[Nek5000-users] postx black window
Sun Oct 20 06:10:20 CDT 2013
Have you tried VisIt ?
There is much more support for VisIt than for postx.
Let me think about your postx problem --- it has something to
do with the X11 drivers and font sets, but I can't recall how
I've remedied this in the past.
Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Sunday, October 20, 2013 5:03:26 AM
Subject: Re: [Nek5000-users] postx black window
Sorry to bother people in the list for this kind of naive question.
I tried postx on two computers, one my laptop, one cluster in my laboratory.
I got the same screen. It seems to be some graphics issue with the system.
You can find the screenshot attached here.
So what should I do? Thank you very much!
Tubois
On Sun, Oct 20, 2013 at 10:40 AM, < nek5000-users at lists.mcs.anl.gov > wrote:
Hi Paul,
Thank you for your response.
I already put PATH = ~/bin:$PATH in ~/.bashrc
running nekb is not a problem, the logfile gives the right results by using nekb or nekbmpi
so the computation is ok.
The question lies on postx
I typed postx on the command line, then a black window appears, on the top of which there is "Nekton".
but I do not see any sidebar
And on the terminal, it asks "Enter Session Name"
I left click the window with the cursor , and then "return" on the keyboard
it returns on the terminal
Enter Session Name
Beginning Session
renaming SESSION.NAME SESSION.NAME ~
Session name:
** ERROR ** Can't open file .rea
Enter Session Name
XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
after 235 requests (235 known processed) with 0 events remaining.
What is wrong here?
Thank you very much !
Tubois
On Sun, Oct 20, 2013 at 1:57 AM, < nek5000-users at lists.mcs.anl.gov > wrote:
The easiest thing is to copy the nekb script to your working directory.
There should also be a .soft file or something where you can add
PATH = ~/bin:$PATH
to get your bin directory into your path.
hth, Paul
Sent: Saturday, October 19, 2013 6:19:23 PM
Subject: [Nek5000-users] postx black window
Hello,
I am totally new to nek5000. I started with the pdf online to the case eddy_uv
The computation seems ok, when I check the tail, I got the same results as in the pdf online.
However, when I type postx
I just got a black window, without any sidebar menu.
In fact, when I compiled the tools in /nek5000_svn/trunck/tools/.
I typed ./maketools all
I got a lot of warnings, like
CALL ZWGJD (ZD,WD,NP,ALPHAD,BETAD)
1
Warning: Type mismatch in argument 'alpha' at (1); passed REAL(4) to REAL(8)
gfortran -mcmodel=medium -c mxm44f2.f
gcc -mcmodel=medium -c -DUNDERSCORE byte.c
gfortran -mcmodel=medium -c int_tp_gbox.f
int_tp_gbox.f:574.28:
But at the end, the compilation seems accomplished.
So what is wrong with my installation? Thank you very much!
Tubois Gao
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
