[Nek5000-users] Surface source term
Fri Mar 9 11:19:10 CST 2012
Hi Paul,
             yes, I use also "iel = gllel(ieg)".
I have just checked the energy balance and it is fine.
Thanks a lot for your answer.
Andreas.
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, March 09, 2012 6:10 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Surface source term
Hi Andreas,
That looks right to me...  Did you also use:
       iel = gllel(ieg)
where ieg is the argument passed into the call line?
Also, do you get the expected energy balance in a test case?
Best,
Paul
On Fri, 9 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear NEKs,
>                I am trying to add a surface source term in the energy equation on a certain surface of my 2D domain.
> The way I did was to put into userq the following expression:
> qvol = qref*area(ix,1,ifc,iel)/bm1(ix,iy,iz,iel)
> The case seems to work fine but I would like to ask you just a confirmation that the way I did is correct (maybe there are some mathematical/physical reasons why that way is wrong).
> Thanks in advance for your help.
> Regards,
> Andreas.
> Nek5000-users mailing list
