[Nek5000-users] Setting up a case from scratch
Wed Nov 28 08:00:12 CST 2012
If I specify import.rea file of ext_cyl as the first file during nekmerge I
get this error
$ nekmerge
 ascii or binary output ? (a/b):
a
 Input new (output) file name:
ooo
 Input source .rea file name or press enter to continue:
import
At line 19 of file reader.f
Fortran runtime error: Bad integer for item 1 in list input
praveen
On Wed, Nov 28, 2012 at 7:26 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Thanks to Aleks and Paul. I was able to setup the test case using the
> steps I wrote before (gmsh -> vtx -> prex -> rea).
> Now I am trying to use nek tools to do it.
> Starting from ext_cyl, I try to merge the two meshes to understand the
> process.
> fpcyl.box needs cc2.rea which I could not find. I changed cc2.rea in
> fpcyl.box to import.rea
> Then generate box.rea using genbox.
> Then I try nekmerge but I get following error. What am I doing wrong ?
> Thanks
> praveen
> $ nekmerge
> a
> ooo
> box
> import
>  locglob:           1           1           1        6144
>  locglob:           1           2         199        6144
>  locglob:           2           1        3158        6144
>  locglob:           2           2        3159        6144
> done locglob_lexico:     3159     3159     6144
>  FACE ERROR:         458           4         520           3
> On Wed, Nov 28, 2012 at 6:41 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Praveen,
>> I would recommend starting from the "ext_cyl" example.
>> You should be able to make some progress with this and
>> you could use prenek to modify the geometry if needed.
>> Check out the README in that directory.
>> Let me know if you have questions.
>> Paul
>> On Tue, 27 Nov 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>  Hello
>>> I want to setup a case of 2d cylinder in a channel. I plan to do this way
>>> 1. Make mesh in gmsh
>>> 2. Convert to vtx
>>> 3. Setup in prex and read vtx mesh.
>>> 3.1 make curved sides
>>> 3.2 set boundary conditions
>>> I have already tried all these steps partly. I want to know if there is
>>> any
>>> easier way to do it. Especially making curved sides and setting boundary
>>> conditions needs to be done per boundary edge. Is there a way to make it
>>> faster ?
>>> Thanks
>>> praveen
>>>  ______________________________**_________________
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20121128/4ee7f94d/attachment.html>
