[Nek5000-users] postx black window
Sun Oct 20 03:40:15 CDT 2013
Hi Paul,
Thank you for your response.
I already put PATH = ~/bin:$PATH in ~/.bashrc
running nekb is not a problem, the logfile gives the right results by using
nekb or nekbmpi
so the computation is ok.
The question lies on postx
I typed postx on the command line, then a black window appears, on the top
of which there is "Nekton".
but I do not see any sidebar
And on the terminal, it asks "Enter Session Name"
I left click the window with the cursor , and then "return" on the keyboard
it returns on the terminal
Enter Session Name
 Beginning
Session
 renaming SESSION.NAME SESSION.NAME~
 Session
name:
 ** ERROR **  Can't open file .rea
Enter Session Name
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server
":0.0"
      after 235 requests (235 known processed) with 0 events remaining.
What is wrong here?
Thank you very much !
Tubois
On Sun, Oct 20, 2013 at 1:57 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> The easiest thing is to copy the nekb script to your working directory.
> There should also be a .soft file or something where you can add
> PATH = ~/bin:$PATH
> to get your bin directory into your path.
> hth, Paul
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Saturday, October 19, 2013 6:19:23 PM
> Subject: [Nek5000-users] postx black window
> Hello,
> I am totally new to nek5000. I started with the pdf online to the case
> eddy_uv
> The computation seems ok, when I check the tail, I got the same results as
> in the pdf online.
> However, when I type postx
> I just got a black window, without any sidebar menu.
> In fact, when I compiled the tools in /nek5000_svn/trunck/tools/.
> I typed ./maketools all
> I got a lot of warnings, like
> CALL ZWGJD (ZD,WD,NP,ALPHAD,BETAD)
> 1
> Warning: Type mismatch in argument 'alpha' at (1); passed REAL(4) to
> REAL(8)
> gfortran -mcmodel=medium -c mxm44f2.f
> gcc -mcmodel=medium -c -DUNDERSCORE byte.c
> gfortran -mcmodel=medium -c int_tp_gbox.f
> int_tp_gbox.f:574.28:
> But at the end, the compilation seems accomplished.
> So what is wrong with my installation? Thank you very much!
> Tubois Gao
> Nek5000-users mailing list
Ecole Polytechnique
Email; zhenlan.gao at polytechnique.edu
          zhenlan.gao at gadz.org
Addresse:  Chambre 5017,
                 Maison des Arts et Métiers,
                 1, avenue Pierre Massé
                 75014 Paris, France
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131020/bbf6874b/attachment-0001.html>
