Paul
>>> >> Sent: Saturday, October 19, 2013 6:19:23 PM
>>> >> Subject: [Nek5000-users] postx black window
>>> >> Hello,
>>> >> I am totally new to nek5000. I started with the pdf online to the case
>>> >> eddy_uv
>>> >> The computation seems ok, when I check the tail, I got the same
>>> results
>>> >> as in the pdf online.
>>> >> However, when I type postx
>>> >> I just got a black window, without any sidebar menu.
>>> >> In fact, when I compiled the tools in /nek5000_svn/trunck/tools/.
>>> >> I typed ./maketools all
>>> >> I got a lot of warnings, like
>>> >> CALL ZWGJD (ZD,WD,NP,ALPHAD,BETAD)
>>> >> 1
>>> >> Warning: Type mismatch in argument 'alpha' at (1); passed REAL(4) to
>>> >> REAL(8)
>>> >> gfortran -mcmodel=medium -c mxm44f2.f
>>> >> gcc -mcmodel=medium -c -DUNDERSCORE byte.c
>>> >> gfortran -mcmodel=medium -c int_tp_gbox.f
>>> >> int_tp_gbox.f:574.28:
>>> >> But at the end, the compilation seems accomplished.
>>> >> So what is wrong with my installation? Thank you very much!
>>> >> Tubois Gao
>>> >> _______________________________________________
>>> >> Nek5000-users at lists.mcs.anl.gov
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <
>>> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/a1c1fd7b/attachment.html>
>>> A non-text attachment was scrubbed...
>>> Name: Screenshot from 2013-10-20 11:58:26.png
>>> Type: image/png
>>> Desc: not available
>>> URL: <
>>> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/a1c1fd7b/attachment.png>
>>> End of Nek5000-users Digest, Vol 56, Issue 20
> Jean-Christophe Loiseau
> Homepage <https://sites.google.com/site/loiseaujc/>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131021/75a07158/attachment.html>
