[Nek5000-users] Prenek and Genbox - Maketools problems
Fri May 24 19:34:15 CDT 2013
Hi JP,
I have update the nek5_svn/trunk/tools to reflect the shell script change
and to fix the genbox bug.  If you could update your tools and do a
"./maketools clean; ./maketools all" things should be working better.
I have not been able to replicate the prenek error, but the error message, :
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
      after 153 requests (153 known processed) with 0 events remaining.
Usually just means that X11 was closed in a non-standard way.
If you are still having prenek issues, could you explain to me what isn't
working, or what happens when you try to start a session?
Katie
On Thu, May 23, 2013 at 4:35 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Katie,
> Yes thanks, the problem when compiling is solved. I imagined it was
> something related to bash but it didn't cross my mind to check the makefile.
> Unfortunately the errors with genbox (when trying to output a .re2 file)
> and prex (the errors I mentioned + interface does not work well) still
> remain (even after re-making the tools).
> Thanks,
> JP
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130524/776b7927/attachment.html>
