[Nek5000-users] genmap, ABORT: SELF-CHK
Wed Jun 26 08:22:17 CDT 2013
Hi Neks,
Frank, did you ever find the solution to this error? I have the same problem.
Thank you for your help,
Holly Johnson
Masters Student at ONERA - DAFE
Département d'Aéronautique Fondamentale et Expérimentale
8, Rue des Vertugadins
92190 - Meudon - France
On Apr 29, 2010, at 5:23 PM,nek5000-users at lists.mcs.anl.gov  <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>  wrote:
/>Hello all,
>I am running into a problem with "genmap", see error below.  My *.rea
>file that I feed to "genmap" is:
>http://tetra.fluid.tuwien.ac.at/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/sim11/openboat3D.rea
>[root at frank  <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>  sim11]# genmap
>Input (.rea) file name:
>openboat3D
>Input mesh tolerance (default 0.2):
>NOTE: smaller is better, but generous is more forgiving for bad meshes.
>.2
>  reading .rea file data ...
>  start locglob_lexico:           8           1           8
>0.200000000000000
>  locglob:           1           1           8
>  locglob:           2           2           8
>  locglob:           3           4           8
>  locglob:           1           8           8
>  locglob:           2           8           8
>  locglob:           3           8           8
>  locglob:           1           8           8
>  locglob:           2           8           8
>  locglob:           3           8           8
>  done locglob_lexico:         8         8         8         1
>  start periodic vtx:           1           8
>          1 5  5  3  0.00000000E+00        1 shift
>          1 6  5  3  0.00000000E+00        2 shift
>      1     2     4  Matrix:  SELF!!
>        1 SELF!!        1        2        1        2
>        2 SELF!!        3        4        3        4
>  ABORT: SELF-CHK            1           5           1           6
>  Try to tighten the mesh tolerance!
>            6  quit
>Cheers,
>Frank
>Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>Technische Universität Wien (Technical University of Vienna)
>Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>Mechanics and Heat Transfer)
>Resselgasse 3
>1040 Wien
>Tel: +4315880132232
>Fax: +4315880132299
>Cell:+436765203470
>fmuldoo (skype)
>http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html/
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130626/496106b4/attachment.html>
