[Nek5000-users] compilation error
Fri May 18 06:58:49 CDT 2012
Hi Vinaya,
You can run Nek5000 with scripts:
http://nek5000.mcs.anl.gov/index.php/Scripts
that create SESSION.NAME.
Best.
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, May 18, 2012 3:44:03 AM
Subject: Re: [Nek5000-users] compilation error
Dear Sir,
As in my previous mail I had told that Iam
able to run, but the run was not successful.
ERROR: Cannot open SESSION.NAME ! ierr= 1
Plz help in this regard.
with regards,
On Fri, May 18, 2012 at 12:52 PM, vinaya sivanandan < vinaya.sivanandan at gmail.com > wrote:
Dear Sir,
Yes, it is able to run.
Thanks a lot.
with regards,
Vinaya
On Fri, May 18, 2012 at 12:07 PM, < nek5000-users at lists.mcs.anl.gov > wrote:
Warnings are fairly standard.
Is it able to run?
Paul
On Fri, 18 May 2012, nek5000-users at lists.mcs.anl. gov wrote:
Dear Sir,
Thank you for your kind response.
I was not using using gfortran but using gcc( 3.4.6 version ) and g77.
After using gfortran(GNU Fortran 95 (GCC) 4.1.0 and gcc( 3.4.6 version ). I
could compile makenek but with warnings.Below are the warnings which I get
while compiling.
*/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ errmem.c: In function
`fail':
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ errmem.c:15: warning:
`noreturn' function does return
gcc -c -O2 -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ crystal.c -o
obj/jl_crystal.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/findpts.c -o
obj/jl2_findpts.o
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9584*
* IF(DFLAG) 50,10,30
1
Warning: Obsolete: arithmetic IF statement at (1)
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9623*
* IF(DFLAG)120,80,100
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9764*
* GO TO IGO,(120,150,180,210)
1
Warning: Obsolete: Assigned GOTO statement at (1)
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9770*
* ASSIGN 120 TO IGO
1
Warning: Obsolete: ASSIGN statement at (1)
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9782*
* ASSIGN 150 TO IGO
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9795*
* ASSIGN 180 TO IGO
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9806*
* ASSIGN 210 TO IGO
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:9815*
* IF(DFLAG)250,230,240
1
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/findpts_local.c
-o obj/jl2_findpts_local.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/obbox.c -o
obj/jl2_obbox.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/poly.c -o
obj/jl2_poly.o
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17100*
* IF(SFLAG) 50,10,30
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17139*
* IF(SFLAG)120,80,100
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17277*
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17283*
* ASSIGN 120 TO IGO
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17295*
* ASSIGN 150 TO IGO
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17308*
* ASSIGN 180 TO IGO
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17319*
* ASSIGN 210 TO IGO
1
In file
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/ 3rd_party/blas.f:17328*
* IF(SFLAG)250,230,240
1
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/lob_bnd.c -o
obj/jl2_lob_bnd.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/findpts_el_3.c
-o obj/jl2_findpts_el_3.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/findpts_el_2.c
-o obj/jl2_findpts_el_2.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/sparse_cholesky.c
-o obj/jl2_sparse_cholesky.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/xxt.c -o
obj/jl2_xxt.o
-DPREFIX=jl_
/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek/jl/ ../jl2/fcrs.c -o
obj/jl2_fcrs.o
gfortran -c -O2 -fcray-pointer -fdefault-real-8 -x f77-cpp-input
-I/home/secg/cfd/vinayas/ nek5000/testnek/rayleigh1
-I/home/secg/cfd/vinayas/ nek5000/nek5_svn/trunk/nek -I./
/home/secg/cfd/vinayas/ nek5000/testnek/rayleigh1/ rayleigh.f -o
obj/rayleigh.o
gfortran -o nek5000 obj/rayleigh.o obj/drive.o obj/drive1.o obj/drive2.o
obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o
obj/hsmg.o obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o
obj/navier6.o obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o
obj/calcz.o obj/byte.o obj/chelpers.o obj/byte_mpi.o obj/postpro.o
obj/cvode_driver.o obj/nek_comm.o obj/init_plugin.o obj/setprop.o
obj/qthermal.o obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o
obj/dsygv.o obj/mxm_std.o obj/blas.o obj/comm_mpi.o obj/mpi_dummy.o
obj/jl2_gs.o obj/jl2_sort.o obj/jl2_sarray_transfer.o obj/jl2_sarray_sort.o
obj/jl2_gs_local.o obj/jl2_crystal.o obj/jl2_comm.o obj/jl2_tensor.o
obj/jl2_fail.o obj/jl2_fcrystal.o obj/jl_tuple_list.o obj/jl_transfer.o
obj/jl_sort.o obj/jl_fcrystal.o obj/jl_errmem.o obj/jl_crystal.o
obj/jl2_findpts.o obj/jl2_findpts_local.o obj/jl2_obbox.o obj/jl2_poly.o
obj/jl2_lob_bnd.o obj/jl2_findpts_el_3.o obj/jl2_findpts_el_2.o
obj/jl2_sparse_cholesky.o obj/jl2_xxt.o obj/jl2_fcrs.o
# Compilation successful! #
text data bss dec hex filename
2073815 2992 24176824 26253631 190993f nek5000*
Thanks and regards
Vinaya
On Thu, May 17, 2012 at 5:51 PM, < nek5000-users at lists.mcs.anl. gov > wrote:
Are you using gfortran and gcc?
I would suggest setting these as your compiler in makenek
and also settig IFMPI to false in the makenek script.
Then,
makenek clean
before resuming your attempt to compile.
Best regards,
Paul
On Thu, 17 May 2012, nek5000-users at lists.mcs.anl.** gov< nek5000-users at lists.mcs. anl.gov >wrote:
Dear Sir,
Iam trying to compile makenek in (x86_64 x86_64 x86_64 GNU/Linux)
environment
the error is:
*Unable to detect compiler!
- don't know how to promote datatype REAL to 8 bytes
- don't know how to invoke the C pre-processor (CPP) before
compilation
Please edit the makefile and specify the requested compiler flags
using the P variable.*
*generating makefile ...*
Plz help me in this regard
*Vinaya Sivanandan*
*Pune*
______________________________ **_________________
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.** gov < Nek5000-users at lists.mcs.anl. gov >
https://lists.mcs.anl.gov/** mailman/listinfo/nek5000-users < https://lists.mcs.anl.gov/ mailman/listinfo/nek5000-users >
*Vinaya Sivanandan*
*Pune*
______________________________ _________________
Vinaya Sivanandan
Pune
Vinaya Sivanandan
Pune
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
