[Nek5000-users] Area integral calculation in Nek
Thu Oct 18 14:15:21 CDT 2012
Hi Paul,
> Looks good.  One thing to note that nz1 is variable and not a parameter,
> so there will be an issue with the fbar() declaration.
> I would suggest using lz1 and lelz for declaration of fbar(),
> etc., as these parameters are already established for that role.
change to lz1 is fine.
I run in trouble whenever I use lelz.
The attached version works.
       subroutine vertical_mean(ff)
      include 'SIZE'
      include 'TOTAL'
!      include 'ZPER'
      integer nelz
      parameter(nelz=32)
      real ff(lx1,ly1,lz1,lelt)
!      common /scruz/ fbar(lz1,lelz),wght(lz1,lelz),work(lz1,lelz)
      real fbar(lz1,nelz)
      real wght(lz1,nelz)
      real work(lz1,nelz)
      integer e,eg,ex,ey,ez,f
!      lelz=32
!      nelz=32
      nelxy = nelgv/nelz
!-----Set both arrays to zero
      call rzero(fbar,lz1*nelz)
      call rzero(wght,lz1*nelz)
!-----Pick face 5 to evaluate surface Jacobian
      f = 5
      do e=1,nelv
         eg = lglel(e)
         call get_exyz(ex,ey,ez,eg,nelxy,1,nelz)
         do k=1,nz1
           do i=1,nx1*ny1
             fbar(k,ez) = fbar(k,ez)+area(i,1,f,e)*ff(i,1,k,e)
             wght(k,ez) = wght(k,ez)+area(i,1,f,e)
           enddo
         enddo
      enddo
!-----Gather over all processes (-> mpi_allreduce)
      call gop(fbar,work,'+  ',lz1*nelz)
      call gop(wght,work,'+  ',lz1*nelz)
!-----Area average
      do i=1,lz1*nelz
        fbar(i,1)=fbar(i,1)/wght(i,1)
      enddo
!-----Output of the vertical profile of plane averages
!     Example with 32 (=nelz) vertical elements and lx1=ly1=lz1=4:
!      -> 2 internal vertical GLL points per element
!      -> 97 vertical planes, here output of 96
      if(nid.eq.0)then
        OPEN(10,file="uzt.dat",access="append")
        do k=1,nelz
        do i=1,lz1-1
          write(10,*)fbar(i,k),wght(i,k)
        enddo
        enddo
        CLOSE(10)
      endif
      return
      end
Thanks Joerg.
> I think the issue you ran into before was that I failed to include
> ZPER in the include statement, which is how nelz becomes known
> to the routine.  (It remains, however, up to the user to set
> nelz and lelz to the proper values.)
> Also, I often find it handy to define a "zbar()" which computes
> the mean of z and then prints this out along with fbar and wght.
> That makes it easy to plot (zbar,fbar), etc.
> Cheers,
> Paul
> On Thu, 18 Oct 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> I attach a version with two corrections. This one should work now correctly.
>> Thanks once more.
>> Joerg.
>>     subroutine vertical_mean_profile(ff)
>>     include 'SIZE'
>>     include 'TOTAL'
>>     integer nelz
>>     parameter(nelz=32)
>>     real ff(nx1,ny1,nz1,nelv)
>>     real fbar(1:nz1,1:nelz)
>>     real wght(1:nz1,1:nelz)
>>     real work(1:nz1,1:nelz)
>>     nelxy = nelgv/nelz
>>     call rzero(fbar,nz1*nelz)
>>     call rzero(wght,nz1*nelz)
>>     f = 5
>>     do e=1,nelv
>>        eg = lglel(e)
>>        do k=1,nz1
>>          do i=1,nx1*ny1
>>          enddo
>>        enddo
>>     enddo
>>     call gop(fbar,work,'+  ',nz1*nelz)
>>     call gop(wght,work,'+  ',nz1*nelz)
>> !-----Area average
>>     do i=1,nz1*nelz
>>     enddo
>> !-----Output of the vertical profile of planar averages
>>     if(nid.eq.0)then
>>       do k=1,nelz
>>       do i=1,nz1-1
>>       enddo
>>       enddo
>>     endif
>>     return
>>     end
>> Am 15.10.2012 um 22:15 schrieb nek5000-users at lists.mcs.anl.gov:
>>> Hi Joerg,
>>> If your geometry came from n2to3, then your data
>>> is organized into planar sections and you can compute
>>> F(z) =   |  f(x,y,z) dx dy
>>>          /A
>>> as follows:
>>>     nelz  = [how many levels you have in z]
>>>     nelxy = nelgv/nelz ! Number of elements in a plane
>>>     f = 5  ! Pick face 5 to evaluate surface Jacobian
>>>     do e=1,nelv
>>>        eg = lglel(e)
>>>        call get_exyz(ex,ey,ez,eg,nelxyz,1,nelz)
>>>        do k=1,nz1
>>>        do i=1,nx1*ny1
>>>           fbar(k,ez) = fbar(k,ez)+area(i,f,e)*f(i,1,k,e)
>>>           wght(k,ez) = wght(k,ez)+area(i,f,e)
>>>        enddo
>>>        enddo
>>>     enddo
>>>     call gop(fbar,work,'+  ',nz1*nelv)
>>>     call gop(wght,work,'+  ',nz1*nelv)
>>>     do i=1,nz1*nelz
>>>        fbar(i,1)=fbar(i,1)/wght(i,1) ! If you want the average
>>>     enddo
>>> That should pretty much work as is... You need to specify
>>> nelz and lelz >= nelz.
>>> Paul
>>> On Mon, 15 Oct 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi,
>>>> I work in cylindrical geometry and want to evaluate an integral of one of
>>>> scalar fields over the circular cross section at fixed position z_0. I
>>>> suppose that the best way would be to make use of the GLL quadrature formulas
>>>> on the elements after picking the elements at desired height z_0. I have two
>>>> short questions:
>>>> 1/  Is it correct that xm1, ym1, zm1 are the coordinate arrays, i.e. fixing
>>>> for example zm1(i,1,1,1)=0.5 would then give all elements that contain nodes
>>>> in exactly this plane?
>>>> 2/ Are the GLL weights at the primary and secondary nodes stored in a
>>>> specific array or do I have to evaluate them for each element, e.g. by
>>>> combination of 1d routines which are collected in speclib.f?
>>>> Thanks in advance, Joerg.
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
