[Nek5000-users] postx black window
Sun Oct 20 10:59:17 CDT 2013
Hi Tubois
I had a similar problem when installing on an Ubuntu 12.04 machine (I am
not sure which OS you are using) The problem was solved by installing the
following packages:
mesa-utils
libx11-*
libxt-dev
xfonts-100dpi
xfonts-100dpi-transcoded
xfonts-75dpi
xfonts-75dpi-transcoded
Perhaps this will help you determine what packages need to be installed on
your system.
Brandon
On Oct 20, 2013 3:03 AM, <nek5000-users-request at lists.mcs.anl.gov> wrote:
Send Nek5000-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        nek5000-users-owner at lists.mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Nek5000-users digest..."
Today's Topics:
   1. Re: postx black window (nek5000-users at lists.mcs.anl.gov)
Message: 1
Date: Sun, 20 Oct 2013 12:03:26 +0200
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] postx black window
Message-ID:
        <mailman.2996.1382263412.3278.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="iso-8859-1"
Sorry to bother people in the list for this kind of naive question.
I tried postx on two computers, one my laptop, one cluster in my
laboratory.
I got the same screen. It seems to be some graphics issue with the system.
You can find the screenshot attached here.
So what should I do? Thank you very much!
Tubois
On Sun, Oct 20, 2013 at 10:40 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Paul,
> Thank you for your response.
> I already put PATH = ~/bin:$PATH in ~/.bashrc
> running nekb is not a problem, the logfile gives the right results by
> using nekb or nekbmpi
> so the computation is ok.
> The question lies on postx
> I typed postx on the command line, then a black window appears, on the top
> of which there is "Nekton".
> but I do not see any sidebar
> And on the terminal, it asks "Enter Session Name"
> I left click the window with the cursor , and then "return" on the
keyboard
> it returns on the terminal
> Enter Session Name
>  Beginning
> Session
>  renaming SESSION.NAME SESSION.NAME~
>  Session
> name:
>  ** ERROR **  Can't open file .rea
> Enter Session Name
> XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server
> ":0.0"
>       after 235 requests (235 known processed) with 0 events remaining.
> What is wrong here?
> Thank you very much !
> Tubois
> On Sun, Oct 20, 2013 at 1:57 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> The easiest thing is to copy the nekb script to your working directory.
>> There should also be a .soft file or something where you can add
>> PATH = ~/bin:$PATH
>> to get your bin directory into your path.
>> hth, Paul
>> ----- Original Message -----
>> From: nek5000-users at lists.mcs.anl.gov
>> Sent: Saturday, October 19, 2013 6:19:23 PM
>> Subject: [Nek5000-users] postx black window
>> Hello,
>> I am totally new to nek5000. I started with the pdf online to the case
>> eddy_uv
>> The computation seems ok, when I check the tail, I got the same results
>> as in the pdf online.
>> However, when I type postx
>> I just got a black window, without any sidebar menu.
>> In fact, when I compiled the tools in /nek5000_svn/trunck/tools/.
>> I typed ./maketools all
>> I got a lot of warnings, like
>> CALL ZWGJD (ZD,WD,NP,ALPHAD,BETAD)
>> 1
>> Warning: Type mismatch in argument 'alpha' at (1); passed REAL(4) to
>> REAL(8)
>> gfortran -mcmodel=medium -c mxm44f2.f
>> gcc -mcmodel=medium -c -DUNDERSCORE byte.c
>> gfortran -mcmodel=medium -c int_tp_gbox.f
>> int_tp_gbox.f:574.28:
>> But at the end, the compilation seems accomplished.
>> So what is wrong with my installation? Thank you very much!
>> Tubois Gao
>> Nek5000-users at lists.mcs.anl.gov
URL: <
http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/a1c1fd7b/attachment.html
Name: Screenshot from 2013-10-20 11:58:26.png
Type: image/png
Desc: not available
URL: <
http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/a1c1fd7b/attachment.png
End of Nek5000-users Digest, Vol 56, Issue 20
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/a2c04d21/attachment-0001.html>
