[Nek5000-users] postx black window
Sat Oct 19 18:57:32 CDT 2013
The easiest thing is to copy the nekb script to your working directory.
There should also be a .soft file or something where you can add
PATH = ~/bin:$PATH
to get your bin directory into your path.
hth, Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Saturday, October 19, 2013 6:19:23 PM
Subject: [Nek5000-users] postx black window
Hello,
I am totally new to nek5000. I started with the pdf online to the case eddy_uv
The computation seems ok, when I check the tail, I got the same results as in the pdf online.
However, when I type postx
I just got a black window, without any sidebar menu.
In fact, when I compiled the tools in /nek5000_svn/trunck/tools/.
I typed ./maketools all
I got a lot of warnings, like
CALL ZWGJD (ZD,WD,NP,ALPHAD,BETAD)
1
Warning: Type mismatch in argument 'alpha' at (1); passed REAL(4) to REAL(8)
gfortran -mcmodel=medium -c mxm44f2.f
gcc -mcmodel=medium -c -DUNDERSCORE byte.c
gfortran -mcmodel=medium -c int_tp_gbox.f
int_tp_gbox.f:574.28:
But at the end, the compilation seems accomplished.
So what is wrong with my installation? Thank you very much!
Tubois Gao
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
