[Nek5000-users] genmap, ABORT: SELF-CHK
Wed Jun 26 08:38:43 CDT 2013
Hi Holly,
To the best of my knowledge, we solved this problem for Frank.
The error usually indicates a problem with the mesh.  If you'd like,
email me off-list (fischer at mcs.anl.gov) and we can figure out a way
to get your mesh to me - email, if it's small enough - and I can take
a look.
Paul
On Wed, 26 Jun 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> Frank, did you ever find the solution to this error? I have the same problem.
> Thank you for your help,
> Holly Johnson
> Masters Student at ONERA - DAFE
> Département d'Aéronautique Fondamentale et Expérimentale
> 8, Rue des Vertugadins
> 92190 - Meudon - France
> On Apr 29, 2010, at 5:23 PM,nek5000-users at lists.mcs.anl.gov
> <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>  wrote:
> />Hello all,
>> I am running into a problem with "genmap", see error below.  My *.rea
>> file that I feed to "genmap" is:
>> http://tetra.fluid.tuwien.ac.at/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/sim11/openboat3D.rea
>> [root at frank  <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>> sim11]# genmap
>> Input (.rea) file name:
>> openboat3D
>> Input mesh tolerance (default 0.2):
>> NOTE: smaller is better, but generous is more forgiving for bad meshes.
>> .2
>>  reading .rea file data ...
>>  start locglob_lexico:           8           1           8
>> 0.200000000000000
>>  locglob:           1           1           8
>>  locglob:           2           2           8
>>  locglob:           3           4           8
>>  locglob:           1           8           8
>>  locglob:           2           8           8
>>  locglob:           3           8           8
>>  locglob:           1           8           8
>>  locglob:           2           8           8
>>  locglob:           3           8           8
>>  done locglob_lexico:         8         8         8         1
>>  start periodic vtx:           1           8
>>          1 5  5  3  0.00000000E+00        1 shift
>>          1 6  5  3  0.00000000E+00        2 shift
>>      1     2     4  Matrix:  SELF!!
>>        1 SELF!!        1        2        1        2
>>        2 SELF!!        3        4        3        4
>>  ABORT: SELF-CHK            1           5           1           6
>>  Try to tighten the mesh tolerance!
>>            6  quit
>> Cheers,
>> Frank
>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>> Technische Universität Wien (Technical University of Vienna)
>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>> Mechanics and Heat Transfer)
>> Resselgasse 3
>> 1040 Wien
>> Tel: +4315880132232
>> Fax: +4315880132299
>> Cell:+436765203470
>> fmuldoo (skype)
>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html/
