[Nek5000-users] turbJet problem
Sun Dec 8 13:26:55 CST 2013
Hi Tanmoy,
I have divided by 4 and again my run stopped at iteration 1200. My
question is: does nek5000 have variable time-stepping?
Barak
On 12/07/2013 08:37 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Barak,
> it is because of the fact that the generated file format is probably not
> readable in visit. In the *usrchk* subroutine in your .usr file write
> these 2 lines
> param(66) = 4
> param(67) = 4
> before the end of the routine
> Then compile and execute your program. Now you will get output files in
> the form of turbJet.fld001, turbJet.fld002, ...and so on.
> type in visnek turbJet in your terminal, and generate *turbJet.nek5000*.
> This .nek5000 file can be read by visit.
> Thanks,
> Tanmoy
> On Sat, Dec 7, 2013 at 10:33 AM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi Tanmoy,
>     Many thanks. It seems that after dividing by 4 (dt=0.005) it runs
>     and I get output files in the form jet0.fxxxxx .
>     Now I am trying to visualize them using the precompiled ubuntu11
>     version of visit. Unfortunately, I get the following error:
>       VisIt could not read from the file
>     "/home/galanti/COMPUTATION/__NEK5000/nek5_svn/TEST-__examples/turbJet/jet0.f*
>     database".
>     The generated error message was:
>     There was an error opening
>     database. It may be an invalid file.  VisIt tried using the
>     following file format readers to open the file: Nek5000
>     The following error(s) may be helpful in identifying the problem:
>     When attempting to use "Nek", the file matched the general format
>     expected by the reader but eventually encountered this error: "A tag
>     called filetemplate: must be specified".
>     What's wrong?
>     Many thanks again,
>     Barak
>     On 12/07/2013 12:42 AM, nek5000-users at lists.mcs.anl.__gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>         Hi Barak,
>         It is a problem with numerical Stability. Decrease DT  in your
>         .rea file
>         until the simulations become stable. You could start with 1/2 DT to
>         check if simulation is stable, other wise go for 1/4 DT, and
>         check with
>         this simple test.
>         Thanks,
>         Tanmoy
>         On Fri, Dec 6, 2013 at 3:31 PM,
>         <nek5000-users at lists.mcs.anl.__gov
>         <mailto:nek5000-users at lists.__mcs.anl.gov
>         <mailto:nek5000-users at lists.mcs.anl.gov>>> wrote:
>              Hello,
>              I am testing the example turbJet, and it seems that I have some
>              problem with output. This are the output files:
>              jet0.f00001
>              Moreover, the ran stops with emergency exit at time 5.64
>         (CFL too
>              large?):
>                       282  DNORM, DIVEX   6.2789891850172769E-004
>              8.4967723454134898E-006
>                       282   5.6400E+00  1.1065E+01 Fluid done
>                  282  5.6400000E+00  1.1955953E-03  6.4269380E-04
>           9.9999991E-01 e2
>                t max/min:   0.0000000000000000        0.0000000000000000
>                CFL, Ctarg!   22.504301079496056        2.0000000000000000
>                call outfld: ifpsco: T
>                     283  5.6400E+00 Write checkpoint:
>                      0     283 OPEN: jet0.f00001
>                     283  5.6400E+00 done :: Write checkpoint
>                                             file size =      55.    MB
>                                             avg data-throughput =
>         572.1MB/s
>                                             io-nodes =     1
>                          7  Emergency exit:         283    time =
>              5.6399999999999677
>                 Latest solution and data are dumped for post-processing.
>                 *** STOP ***
>                          3  Emergency exit:         283    time =
>              5.6399999999999677
>                 *** STOP ***
>                          5  Emergency exit:         283    time =
>              5.6399999999999677
>                 *** STOP ***
>                          0  Emergency exit:         283    time =
>              5.6399999999999677
>                 *** STOP ***
>                          6  Emergency exit:         283    time =
>              5.6399999999999677
>                 *** STOP ***
>                          4  Emergency exit:         283    time =
>              5.6399999999999677
>                 *** STOP ***
>                          2  Emergency exit:         283    time =
>              5.6399999999999677
>                 *** STOP ***
>                          1  Emergency exit:         283    time =
>              5.6399999999999677
>              Thank you,
>              Barak
>              ___________________________________________________
>              Nek5000-users mailing list
>              Nek5000-users at lists.mcs.anl.____gov
>              <mailto:Nek5000-users at lists.__mcs.anl.gov
>         <mailto:Nek5000-users at lists.mcs.anl.gov>>
>         https://lists.mcs.anl.gov/____mailman/listinfo/nek5000-users
>         <https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users>
>         <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>__>
>         Nek5000-users at lists.mcs.anl.__gov
