[Nek5000-users] Nonzero swirl velocity at the centerline
Sat Oct 6 17:28:43 CDT 2012
Dear Outi,
Do you have the "A  " bc on your elements that touch the centerline?
Are you using the same mesh as vortex2? Or a new one generated with
genbox.
In principal, the A bc should set U_theta=0 on the axis.
Paul
On Sat, 6 Oct 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I have started to use the 2D axisymmetric version of Nek5000 with swirl (like
> the example vortex2), to get some base flows in axisymmetric geometries.
> To test the code I modified the vortex2 example to simple Grabowski vortex
> flow.
> This means setting the inlet profile:
> U_x=1
> U_r=0
> U_theta=0.8944r(2-r^2)
> The result looked good at the first sight, but a closer inspection revealed
> that the swirl velocity (U_theta) is nonzero at the centerline (up to
> U_theta=0.1). Also other axisymmetric flow cases with swirl gave nonzero
> swirl velocities.
> I wonder if it would be possible for someone to look into why this happens? I
> have attached the .usr, .rea and .box files below.
> Also, it would be useful if you could guide me into the precise place in the
> code where the centerline condition for swirl is set. Does OMASK have
> something to do with this? Or is it TMASK?
> Outi
