[Nek5000-users] Writing 2d output files for 3d data
Tue Jun 25 06:28:09 CDT 2013
Hi Janet,
I think that z_slice() and outfld2d would be reasonable
starting points.
As I look at the code, z_slice takes element 1, slice 1
in the z direction.   You would want to generalize this.
Also, it looks outfld2d() is set up only for ascii output
at the moment.   I would suggest conversion to binary.
I can take a pass at making these changes but will not have
time to verify functionality for a few days.  I could however
work with you on that.
Paul
On Tue, 25 Jun 2013, nek5000-users at lists.mcs.anl.gov wrote:
> We are generating huge 3d data files (>8GB with multiple I/O) which are so
> large, our version of visit does not have enough memory to load them.
> Oftentimes we only want to visualize a 2d slice anyway. Is there a routine
> in nek5000 that does this? Or one that can be easily modified? To be more
> specific, we want to output, for example, the coordinates and the velocity
> field for some fixed z-value, into a blah.f00001 file that can then be read
> by visit.
> Thanks,
> Janet
> Janet Scheel
> Assistant Professor of Physics
> Occidental College
> 1600 Campus Road, M21
> Los Angeles, CA 90041
> (323) 259-2777
> jscheel at oxy.edu
