[Nek5000-users] postx black window
Mon Oct 21 04:04:14 CDT 2013
Yop Tubois,
As far as I known, visit has no problem handling three digits files. For
the same case, my .nek3d metafile on my laptop simply reads:
NEK5000
version: 1.0
filetemplate: ext_cyl.fld%02d
firsttimestep: 001
numtimesteps: 999
for instance. Have you tried that?
JC
2013/10/21 <nek5000-users at lists.mcs.anl.gov>
> Thank you very much! the "draw" bouton is indeed hided, and i missed it.
> Another small question: I ran the example of the flow past a cylinder:
> ext_cyl
> The output is ext_cyl.fld01 ext_cyl.fld02 .... ext_cyl.fld99, then
> ext_cyl.fld100, ext_cyl.fld101 ....
> So the number at the end the name of the data file jumps from two digits
> to three digits.
> Anyway to make all of the them in 3 digits or N digits as we wanted
> without writing another bash script?
> Thank you very much.
> Tubois
> On Sun, Oct 20, 2013 at 11:30 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Tubois,
>> Did you got any error messages in the output window which you can access
>> by pressing icon with "i" at the low right corner?
>> Also have pressed on 'Draw' after choosing the pressure pseudocolor plot?
>> Aleks
>> ----- Original Message -----
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov
>> Sent: Sunday, October 20, 2013 11:58:50 AM
>> Subject: Re: [Nek5000-users] postx black window
>> Yes it is. It almost totally correct the problem.
>> I can visualize the flow pattern now.
>> But fonction of movie does not work yet.
>> Still thank you very much.
>> I just download the visit executable file. The version for ubuntu 11.04
>> visit2_6_3.linux-x86_64-ubuntu11.tar.gz
>> There is not version for 12.04 available.
>> nekb output eddy_uv.fld01 .... eddy_uv.fld12
>> I created the metadata file called "eddy_uv.nek2d"
>> NEK5000
>> version: 1.0
>> filetemplate: eddy_uv.fld%02d
>> firsttimestep: 1
>> numtimesteps: 10
>> I loaded it into visit, and choose the pressure contour, I got nothing on
>> the screen.
>> It seems that visit do not see the nek output file file
>> What is the problem?
>> Tubois
>> On Sun, Oct 20, 2013 at 5:59 PM, < nek5000-users at lists.mcs.anl.gov >
>> wrote:
>> Hi Tubois
>> I had a similar problem when installing on an Ubuntu 12.04 machine (I am
>> not sure which OS you are using) The problem was solved by installing the
>> following packages:
>> mesa-utils
>> libx11-*
>> libxt-dev
>> xfonts-100dpi
>> xfonts-100dpi-transcoded
>> xfonts-75dpi
>> xfonts-75dpi-transcoded
>> Perhaps this will help you determine what packages need to be installed
>> on your system.
>> Brandon
>> On Oct 20, 2013 3:03 AM, < nek5000-users-request at lists.mcs.anl.gov >
>> wrote:
>> Send Nek5000-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> nek5000-users-owner at lists.mcs.anl.gov
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Nek5000-users digest..."
>> Today's Topics:
>> 1. Re: postx black window ( nek5000-users at lists.mcs.anl.gov )
>> Message: 1
>> Date: Sun, 20 Oct 2013 12:03:26 +0200
>> Message-ID:
>> < mailman.2996.1382263412.3278.nek5000-users at lists.mcs.anl.gov >
>> Content-Type: text/plain; charset="iso-8859-1"
>> Sorry to bother people in the list for this kind of naive question.
>> I tried postx on two computers, one my laptop, one cluster in my
>> laboratory.
>> I got the same screen. It seems to be some graphics issue with the system.
>> You can find the screenshot attached here.
>> So what should I do? Thank you very much!
>> Tubois
>> On Sun, Oct 20, 2013 at 10:40 AM, < nek5000-users at lists.mcs.anl.gov >
>> wrote:
>> > Hi Paul,
>> > Thank you for your response.
>> > I already put PATH = ~/bin:$PATH in ~/.bashrc
>> > running nekb is not a problem, the logfile gives the right results by
>> > using nekb or nekbmpi
>> > so the computation is ok.
>> > The question lies on postx
>> > I typed postx on the command line, then a black window appears, on the
>> top
>> > of which there is "Nekton".
>> > but I do not see any sidebar
>> > And on the terminal, it asks "Enter Session Name"
>> > I left click the window with the cursor , and then "return" on the
>> keyboard
>> > it returns on the terminal
>> > Enter Session Name
>> > Beginning
>> > Session
>> > renaming SESSION.NAME SESSION.NAME ~
>> > Session
>> > name:
>> > ** ERROR ** Can't open file .rea
>> > Enter Session Name
>> > XIO: fatal IO error 11 (Resource temporarily unavailable) on X server
>> > ":0.0"
>> > after 235 requests (235 known processed) with 0 events remaining.
>> > What is wrong here?
>> > Thank you very much !
>> > Tubois
>> > On Sun, Oct 20, 2013 at 1:57 AM, < nek5000-users at lists.mcs.anl.gov >
>> wrote:
>> >> The easiest thing is to copy the nekb script to your working directory.
>> >> There should also be a .soft file or something where you can add
>> >> PATH = ~/bin:$PATH
>> >> to get your bin directory into your path.
>> >> hth, Paul
>> >> Sent: Saturday, October 19, 2013 6:19:23 PM
>> >> Subject: [Nek5000-users] postx black window
>> >> Hello,
>> >> I am totally new to nek5000. I started with the pdf online to the case
>> >> eddy_uv
>> >> The computation seems ok, when I check the tail, I got the same results
>> >> as in the pdf online.
>> >> However, when I type postx
>> >> I just got a black window, without any sidebar menu.
>> >> In fact, when I compiled the tools in /nek5000_svn/trunck/tools/.
>> >> I typed ./maketools all
>> >> I got a lot of warnings, like
>> >> CALL ZWGJD (ZD,WD,NP,ALPHAD,BETAD)
>> >> 1
>> >> Warning: Type mismatch in argument 'alpha' at (1); passed REAL(4) to
>> >> REAL(8)
>> >> gfortran -mcmodel=medium -c mxm44f2.f
>> >> gcc -mcmodel=medium -c -DUNDERSCORE byte.c
>> >> gfortran -mcmodel=medium -c int_tp_gbox.f
>> >> int_tp_gbox.f:574.28:
>> >> But at the end, the compilation seems accomplished.
>> >> So what is wrong with my installation? Thank you very much!
>> >> Tubois Gao
>> >> _______________________________________________
>> >> Nek5000-users at lists.mcs.anl.gov
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/a1c1fd7b/attachment.html>
>> A non-text attachment was scrubbed...
>> Name: Screenshot from 2013-10-20 11:58:26.png
>> Type: image/png
>> Desc: not available
>> URL: <
>> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/a1c1fd7b/attachment.png>
>> End of Nek5000-users Digest, Vol 56, Issue 20
Jean-Christophe Loiseau
Homepage <https://sites.google.com/site/loiseaujc/>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131021/ca19c94b/attachment-0001.html>
