[Nek5000-users] compilation error
Fri May 18 03:44:03 CDT 2012
Dear Sir,
As in my previous mail I had told that Iam
 able to run, but the run was not successful.
ERROR: Cannot open SESSION.NAME! ierr= 1
Plz help in this regard.
with regards,
On Fri, May 18, 2012 at 12:52 PM, vinaya sivanandan <
vinaya.sivanandan at gmail.com> wrote:
> Dear Sir,
> Yes, it is able to run.
> Thanks a lot.
> with regards,
> Vinaya
> On Fri, May 18, 2012 at 12:07 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi,
>> Warnings are fairly standard.
>> Is it able to run?
>> Paul
>> On Fri, 18 May 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>> Dear Sir,
>>> Thank you for your kind response.
>>> I was not using using gfortran but using gcc( 3.4.6 version ) and g77.
>>> After using gfortran(GNU Fortran 95 (GCC) 4.1.0 and gcc( 3.4.6 version
>>> ). I
>>> could compile makenek  but with warnings.Below are the warnings which I
>>> get
>>> while compiling.
>>> */home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**errmem.c: In
>>> function
>>> `fail':
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**errmem.c:15:
>>> warning:
>>> `noreturn' function does return
>>> gcc -c  -O2 -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**crystal.c -o
>>> obj/jl_crystal.o
>>> -DPREFIX=jl_
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**../jl2/findpts.c
>>> -o
>>> obj/jl2_findpts.o
>>> In file
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/**
>>> 3rd_party/blas.f:9584*
>>> *               IF(DFLAG) 50,10,30
>>>        1
>>> Warning: Obsolete: arithmetic IF statement at (1)
>>> In file
>>> 3rd_party/blas.f:9623*
>>> *          IF(DFLAG)120,80,100
>>>        1
>>> In file
>>> 3rd_party/blas.f:9764*
>>> *      GO TO IGO,(120,150,180,210)
>>>             1
>>> Warning: Obsolete: Assigned GOTO statement at (1)
>>> In file
>>> 3rd_party/blas.f:9770*
>>> *               ASSIGN 120 TO IGO
>>>        1
>>> Warning: Obsolete: ASSIGN statement at (1)
>>> In file
>>> 3rd_party/blas.f:9782*
>>> *               ASSIGN 150 TO IGO
>>>        1
>>> In file
>>> 3rd_party/blas.f:9795*
>>> *               ASSIGN 180 TO IGO
>>>        1
>>> In file
>>> 3rd_party/blas.f:9806*
>>> *               ASSIGN 210 TO IGO
>>>        1
>>> In file
>>> 3rd_party/blas.f:9815*
>>> *          IF(DFLAG)250,230,240
>>>        1
>>> -DPREFIX=jl_
>>> ../jl2/findpts_local.c
>>> -o obj/jl2_findpts_local.o
>>> -DPREFIX=jl_
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**../jl2/obbox.c
>>> -o
>>> obj/jl2_obbox.o
>>> -DPREFIX=jl_
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**../jl2/poly.c
>>> -o
>>> obj/jl2_poly.o
>>> In file
>>> 3rd_party/blas.f:17100*
>>> *               IF(SFLAG) 50,10,30
>>>        1
>>> In file
>>> 3rd_party/blas.f:17139*
>>> *          IF(SFLAG)120,80,100
>>>        1
>>> In file
>>> 3rd_party/blas.f:17277*
>>>             1
>>> In file
>>> 3rd_party/blas.f:17283*
>>> *               ASSIGN 120 TO IGO
>>>        1
>>> In file
>>> 3rd_party/blas.f:17295*
>>> *               ASSIGN 150 TO IGO
>>>        1
>>> In file
>>> 3rd_party/blas.f:17308*
>>> *               ASSIGN 180 TO IGO
>>>        1
>>> In file
>>> 3rd_party/blas.f:17319*
>>> *               ASSIGN 210 TO IGO
>>>        1
>>> In file
>>> 3rd_party/blas.f:17328*
>>> *          IF(SFLAG)250,230,240
>>>        1
>>> -DPREFIX=jl_
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**../jl2/lob_bnd.c
>>> -o
>>> obj/jl2_lob_bnd.o
>>> -DPREFIX=jl_
>>> ../jl2/findpts_el_3.c
>>> -o obj/jl2_findpts_el_3.o
>>> -DPREFIX=jl_
>>> ../jl2/findpts_el_2.c
>>> -o obj/jl2_findpts_el_2.o
>>> -DPREFIX=jl_
>>> ../jl2/sparse_cholesky.c
>>> -o obj/jl2_sparse_cholesky.o
>>> -DPREFIX=jl_
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**../jl2/xxt.c -o
>>> obj/jl2_xxt.o
>>> -DPREFIX=jl_
>>> /home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek/jl/**../jl2/fcrs.c
>>> -o
>>> obj/jl2_fcrs.o
>>> gfortran -c  -O2 -fcray-pointer -fdefault-real-8 -x f77-cpp-input
>>> -I/home/secg/cfd/vinayas/**nek5000/testnek/rayleigh1
>>> -I/home/secg/cfd/vinayas/**nek5000/nek5_svn/trunk/nek -I./
>>> /home/secg/cfd/vinayas/**nek5000/testnek/rayleigh1/**rayleigh.f -o
>>> obj/rayleigh.o
>>> gfortran -o nek5000  obj/rayleigh.o obj/drive.o obj/drive1.o obj/drive2.o
>>> obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
>>> obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
>>> obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
>>> obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
>>> obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
>>> obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
>>> obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o
>>> obj/hsmg.o obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o
>>> obj/navier6.o obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o
>>> obj/calcz.o obj/byte.o obj/chelpers.o obj/byte_mpi.o obj/postpro.o
>>> obj/cvode_driver.o obj/nek_comm.o obj/init_plugin.o obj/setprop.o
>>> obj/qthermal.o obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o
>>> obj/dsygv.o obj/mxm_std.o obj/blas.o obj/comm_mpi.o obj/mpi_dummy.o
>>> obj/jl2_gs.o obj/jl2_sort.o obj/jl2_sarray_transfer.o
>>> obj/jl2_sarray_sort.o
>>> obj/jl2_gs_local.o obj/jl2_crystal.o obj/jl2_comm.o obj/jl2_tensor.o
>>> obj/jl2_fail.o obj/jl2_fcrystal.o obj/jl_tuple_list.o obj/jl_transfer.o
>>> obj/jl_sort.o obj/jl_fcrystal.o obj/jl_errmem.o obj/jl_crystal.o
>>> obj/jl2_findpts.o obj/jl2_findpts_local.o obj/jl2_obbox.o obj/jl2_poly.o
>>> obj/jl2_lob_bnd.o obj/jl2_findpts_el_3.o obj/jl2_findpts_el_2.o
>>> obj/jl2_sparse_cholesky.o obj/jl2_xxt.o obj/jl2_fcrs.o
>>> #                  Compilation successful!                  #
>>>  text    data     bss     dec     hex filename
>>> 2073815    2992 24176824        26253631        190993f nek5000*
>>> Thanks and regards
>>> Vinaya
>>> On Thu, May 17, 2012 at 5:51 PM, <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>>
>>> wrote:
>>>> Are you using gfortran and gcc?
>>>> I would suggest setting these as your compiler in makenek
>>>> and also settig IFMPI to false in the makenek script.
>>>> Then,
>>>> makenek clean
>>>> before resuming your attempt to compile.
>>>> Best regards,
>>>> Paul
>>>> On Thu, 17 May 2012, nek5000-users at lists.mcs.anl.****gov<
>>>> nek5000-users at lists.mcs.**anl.gov <nek5000-users at lists.mcs.anl.gov>
>>>> >wrote:
>>>>  Dear Sir,
>>>>> Iam trying to compile makenek in (x86_64 x86_64 x86_64 GNU/Linux)
>>>>> environment
>>>>> the error is:
>>>>> *Unable to detect compiler!
>>>>>      - don't know how to promote datatype REAL to 8 bytes
>>>>>      - don't know how to invoke the C pre-processor (CPP) before
>>>>> compilation
>>>>>     Please edit the makefile and specify the requested compiler flags
>>>>> using the P variable.*
>>>>> *generating makefile ...*
>>>>> Plz help me in this regard
>>>>> *Vinaya Sivanandan*
>>>>> *Pune*
>>>>> ______________________________****_________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.****gov <Nek5000-users at lists.mcs.anl.**gov<Nek5000-users at lists.mcs.anl.gov>
>>>> https://lists.mcs.anl.gov/****mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users>
>>>> **<https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>> *Vinaya Sivanandan*
>>> *Pune*
>>>  ______________________________**_________________
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
> *Vinaya Sivanandan*
> *Pune*
*Vinaya Sivanandan*
*Pune*
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120518/8918d170/attachment.html>
