[Nek5000-users] neuman bc for the normal velocity component
Tue Sep 25 12:46:29 CDT 2012
Hi Paul,
thanks a lot for your help. Now I understand why 'ON ' did
not work. The inviscid flow we're trying to compute
the boundary layer to is a pulse which first has
v > 0 (outflow) and then after the crest has passed v < 0
(inflow). Therefore 'ON ' did not work.
I helped myself by imposing U_base and V_bl
on the top boundary, where U_base is the
inviscid base flow and V_bl the normal
velocity computed by a boundary layer solver.
However, just for the fun, do you think imposing
u = U_base and dv/dy = - dU_base/dx
on the top boundary would work in this case?
Thanks a lot!
Joris
2012/9/25 <nek5000-users at lists.mcs.anl.gov>
> Hi Joris,
> The usage you describe should work.
> I've put an example "blasius" in the examples directory.
> Note that a common failure mode is where fluid is drawn _in_
> to the domain through the ON boundary.  This can happen if
> the pressure is such that flow wants to come in rather than
> leave.
> However, from what you describe, it sounds as if something
> else is going wrong in your case.  Perhaps looking at the
> example will help.
> Paul
> On Thu, 20 Sep 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>  Dear Nekians,
>> I'm relatively new to nek.
>> I would like to
>> compute the flow of a boundary layer and
>> I would like to impose the following
>> boundary condition on the top (2D) boundary,
>> which is parallel to the wall:
>> u = U_base and dv/dy = - dU_base/dx,
>> where U_base is the known inviscid base flow.
>> The velocity component u is parallel to
>> the boundary, whereas v is normal.
>> I tried to use 'ON ' but this did not give
>> the result I was expecting (Am I doing smth. wrong?).
>> At the boundary nodes u was equal to U_base, but
>> at the very next node u was completly different
>> (and v was of course completly wrong).
>> Thanks for any help
>> Joris
>> ______________________________**_________________
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120925/7d64489c/attachment.html>
