[Nek5000-users] error in n2to3
Wed May 9 07:10:08 CDT 2012
Hi Katie
It was gfortran and gcc and the error message:
At line 286 of file n2to3.f
Fortran runtime error: Bad integer for item 1 in list input
I've solved problem declaring mhd as real. However, there seem to be
more bugs, since I've got following email:
> I found another bug in the n2to3 routine. When I'm choosing the option
> to create the re2 and rea file at the same time, the code gives an
> error while running. I don't know if it's specific to my case, so if
> you have another case to try this on it would be interesting to know
> if it also gives an error. In such a case, it might be good to report
> this together with the other bug you found. However, I couldn't figure
> out how this bug arises. (Although, this bug is not a problem since
> the option to do this in 2 steps exist, n2to3 and then reatore2)
regards
Adam
On Mon, 2012-05-07 at 11:50 -0500, nek5000-users at lists.mcs.anl.gov
wrote:
> Hi Adam,
> Thanks.  Can you send me the error message you are getting?  (And what
> compiler you are using.  Just for future reference.)
> Thanks,
> Katie
> Email:  klheisey at gmail.com
> On Mon, May 7, 2012 at 3:36 AM, <nek5000-users at lists.mcs.anl.gov>
> wrote:
>         Hi
>         Just to report. There is an integer variable mhd reading real
>         number in
>         the newest version of n2to3.f (line 286, subroutine rea23) and
>         causing
>         error message.
>         Regards
>         Adam
>         _______________________________________________
>         Nek5000-users mailing list
>         Nek5000-users at lists.mcs.anl.gov
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
