[Nek5000-users] Transfer data from an nelx*nely*nelz array of Nth-order to an n*n*n array for FFT analysis
Wed Oct 17 13:22:00 CDT 2012
Hi Mike,
Yes, int_tp needs a .box file that will describe the geometry of the data
that is in the files to be interpolated.  Basically, it will take the
geometry of the old and create an interpolation operator to the new
geometry and apply that to the rest of the fields to be interpolated on.
So the .box file must reflect the data in the files in file.list
You might be able to create a .box of the stretched elements if you write
in the xyz distribution of the stretched elements in the .box file by
outputting the endpoints of each element in usrdat.
Best,
Katie
On Wed, Oct 17, 2012 at 11:11 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Katie,
> In regard to your int_tp routine, am I correct that it's not equipped to
> handle a mesh file that was originally generated with genbox, but then
> "stretched" in usrdat?
> Thanks,
> Mike
> Hi,
> I have added an interpolation tool to the repo, int_tp, in
> nek5_svn/trunk/tools/int_tp
> There is also a README in that directory with instructions on the details
> of using the tool.
> (Note - int_tp should be compiled as any standard nek tool in the
> trunk/tools/ directory with "maketools int_tp" or "maketools all")
> Let me know if you encounter complications.
> Thanks,
> Katie
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20121017/d8c4896f/attachment.html>
