[Nek5000-users] trouble with visit
Wed Mar 20 10:58:08 CDT 2013
Hi Paul,
I will check. The same worked for smaller grids.
epst and epsv are positive definite.
It is probably a visit problem.
Best regards, Joerg.
Am 20.03.2013 um 16:49 schrieb nek5000-users at lists.mcs.anl.gov:
> Hi Joerg,
> The first " 4 " indicates that the data is output in 4-byte (32-bit)
> format.
> My guess is that there might be a problem with the raw data
> in the fields that are being written.  For example, what is
> the sign of epst() ?  Is it guaranteed to be positive ?
>      do i=1,n
>         epst(i)=log(epst(i)+tiny)
>         epsv(i)=log(epsv(i)+tiny)
>      enddo
> Paul
> On Wed, 20 Mar 2013, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
> I didn't understand what Justin meant.
> The first line in all output files looks like this:
> #std 4 12 12 12      64000     256000   .2165378385933E+03      5000
> 2      4 XU
> Thanks Joerg.
>> Hi Joerg,
>> Did you try Justin's suggestion of looking at your header?
>> It probably already is 32-bit ? Â  (This would normally be
>> the case.)
>> Perhaps the output data is corrupted, e.g., nans or whatever...?
>> Paul
>> ----- Original Message -----
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov
>> Sent: Wednesday, March 20, 2013 10:03:10 AM
>> Subject: Re: [Nek5000-users] trouble with visit
>> p63 is set to zero and it still does not work
>> Joerg
>> Am 20.03.2013 um 14:47 schrieb nek5000-users at lists.mcs.anl.gov:
>>> It looks like setting p63=0 should take care of that...
>>> Paul
>>>> Hi Paul,
>>> how can I set up the single precision output?
>>> best regards, Joerg.
>>>> Hi Joerg,
>>>> Normally the output is indeed in single precision.
>>>> It's not clear to me the double-precision + visit
>>>> is working - but I've been a bit out of the loop
>>>> on this.
>>>> Paul
>>>>> Hi Neks,
>>>>> I am facing problems with the visualization in visit.
>>>>> The output of the three scalar fields uzt, epst, epsv
>>>>> is done is seen in the following line from my usr file.
>>>>> Here, I wrote the data into four files (see further below).
>>>>> I also attach the visit  script
>>>>> !-------usr file-------------------------------------------------
>>>>> Â  Â  Â  tiny=1.e-16
>>>>> Â  Â  Â  do i=1,n
>>>>> Â  Â  Â  Â epst(i)=log(epst(i)+tiny)
>>>>> Â  Â  Â  Â epsv(i)=log(epsv(i)+tiny)
>>>>> Â  Â  Â  enddo
>>>>> !-------No pressure field, no scalar output
>>>>> Â  Â  Â  ifpo=.false.
>>>>> Â  Â  Â  ifto=.false.
>>>>> Â  Â  Â  call outpost2( uzt,epst,epsv,pr,t,0,'eps')
>>>>> Â  Â  Â  ifpo=.true.
>>>>> Â  Â  Â  ifto=.true.
>>>>> !-------Visit script------------------------------------------------
>>>>> NEK5000
>>>>> version: 1.0
>>>>> filetemplate: epsG1_64%d.f%05d
>>>>> firsttimestep: 1
>>>>> numtimesteps: 1
>>>>> !-------the four files that have to be load into visit and which make up one snapshot--------------
>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:03 epsG1_640.f00001
>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:09 epsG1_641.f00001
>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:16 epsG1_642.f00001
>>>>> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:22 epsG1_643.f00001
>>>>> -rw-r----- 1 josc1234 linux         87 20. Mär 13:37 vis.nek5000
>>>>> !-------This is the error message in visit---------------------------------------
>>>>> The compute engine running on makalu51.rz.tu-ilmenau.de has exited abnormally.
>>>>> Shortly thereafter, the following occured...
>>>>> The Pseudocolor plot of "y_velocity" for the file "/usr/wrk/people4/josc1234/nek5_visit/r095_Lx1_12_Ra1e8/vis.nek5000" could not be generated by the compute engine on host "localhost".
>>>>> My questions:
>>>>> Could it be that the graphics output should be in single precision?
>>>>> I saw that the people at KTH did have similar trouble.
>>>>> If yes, how can I switch to single precision in the usr file output?
>>>>> For smaller grid it worked.
>>>>> Thanks in advance, Joerg.
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users_______________________________________________
