[Nek5000-users] Surface source term
Fri Mar 9 11:10:54 CST 2012
Hi Andreas,
That looks right to me...  Did you also use:
       iel = gllel(ieg)
where ieg is the argument passed into the call line?
Also, do you get the expected energy balance in a test case?
Best,
Paul
On Fri, 9 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear NEKs,
>                I am trying to add a surface source term in the energy equation on a certain surface of my 2D domain.
> The way I did was to put into userq the following expression:
> qvol = qref*area(ix,1,ifc,iel)/bm1(ix,iy,iz,iel)
> The case seems to work fine but I would like to ask you just a confirmation that the way I did is correct (maybe there are some mathematical/physical reasons why that way is wrong).
> Thanks in advance for your help.
> Regards,
> Andreas.
> Nek5000-users mailing list
