[Nek5000-users] Nek5000 maketools compile error
Thu Jan 24 01:22:58 CST 2013
Hi Josh,
That worked for me (after some additional workarounds with the lack of X11 on Mountain Lion). I would be curious to hear what the reason for the issue was on the new OS-- I did not have any similar problems on 10.6.
Thanks!
Kyle
On Jan 23, 2013, at 9:15 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Kyle,
> I have a Mac as well, and I think what I had to do to get the tools to compile correctly was to disable big memory support.  In the maketools script, simply comment out the BIGMEM="true" line and see if that works.
> Josh
> On Wed, Jan 23, 2013 at 4:32 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Neks,
> I just upgraded to a MacBook Pro running Mountain Lion on an i7 (with gcc, gfortran), and I am trying to move my Nek installation over. When I run the maketools all script, I get:
> gcc -mcmodel=medium  -c -DUNDERSCORE ../../nek/byte.c
> gfortran -mcmodel=medium -fdefault-real-8 -o /Users/felker/bin/genmap genmap.o byte.o
> ld: in section __TEXT,__text reloc 61: length != 2 and X86_64_RELOC_GOT not supported for architecture x86_64
> collect2: ld returned 1 exit status
> make[1]: *** [genmap] Error 1
> make: *** [all] Error 1
> I found that someone else had this error:
> http://lists.mcs.anl.gov/pipermail/nek5000-users/2012-June/001843.html
> but there did not appear to be any solution reported. Is there a workaround?
> Best,
> Kyle
> Nek5000-users mailing list
> Josh Camp
> "All that is necessary for the triumph of evil is that good men do nothing" -- Edmund Burke
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130124/03ec2a89/attachment.html>
