[Nek5000-users] Variable density flows
Sat Oct 12 23:07:21 CDT 2013
Thanks Ammar for the help. My channel is quite long so I can use the 'ON'
boundary condition at outlet for the passive scalar. I have a scalar
equation
c_t + u.grad(c) = div(D*grad(c))
with
c = 1 as initial condition
I want to use inlet bc
c = 0 at x=0 (inlet)
but this leads to a discontinuous initial condition. Is it ok to use such
bc ?
To avoid specifying such dirichlet bc, I tried to use zero flux bc for c at
inlet but then c did not change with time at all.
Thanks
praveen
On Sun, Oct 13, 2013 at 12:34 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> If you are to use outflow BCs' at the channel exit plane it should be
> located sufficiently far from the inlet (i.e. the channel length long
> enough) to allow the flow and scalars to be fully developed d phi /dx =0
> Insulation is usually used at solid walls where there is no gradient in
> the wall normal direction (no heat or mass flow across the boundary) so it
> works for temperature and scalars.
> try to at least check on mass conservation in an integral sense..
> Ammar
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131013/38761be7/attachment.html>
