[Nek5000-users] error in n2to3
Wed May 9 11:24:19 CDT 2012
Hi Adam,
Can you send a tar file to me at klheisey at gmail.com with the case that is
giving an error?
The mhd bug has been fixed.
Thanks
katie
On Wed, May 9, 2012 at 7:10 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Katie
> It was gfortran and gcc and the error message:
> At line 286 of file n2to3.f
> Fortran runtime error: Bad integer for item 1 in list input
> I've solved problem declaring mhd as real. However, there seem to be
> more bugs, since I've got following email:
> > I found another bug in the n2to3 routine. When I'm choosing the option
> > to create the re2 and rea file at the same time, the code gives an
> > error while running. I don't know if it's specific to my case, so if
> > you have another case to try this on it would be interesting to know
> > if it also gives an error. In such a case, it might be good to report
> > this together with the other bug you found. However, I couldn't figure
> > out how this bug arises. (Although, this bug is not a problem since
> > the option to do this in 2 steps exist, n2to3 and then reatore2)
> regards
> Adam
> On Mon, 2012-05-07 at 11:50 -0500, nek5000-users at lists.mcs.anl.gov
> wrote:
> > Hi Adam,
> > Thanks.  Can you send me the error message you are getting?  (And what
> > compiler you are using.  Just for future reference.)
> > Thanks,
> > Katie
> > Email:  klheisey at gmail.com
> > On Mon, May 7, 2012 at 3:36 AM, <nek5000-users at lists.mcs.anl.gov>
> > wrote:
> >         Hi
> >         Just to report. There is an integer variable mhd reading real
> >         number in
> >         the newest version of n2to3.f (line 286, subroutine rea23) and
> >         causing
> >         error message.
> >         Regards
> >         Adam
> >         _______________________________________________
> >         Nek5000-users mailing list
> >         Nek5000-users at lists.mcs.anl.gov
> >         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120509/144d2590/attachment.html>
