[Nek5000-users] trouble with visit
Wed Mar 20 11:01:43 CDT 2013
Just  wondering what this reader is doing when you have the same extension .00001 for all four files..would f%05d still work? I imagine , at least, that it will have problem looping over your files
filetemplate: epsG1_64%d.f%05d
firsttimestep: 1
numtimesteps: 1
Ammar
On Mar 20, 2013, at 10:58 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> I will check. The same worked for smaller grids.
> epst and epsv are positive definite.
> It is probably a visit problem.
> Best regards, Joerg.
> Am 20.03.2013 um 16:49 schrieb nek5000-users at lists.mcs.anl.gov:
>> Hi Joerg,
>> The first " 4 " indicates that the data is output in 4-byte (32-bit)
>> format.
>> My guess is that there might be a problem with the raw data
>> in the fields that are being written.  For example, what is
>> the sign of epst() ?  Is it guaranteed to be positive ?
>>     do i=1,n
>>        epst(i)=log(epst(i)+tiny)
>>        epsv(i)=log(epsv(i)+tiny)
>>     enddo
>> Paul
>> On Wed, 20 Mar 2013, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Paul,
>> I didn't understand what Justin meant.
>> The first line in all output files looks like this:
>> #std 4 12 12 12      64000     256000   .2165378385933E+03      5000
>> 2      4 XU
>> Thanks Joerg.
>>> Hi Joerg,
>>> Did you try Justin's suggestion of looking at your header?
>>> It probably already is 32-bit ? Â  (This would normally be
>>> the case.)
>>> Perhaps the output data is corrupted, e.g., nans or whatever...?
>>> Paul
>>> ----- Original Message -----
>>> From: nek5000-users at lists.mcs.anl.gov
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Sent: Wednesday, March 20, 2013 10:03:10 AM
>>> Subject: Re: [Nek5000-users] trouble with visit
>>> p63 is set to zero and it still does not work
>>> Joerg
>>> Am 20.03.2013 um 14:47 schrieb nek5000-users at lists.mcs.anl.gov:
>>>> It looks like setting p63=0 should take care of that...
>>>> Paul
>>>>> Hi Paul,
>>>> how can I set up the single precision output?
>>>> best regards, Joerg.
>>>>> Hi Joerg,
>>>>> Normally the output is indeed in single precision.
>>>>> It's not clear to me the double-precision + visit
>>>>> is working - but I've been a bit out of the loop
>>>>> on this.
>>>>> Paul
>>>>>> Hi Neks,
>>>>>> I am facing problems with the visualization in visit.
>>>>>> The output of the three scalar fields uzt, epst, epsv
>>>>>> is done is seen in the following line from my usr file.
>>>>>> Here, I wrote the data into four files (see further below).
>>>>>> I also attach the visit  script
>>>>>> !-------usr file-------------------------------------------------
>>>>>> Â  Â  Â  tiny=1.e-16
>>>>>> Â  Â  Â  do i=1,n
>>>>>> Â  Â  Â  Â epst(i)=log(epst(i)+tiny)
>>>>>> Â  Â  Â  Â epsv(i)=log(epsv(i)+tiny)
>>>>>> Â  Â  Â  enddo
>>>>>> !-------No pressure field, no scalar output
>>>>>> Â  Â  Â  ifpo=.false.
>>>>>> Â  Â  Â  ifto=.false.
>>>>>> Â  Â  Â  call outpost2( uzt,epst,epsv,pr,t,0,'eps')
>>>>>> Â  Â  Â  ifpo=.true.
>>>>>> Â  Â  Â  ifto=.true.
>>>>>> !-------Visit script------------------------------------------------
>>>>>> NEK5000
>>>>>> version: 1.0
>>>>>> firsttimestep: 1
>>>>>> numtimesteps: 1
>>>>>> !-------the four files that have to be load into visit and which make up one snapshot--------------
>>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:03 epsG1_640.f00001
>>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:09 epsG1_641.f00001
>>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:16 epsG1_642.f00001
>>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:22 epsG1_643.f00001
>>>>>> -rw-r----- 1 josc1234 linux         87 20. Mär 13:37 vis.nek5000
>>>>>> !-------This is the error message in visit---------------------------------------
>>>>>> The compute engine running on makalu51.rz.tu-ilmenau.de has exited abnormally.
>>>>>> Shortly thereafter, the following occured...
>>>>>> The Pseudocolor plot of "y_velocity" for the file "/usr/wrk/people4/josc1234/nek5_visit/r095_Lx1_12_Ra1e8/vis.nek5000" could not be generated by the compute engine on host "localhost".
>>>>>> My questions:
>>>>>> Could it be that the graphics output should be in single precision?
>>>>>> I saw that the people at KTH did have similar trouble.
>>>>>> If yes, how can I switch to single precision in the usr file output?
>>>>>> For smaller grid it worked.
>>>>>> Thanks in advance, Joerg.
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users_______________________________________________
