[Nek5000-users] Variable density flows
Sun Oct 13 00:05:36 CDT 2013
You can also try error function like profile with 0 value at the inlet and increases to a peak somewhere and stays constant up to the exit so gradient is0 at the exit
Insulation normally refers to the diffusive flux (first form)
Ammar
Sent from my iPhone
> On Oct 12, 2013, at 11:50 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Yes Ammar, I get oscillatory solutions with the discontinuous bc. I will try your suggestion.
> When we specify insulated bc 'I' for an advected-diffused scalar c, does it make
> grad(c).n = 0
> or
> (u.n)c - D*grad(c).n = 0
> If I want to implement the second case, what should I do ?
> Thanks
> praveen
>> On Sun, Oct 13, 2013 at 10:11 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> The c=0 bc Is not consistent with the initial condition. You are generating a big error at t=0 that persists throughout your simulation. My understanding is you want to simulate the dispersion of a scalar that is already injected in a flow at t=0 right?  I would spatially localize the concentration so that it decays to 0 at the inflow boundary ..a Gaussian exp(- x-a)^2) is a good candidate for your initial conditions
>> Ammar
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131013/b508d152/attachment.html>
