[Nek5000-users] mesh problems
Mon Jan 14 12:34:28 CST 2013
Hi Paul,
thanks a lot.
1/ we used the AMG preconditioner since it should scale better for bigger processor numbers.
I remember of having long waiting times at the beginning with the XXt. I will check it out.
2/ I got about 80 disconnected elements while running genmap. How many did you get? I will repeat
the run with tol=0.1.
3/ did you use my file y5.rea and my file zpts_compare?
4/ did you have to enforce the outer elements to radius r=0.5 in the usrdat?
Janet and Joerg.
Am 14.01.2013 um 17:52 schrieb nek5000-users at lists.mcs.anl.gov:
>> I faced the same trouble with 2.17 million elements. Let me follow your
>> suggestion and set up a mesh in cell with z between 0 and 3 while keeping the
>> x-y mesh exactly the same, just to check if the same errors occur.
> Hi Joerg,
> I had no problems with the 2.17 million case.
> I ran it with P=32768 and the XXt solver.
> When I ran genmap, I used a tolerance of .01 --- this can
> be important for certain classes of meshes.  If the genmap tolerance
> is too loose then it's conceivable that you can have spurious
> connectivities in the graph that represents the sparse matrices,
> which might be the source of the problem you encountered.
> Paul
> Nek5000-users mailing list
