[Nek5000-users] troubles with examples
Fri May 24 14:56:04 CDT 2013
Hello everybody,
I am a new nek5000 user. I have just successfully compiled the package
(on my 64 bit ubuntu) and run the examples: turbChannel, vortex,
turbJet. Now, although the executable seems to solve the problems (the
display outputs look reasonable), the output files with *.fldxxxx etc
contain only zeros (I can see that using postnek). Moreover, at the end
of the run (vortex), at the summary, the output that appears on the
display is as in the attachment (only zeros).
Many thanks in advance,
Barak Galanti
    40021 U-PRES gmres:      1  5.8090E-16  1.0000E-07  7.9965E-16  0.0000E+00  0.0000E+00
       40021  DNORM, DIVEX   9.6826759533351624E-015   5.8090008701096374E-016
      40021   2.0010E+03  0.0000E+00 Fluid done
    40021  2.001050E+03 -7.958699E-03 VMIN
 call outfld: ifpsco: F
    40021  2.0010E+03 Write checkpoint:
    40021  2.0010E+03 OPEN: r1854a.fld202
end of time-step loop
runtime statistics:
 total time   9.9999999999999995E-008
 inv3 time      161934   0.0000000000000000        0.0000000000000000
 invc time           0   0.0000000000000000        0.0000000000000000
 mltd time      605865   0.0000000000000000        0.0000000000000000
 cdtp time      605865   0.0000000000000000        0.0000000000000000
 eslv time       40021   0.0000000000000000        0.0000000000000000
 pres time       40021   0.0000000000000000        0.0000000000000000
 crsl time       41880   0.0000000000000000        0.0000000000000000
 crsl min    0.0000000000000000
 crsl max    0.0000000000000000
 crsl avg    0.0000000000000000
 hmhz time           6   0.0000000000000000        0.0000000000000000
 spro time       40022   0.0000000000000000        0.0000000000000000
 usbc time       40021   0.0000000000000000        0.0000000000000000
 usbc min    0.0000000000000000
 usbc max    0.0000000000000000
 usb  avg    0.0000000000000000
 axhm time      888174   0.0000000000000000        0.0000000000000000
 advc time       40021   0.0000000000000000        0.0000000000000000
 vdss time      161935   0.0000000000000000        0.0000000000000000
 vdss min    0.0000000000000000
 vdss max    0.0000000000000000
 vdss avg    0.0000000000000000
 dsum time      893746   0.0000000000000000        0.0000000000000000
 dsum min    0.0000000000000000
 dsum max    0.0000000000000000
 dsum avg    0.0000000000000000
 dadd time           0   0.0000000000000000        0.0000000000000000
 ddsl time       41880   0.0000000000000000        0.0000000000000000
 solv time       41880   0.0000000000000000        0.0000000000000000
 prep time       40022   0.0000000000000000        0.0000000000000000
#  nid       tusbc       tdadd       tcrsl       tvdss       tdsum        tgop    qqq    F
           0  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 qqq
           1  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 qqq
           2  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 qqq
           3  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 qqq
call exitt: dying ...
backtrace(): obtained 5 stack frames.
./nek5000(print_stack_+0x18) [0x50e8f8]
./nek5000(exitt_+0x1d0) [0x5fa6a0]
./nek5000(main+0x3b) [0x41ae8b]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fe09c09376d]
./nek5000() [0x41aebd]
total elapsed time             :   0.00000E+00 sec
total solver time incl. I/O    :   0.00000E+00 sec
time/timestep                  :   0.00000E+00 sec
CPU seconds/timestep/gridpt    :   0.00000E+00 sec
