[Nek5000-users] Maintaining order of perturbation
Wed May 15 18:29:10 CDT 2013
To add more, I found that near to the element boundary if I do the
averaging(dsavg()) the order cannot be maintained at those grid points.
Sayed
> Hi Paul,
> Sorry, I should have written it in more details.
> I have the base flow u_{base} calculated, already continuous across the
> elements. Now, I am trying to add perturbation doing to the base flow: u =
> u_{base}+\epsilon*u_{perturb} at each time-step. \epsilon being the order
> (e,g 10^-08) and u_{perturb} varies from 0 to 1 on each grid points.
> Best
> Sayed
>> Hi Sayed,
>> When you say it changed the order, how do you mean?
>> It should indeed just averaged the interface values, so it
>> should be of the same order as the initial perturbation.
>> Paul
>> On Tue, 14 May 2013, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi all,
>>> I want to add perturbation of specific order (e.g. 10^-08) to the whole
>>> velocity field at each time-step. The velocity and pressure are both
>>> considered on GLL points. After adding perturbation, to have velocity
>>> as
>>> continuous function across the elements dsavg() is called (I found the
>>> info in one of the threads). I think it changes the order of
>>> perturbation
>>> near to the element boundary. I was wondering if there is other way to
>>> do
>>> so.
>>> This is my first mail to the group and I am using the code for my
>>> thesis.
>>> Thanks in advance!
>>> Best regards,
>>> Sayed
>>> MSc. COSSE
>>> KTH, Sweden
>>> FAU-Erlangen,Germany
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
