[Nek5000-users] Setting up a case from scratch
Wed Nov 28 07:56:01 CST 2012
Thanks to Aleks and Paul. I was able to setup the test case using the steps
I wrote before (gmsh -> vtx -> prex -> rea).
Now I am trying to use nek tools to do it.
Starting from ext_cyl, I try to merge the two meshes to understand the
process.
fpcyl.box needs cc2.rea which I could not find. I changed cc2.rea in
fpcyl.box to import.rea
Then generate box.rea using genbox.
Then I try nekmerge but I get following error. What am I doing wrong ?
Thanks
praveen
$ nekmerge
 ascii or binary output ? (a/b):
a
 Input new (output) file name:
ooo
 Input source .rea file name or press enter to continue:
box
import
 locglob:           1           1           1        6144
 locglob:           1           2         199        6144
 locglob:           2           1        3158        6144
 locglob:           2           2        3159        6144
done locglob_lexico:     3159     3159     6144
 FACE ERROR:         458           4         520           3
On Wed, Nov 28, 2012 at 6:41 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Praveen,
> I would recommend starting from the "ext_cyl" example.
> You should be able to make some progress with this and
> you could use prenek to modify the geometry if needed.
> Check out the README in that directory.
> Let me know if you have questions.
> Paul
> On Tue, 27 Nov 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>  Hello
>> I want to setup a case of 2d cylinder in a channel. I plan to do this way
>> 1. Make mesh in gmsh
>> 2. Convert to vtx
>> 3. Setup in prex and read vtx mesh.
>> 3.1 make curved sides
>> 3.2 set boundary conditions
>> I have already tried all these steps partly. I want to know if there is
>> any
>> easier way to do it. Especially making curved sides and setting boundary
>> conditions needs to be done per boundary edge. Is there a way to make it
>> faster ?
>> Thanks
>> praveen
>>  ______________________________**_________________
> Nek5000-users mailing list
> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20121128/e335f12f/attachment.html>
